View Full Version : Suspension Performance
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. cutting off springs....''good or bad''?!?!
  2. Called H&R about cup kit
  3. Neuspeed Upper Brace installed on 2k1
  4. RSX front and rear sway in my Civic?
  5. TIEN SS Problems!!!!
  6. Progress swaybar problem!!!!
  7. Alot of people in dropped car??
  8. POST PICS WITH PROGRESS SPRINGS!!!
  9. neuspeed sport
  10. Ground Controls Vs. Skunk2 (**Searched**)
  11. Gold Line Announcement
  12. Which best spring and how many inches drop for 03 Si rims?
  13. Attn lowered civics
  14. H&R Sport Series Springs
  15. CUT bumpstops on neuspeed sport?
  16. RSX 19mm swaybar and TCS
  17. will our chasis last with aftermarket springs??
  18. Stock Sedan struts & Srpings w/ Progress Bars and Neuspeed Brace?
  19. Tein Type-FLEX with EDFC
  20. Front Koni Strut Bolts
  21. HONDA FACTORY LOWERING LIT
  22. diy problem??
  23. Springs that won't lower
  24. Progress Rear Sway Bar and Rear Lower Tie Bar
  25. Sprint camber kits
  26. Question about lowering with certain size tires...
  27. neuspeed sport for sedans
  28. for those with goldline springs
  29. Weird alignment/lowering problems
  30. do springs pass inspection??? just curious, cuz im lowering my car
  31. Camber kit with sportslines?
  32. ground control coilovers /stock shocks
  33. You get what you pay for! ebay camber kit
  34. air sus. install ???
  35. koni yellow where to buy?
  36. Which type of springs? I know its repetitive...
  37. Blowing Steam on "Bouncy"
  38. To people who ordered the hotchkis sway bar kit (please read)
  39. size of civic coil overs
  40. Super down precedos Springs?
  41. HOW LOW CAN I GO...W/215/35/18??
  42. what the hell is this noise?!
  43. a blown shock???
  44. Hows H&R???
  45. Confusion between struts and shocks?
  46. help steering wheel shakes when im in 4th gear around 85 km/h
  47. ordered my springs
  48. new toy
  49. front upper strut bar
  50. does anyone have a DIY spring install?
  51. Rsx type r rear lower sway bar 22mm will it fit 2k1 civic
  52. Eibach Sportlines?
  53. Carreview.coms SPRINGS RATINGS
  54. DIY for installing Neuspeed springs 02 coupe
  55. ingalls kit
  56. Edelbrock Shocks
  57. What happen happen to it!!
  58. What part do I need to do the RSX-S sway conversion
  59. Po' mans front strut dust boot fix.. how to keep them up
  60. Getting springs
  61. Freakin Squeakin Creakin Sway Bar
  62. strut bar installation
  63. Koni adjustable point broke what to do?
  64. NFG with a Question
  65. Does LOWER SPRINGS cost $350 to install???
  66. EAI's new bolt in air ride for 01 Civic...
  67. Dumb Question!
  68. RSX sway bar
  69. neuspeeds are noisey
  70. Neuspeed sway bar
  71. Sticky: Suspension FAQ
  72. Ground Control Creeking question...
  73. Drop Zone vs. Ground Control
  74. Left front camber is off, but no drop!?
  75. Best Lowering Springs
  76. Frame bar (or whatever u want to call it) for 02+
  77. H&R Cup Kit?
  78. Which Coilovers???
  79. Big Heavy Wheels :In Case You Didn't Know
  80. Tein SS
  81. what are the Bump stops?
  82. Suspension Creaking (Skunk2)
  83. Teins are on their way
  84. Progress Front Sway Bar with an EX???
  85. Any good rear uppper strut bars out yet?
  86. For Tein ss or b & g owners
  87. come one come all and rate the type R rear sway bar if you have it
  88. Question: Should I get a shock?!?!
  89. Need Sway bar/tie bar that will work with DC Sports TCS
  90. BEST SPRINGS OR COILOVERS OUT
  91. Camber Kits...prices...kinds
  92. how low??
  93. Neuspeed Lower Rear Tie Bar (pics)
  94. Alignment or Tires??
  95. Neuspeed Spring Owners!
  96. Koni's with GC or Skunk2 Coilovers
  97. Crap!
  98. how about weapon-R coilovers?
  99. Question about camber kits
  100. ATTN: Type-S rear sway bar owner please read!
  101. Emergency!!! Neuspeed sports or H&R sports?!
  102. spring install
  103. eibach anti roll kit
  104. For those of your with ground control!!!
  105. progress swaybars/neuspeed lower front and rear ties
  106. SHOCKS n SPRINGS
  107. Eibach Pro-Kit
  108. question about suspension on 2dr coupes
  109. 03 Springs
  110. Will shocks blow???
  111. H&R Coilovers for Civic and RSX !!
  112. GC or springs install
  113. install coilovers
  114. Air ride or Hydraulics??? Which one to get??
  115. RSX-S sway bar!!!
  116. --HELP-- SPRING problem
  117. I need help chooseing between sway bars
  118. Confirm JDM DC5 type R 22mm sway bar FIT!!! LX/EX
  119. Suspension Questions for 02 EX
  120. ATTENTION KONI OWNERS!!
  121. Solidifying the perch on the Rear Koni Shocks
  122. drop zone springs???
