View Full Version : Suspension Performance
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. full coilovers for less than 1000?
  2. AROSPEED????
  3. Buy anything else with Tein SS?
  4. is alignment something under warranty?
  5. TEIN Springs
  6. MaKING A DIFFERENCe!!!
  7. $300...enough to lower????
  8. Tein S Tech & Camber Kit queston
  9. Just a little Tein FYI....
  10. SPC=Gold line
  11. so many choices, what to choose??
  12. Will B&G Coilovers fit a 2002 model?
  13. TOWER/STRUT BAR
  14. air suspension for civic sedan
  15. which koni? red or yellow
  16. What do you think about KONI+GC Coilovers???
  17. Who has raced on Tein SS (AutoX/Road Course)?
  18. Where 2 buy Neuspeed?
  19. Skunk2 Coilovers
  20. just got my air bags done
  21. Allen socket stripped - Help!
  22. I think I got a very good deal
  23. Camber kit
  24. torqueing down the rear sway bar
  25. need help on what springs to get?
  26. Coilovers & Tower Bars?
  27. What is best shock spring combo that is near stock ride quality?
  28. Front or Rear?
  29. why is the rear is so low with GC's?
  30. difference between
  31. LOWERING STEPS: ....?
  32. Spring Length - B&G vs. Tein
  33. DIY: Energy Suspension Sway Bar Bushings
  34. X-brace creaking....
  35. Anyone get the H&R Cup kit
  36. Tein is NUTS!!
  37. Newbie suspension questions?
  38. Tein SS vs Basic
  39. springs
  40. rsx rear sway bar
  41. Black 7th Gen hydraulic civic
  42. FYI: suspension prod. quote
  43. Eibach pro or H&R sport
  44. rear strut bar
  45. Tein Springs with 18's
  46. Best Place to get Progress Rear Sway/Tie Bar!!
  47. Skunk2 "Lowering Springs"
  48. I need some pics????????
  49. is this good deal
  50. nm
  51. Tokico's out...
  52. Progress to release full 4 corner swap set, good-bye Tein!
  53. Ground Control or Sprint Springs
  54. TEINS anyone?
  55. The never ending Squeek Saga Continues
  56. Problem with Tein spring
  57. Question???
  58. how to impreve stability?
  59. struts
  60. Ride Height in Canadian Conditions
  61. mugen strut bar
  62. eibach 1.4 inch drop, camber needed?
  63. Do you Need a Rear lower tie bar??
  64. Back is lower than the front....
  65. Can I lower for cheaper than a grand?
  66. What do you think of these neuspeed bushings?
  67. Question About Air Bags!
  68. + and - of H&R and TEIN SS coilovers???
  69. Back is lower than the front....
  70. Back is lower than the front....
  71. suspension problem???
  72. SPC Camber Kit Owners, Read
  73. Help w/lowering Decision!
  74. Define Vague: KYB Fall
  75. How do u higher the perch???
  76. Older Civic Springs
  77. for those w/ Ground Control
  78. RSX-s endlinks and 7thgen endlinks? are they different?
  79. Is too much??
  80. Can you ride stock height on Tein SS?
  81. Camber kit
  82. Can I lower for cheap?
  83. RS Akimoto bar works
  84. coilover and sleeve..Who's got the best?
  85. Cutting Coils on my Prokit Springs
  86. Sedan sagging
  87. I keep scratching my exhaust
  88. anybody has h&r cup kit??
  89. Tein SS
  90. neuspeed front strut bar Q
  91. Alignment?
  92. Best options for Heavy Stereo
  93. it is true our car don't need a camber kit?
  94. lower front bar: neuspeed or spoon sports
  95. Torque on Shocks and Struts...
  96. Are the stock struts for the 2001+ EX that bad?
  97. Ground Control
  98. DIY: New hardware for Spoon Sports strut bars.
  99. skunk2 coilovers
  100. Could someone scan the Neuspeed F/U strut bar instructions?
  101. Is it ok to have only a f/u strut bar?
  102. BEST SHOCKS FOR BEST PRICE?
  103. where are struts located?
  104. where to buy tien coil overS?
  105. Edit: HELP on removing FRONT STRUT...
  106. What do I use to cut springs?
  107. Anyone with neuspeed race?
  108. Neuspeed Sport Springs on a 2002 SI?
  109. tokicos dammit!!!
  110. Floor Bar/Monkey Bar - What are the options
  111. Will slamming go away with Tein SS?
  112. MAX Speed Coilovers...
  113. Eibach or Progress ARB's?
  114. Best cutting setup.
  115. RSX TypeS Sway Bar..
  116. S/T Sway Bar Kit is out and in stock!
  117. Looking for neuspeed x-brace...
  118. tein or neuspeed race
  119. Progress and tanabe
  120. Squeaky ride
  121. Lowest Drop from Springs?
  122. Where can i get spc camber kit?
  123. Suspension set up
  124. Help With Ground Control Coil Overs....What is this called?
  125. people with eibach sportlines
  126. Do I need to get springs if.....
  127. coil overs
  128. just installed my neuspeed F U bar
  129. Neuspeed rear sway/tir bar combo installed....
  130. Official Suspension Drop Pictures Post
  131. How to make steering tighter.
  132. Front strut tower bar?
  133. There is no Progress Front SB
  134. best (simple) improvement mods?
  135. sound when I brake or clutch
  136. I'm Gonna Be a Newbie for a Second...
  137. Goldlines & Camber Kit..
  138. Strut Bars
  139. Ordered Goldlines! Now a Camber?
  140. help with lowering
  141. Eibach Sportline Kit
  142. people with ground control coil-over or any kind of coil-over
  143. blown shocks?
  144. springs or coilovers
  145. How low can I go?
  146. What kind of spring to use with Koni's?
  147. What are these strut and sway bars?
  148. What better for the progress sway bar a after market tie bar or use the progress one
  149. pics of lowered sedans?
  150. Sway bar ?? for 2003 coupe
  151. WHITELINE SPRINGS
  152. TOKICO NON ADJUSTABLE shocks for civic 01+
  153. confused: tein flex
  154. DO I NEED A CAMBER KIT?
  155. broke another endlink
  156. RSX type-s VS base swaybars
  157. camber kit install?
  158. Anyone Hearin' This?
  159. Progress springs sagging?
  160. Whats Tha Best Droping Spring?
  161. Installing JIC-Magic FLT-A2 tonight have questions...(update INSTALLED)
  162. neuspeed strut bar on
  163. slamming this thing
  164. What set up should i do?
  165. Progress Auto full coilover / strut kit!!!!
  166. Neuspeed strut bar installation question
  167. COIL OVERS ANY GOOD?????
  168. Does anyone on this site even have these??
  169. TEIN FLEX: finally!
  170. Price Question
  171. rsx springs on 7 gen?
  172. question about tein SS
  173. Choices on springs
  174. GoldLine Springs: Wonder what your car would look like?
  175. Tokico Shocks...possible update...
  176. Rear upper strut question
  177. camry springs
  178. new version of goldlines or old version??
  179. Those with H&R's....
  180. Fragile upper mount rubber ?
  181. How much do alignment job cost you guys?
  182. Koni Shocks or Tein Basic
  183. SKUNK 2 coilovers
  184. I got a question
  185. Which Springs should I get?
  186. 7th gen bad shock and strut curse?
  187. Ingalls Camber Kit?
  188. Re: Changes regarding the 2001~2003 suspension
  189. How low should I go?
  190. Installed my KONI's.....FEW PROBLEMS TO WATCH OUT FOR
  191. Is this the eBay rear upper strut bar that everyone has?
  192. Did anyone have this problem?
  193. Spring install on sedan Q
  194. Will Raising The Ring Below The Perch Raise Car With Koni?
  195. Blown Struts w/stock susp. = Poss. Recall or TSB
  196. camber kits
  197. Need to finish my suspension the right way, need some feedback
  198. Question about my drop
  199. Does EX rear sway bar fit 3rd gen Integs??
  200. Straight out of Teins mouth regarding stiffer springs
  201. B&G
  202. How should you set up your car for touge?
  203. springs look weird
  204. Problem with KONI's
  205. Have Pics of the Progress Hardware kit for DX/LX?
  206. Bout to work on my suspension.. just need advice..
  207. This might be dumb
  208. what is the factory setting for our camber??
  209. whining noise from under hood - suspension ?
  210. RSX sway bar questions
  211. Prices on an SPC Camber Kit
  212. Lowering car help please...
  213. Unsafe ride
  214. Tein SS or Koni with Eibach springs??
  215. Got them Teins!
  216. What vendors will carry the new progress coilovers?
  217. best suspension 4 20's on a 03 civic coupe
  218. SPRINGS BABY!!
  219. b&g or tein ss???
  220. Front Springs Install Question
  221. Lower tie bar
  222. My coil-over make to much noise
  223. Anyone have the new energy suspension control arm bushings?
  224. Neuspeed Sport or Goldlines??? Help!
  225. What's a good price for RSX rear sway bar?
  226. will it rub
  227. 2.0” Proper Drop Shopping List
  228. Front upper strut bar with AEM CAI
  229. Spoon Rear Upper Tie Bar
  230. riding on air.
  231. coilover q's
  232. HELP with dropping my car...
  233. Stock Shocks??
  234. Neuspeed Race/Sport w/ Stock rims
  235. Tein S-Tech springs?????
  236. Clunking Noise from front wheels!
  237. how long to install B+G???
  238. what kind of struts should i use?
  239. Anyone switch from COIL to SPRING???
  240. air struts
  241. PLEASE READ: 2K1 Suspension Replaced
  242. Neuspeed strut bar ???
  243. Coils or Springs
  244. Strut Bars that will work with the K&N CAI
  245. Tein ss Install help
  246. this is a very stupid question
  247. Alignment before camber kit?
  248. Will Neuspeed upper front strut bar work with Tein SS?
  249. Springs ride quality
  250. Looking Ground Control