  123. do 7th gens need new sway bars?
  124. dropzone GB
  125. OoOhhhh OooOoOHH!!! Front Upper Strut Bar
  126. opinions?
  127. ATTN: ppl with TEIN SS COILOVERS!!
  128. Will a $28 rear strut bar reduce understeer?
  129. B+G Coilovers? Ride Quality? Help?
  130. To those who installed goldlines...
  131. 2 finger gap..
  132. STRUT Bar quest
  133. Tien S. Springs????
  134. GC Coilover lengths
  135. Which coilovers system to get?? Tein,B&G, or H&R??
  136. Help!! Suspension dilemma!
  137. Help! Suspension Dilemma!!
  138. Neuspeed rear lower tie bar installed w/pics
  139. tokico illumina
  140. Suspension Noise...What is it?
  141. Intrax Springs??
  142. springs installed or get a CAI?
  143. camber kit for Goldline springs
  144. But, but, but......I wanna
  145. Finally got my Neuspeed Rear Lower Brace (tie bar).. check out the pics
  146. do i need a camber kit =/
  147. Tein SS Install Time
  148. Front stock struts bottoming out.
  149. Cut perches on springs?
  150. Suspension Problems, Need Advice
  151. finally
  152. tenzo R strut bar
  153. strut bars?
  154. My new toys`
  155. question
  156. Need some suggestions
  157. Rear Lower Strut Bars?
  158. ok.. my rear has no wheelgap
  159. spring installation: which direction
  160. What kind of camber kit should I get?
  161. What Lowering springs to get....
  162. Goldlines and wheelgap
  163. Neuspeed Lower X Brace Impressions
  164. Koni's are knock,knock knocking!
  165. ticking noise when i turn
  166. macpherson strut
  167. Help....need rear shock suggestions
  168. lowering 2002 Civic Si coupe?
  169. Bushings for Stock sway bars
  170. Camber kit
  171. SPC or Ingalls for full camber kit?
  172. Progress springs on stock struts/shocks..DESCRIBE
  173. H&R True Coilovers or Cup-Kit?
  174. Sportlines or ProKit on stock rims?
  175. Sprint Springs
  176. Does this sound right
  177. I need some info on coilovers??
  178. goldlines installed as we speak
  179. polyurethane bushings - 19mm
  180. bump guards
  181. Do I need to get alignment?
  182. Good Online Store?
  183. Tien S Springs??????
  184. Goldline Install Help
  185. springs or coilovers??
  186. Springs?
  187. Installed my rear Sway
  188. DIY Spring & Camber Kit Install...no pics...yet
  189. Neuspeed Sports With My Wheels
  190. koni yellow
  191. ground control diy?
  192. Neuspeed race
  193. exhaust in a way of sway bar
  194. TEIN SS installed
  195. Camber kit at 45$
  196. Honda OEM spec allignment
  197. My progress rear sway bar broke my...
  198. Best springs camparison
  199. New here, question about camber kits
  200. JUST INsTALLEd RsX TypE S ReAR ShoCks!!
  201. 0-4 inch drop coilovers for 50$
  202. Simple Tein Flex Question
  203. NEW PRODUCTS!!!
  204. Full Coilover System - Adjusting
  205. H&R Cup Kit - Availability ?
  206. Skunk 2 lowering springs, How low will I go?
  207. Need help ASAP (Neuspeed installation)
  208. Lowering with 17 or 18" rims? Springs or Coilovers? OPINIONS PLEASE.
  209. Tein Basic Damper ~update~
  210. tokico and coilovers
  211. question about springs....
  212. Koni Yellow Strut/Shock Install, How Much Did You Pay?
  213. Can I correct the camber myself??
  214. HELP: my front lower control arm has broken
  215. Intrax...Did a search
  216. DC sport or Neuspeed?
  217. What are the best coil overs
  218. koni shockss
  219. Lowering and Speed Bumps..
  220. does a strutbar make all the difference?
  221. Installed: Spoon Sport Rear Upper Strut
  222. Koni Schocks
  223. For Gold Lines.. do you need to cut the bump stop?
  224. HELP ASAP! Tie rod problem...
  225. Where can I get RSX SWAY BAR
  226. TEIN SS Adjustment Knob
  227. PLEASE HELP!
  228. 2002 Civic Ex suspension
  229. Strut bars or Sway bars
  230. Final lowdown on Skunk2 and Koni Yellow
  231. Just installed Neuspeed front upper strut bar ( PICS INSIDE )
  232. Just got Teins
  233. Tein Question
  234. BEst spring
  235. HP Racing full coilover kit
  236. pics of eibach prokit?
  237. Drop options for 215/45/17 tires???
  238. Help please
  239. Blown Struts
  240. Ground Control Coil Overs...Tools?
  241. GOLDLINE Is Awesome!!!!!!!!!!
  242. Rear upper tie bar is it worth it?
  243. What is a good suspension system overall?
  244. Tein S-Tech Springs
  245. What are the best springs
  246. recommendations?
  247. getiing groundcontrol installed tommorrow
  248. What to do? Front struts blown......
  249. 17's drop Options on budget.
  250. Camber Kit Question
