View Full Version : Suspension Performance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30
  1. Update
  2. Im Excited!
  3. konis squeeking, need some input
  4. Ride Height measurements
  5. Lowering Springs Knocking!! HELP!
  6. RSX-S rear sway hitting my exhaust!
  7. shock civic 03' fit on rsx type-s 04'?
  8. Tokico blues and stock springs install help plz!!!
  9. suspension help HFP
  10. suspenstion questions
  11. Should i go with s-techs and tokicos or oem springs with tokicos???
  12. What are the specs(not height) for eibach pro kit?
  13. Adjusting rear Koni's (no, not about the metal piece)
  14. Anyone know what the stock height of the civic was?
  15. Suspension set up
  16. camber adjustment help
  17. Eibach Help Please
  18. rear is lifted
  19. STS/track suspension is done, small things missing
  20. Struts/Rattling (Warranty?)
  21. I'm going to freaking kill myself!!
  22. Camber Kit question
  23. New suspention= shitty popping...
  24. shocks to make car even lower?
  25. What brand and what combo to go with???
  26. almost done.......need help.
  27. my gc/tokico setup is making noise!! help!
  28. $50 is a steal for these Lowering Springs ?
  29. Troubleshooting Coilover Problem
  30. alignment question
  31. Spacer for rear springs?
  32. Question W/Tein Springs And New Struts???
  33. what to lower car to 1 finger or less gap.
  34. Ksport Camber Question (Calling all Ksport owners)
  35. why do I have to adjust camber every 6 months?????
  36. blues + s tech pics?
  37. installing springs/struts
  38. Auto-x Help And Setup
  39. strut question for those who have rsx-s 5 lug swap
  40. Neuspeed Race Springs with what Shock to use?
  41. GROUND CONTROL + OEM/TOKICO STRUT -> Koni yellow upgrade???
  42. New Front Lower control arms
  43. edit
  44. coil over or new shocks with s techs
  45. Neuspeed strut bar making noise?
  46. straight steering wheel
  47. question bout dropping my car
  48. SRR Purple LCA
  49. Autox/Track Alignment
  50. S tech drop -1.6" all around?
  51. creeking sound in front end of 2003 civic si
  52. 02 civic suspention lowered BANGING???
  53. Suspension creaking but only when car is cold [*Fixed*]
  54. Sportline & HFP Aerokit with 14" wheels?
  55. Thinking about buying Ksport? Read this first.
  56. I need help on civic 01 gc
  57. do this suspensio fit my 02 civic
  58. quick question
  59. help on puttin suspension on 18"
  60. edit
  61. suspension issues
  62. retuning my suspension... suspension gurus needed
  63. camber kit
  64. Suspension Question...Please Help!!!
  65. Hi, quick question
  66. so when do springs sag
  67. Better results?
  68. Brand Of These Coilovers????
  69. Lowering my 04 Civic EX
  70. pic request for s techs with blues on 17 rims
  71. Pic Request Of S. Tech w/99-00 Si wheels..
  72. do i need....?
  73. back to stock
  74. Ksports: Springs still binding. UPDATE: Possible solution, see post #12
  75. question? sway bar
  76. AutoX Set Up Help
  77. Mixing Shocks?
  78. Coilover spring binding and sound fix!
  79. edit
  80. Any One Deal Tein Suspension???????
  81. Need lil info. about suspension..
  82. Alignment effect on steering responce
  83. ***Help with front tie rod ends***
  84. 01 civc 4 door drop sugestions
  85. springs and shocks
  86. front lower control arm bushings same as rsx?
  87. Will 03 1.7EL supension fit on 03 Civic coupe?
  88. D2 End Links!
  89. Rear Suspension Help!
  90. clutch and flywheel
  91. 02 RSX on 03 EM2?
  92. To TEIN ss users
  93. found a problem searching couldnt fix
  94. I need Everyones Advice - Lowering My Vehicle - Check it out
  95. Eibach Sportlines
  96. Skunk2 lower tie bar
  97. Need help.....
  98. Sway Bar Specs has been updated!
  99. Front LCA Compliance Bushing
  100. Anyone have stock bushing failure? Like ALL of them......
  101. Jdm Coil Overs
  102. Coilovers?????
  103. need help, which springs?
  104. Will Si springs fit?
  105. Looking to buy new shocks/struts for my EP
  106. i need stock suspension asap
  107. SKUNK2 Lower Control Arms Installed!
  108. civic drop question
  109. megan racing problem
  110. *****dezod SUSPENSION*****
  111. Megan Racing Sqeaky back! Help!!! Updated!
  112. Tein Pillowball Top Mounts
  113. werid spring noise in rear
  114. how long do coilovers last
  115. do i need a drop
  116. Steering Rack Options
  117. H&R, Eibach, & Tein
  118. suspension is going...
  119. Kind of a stupid question?
  120. Ground Control Coilvers! Help! Can't Raise the Rear!
  121. Which coilovers? Tein SS-P or Flex?
  122. springs or coilovers? - newb question
  123. Am I having Strut Problem?
  124. Measuring the front struts? v.50or55mm
  125. Monroe Shocks and Strutts?
  126. energy suspension LCA bushings...
  127. Advice needed on suspension...
  128. Return car to stock height
  129. Koni Sport Kit ?'s
  130. Bilstein sport struts review
  131. tokico hp
  132. Strut install ....now popping noise!!
  133. Name brand vs Generic Strut bars
  134. Doeas RSX Front sway bar fit 2001 EX ?
  135. Megan Coilover height adjustment Help
  136. popping sound
  137. new strut bar installed
  138. Mugen Coilovers
  139. Koni Issue
  140. Squeek/Crunk Noises in Passenger Rear
  141. So who has experimented with aerodynamics?
  142. A bunch of problems w/ Tein lowering springs on stock struts
  143. check this out
  144. question about coil over sleeves...
  145. Blown B+G's
  146. 2003 stock suspension question
  147. Eibach Pro Kit, Lowering Coil Springs
  148. Am I missing anything when install a 19mm RSX rearsway bar?
  149. Skunk 2 Coilovers
  150. Tein Flex
  151. Skunk2 full coilovers - not sleeved!
  152. aftermarket shocks for my car
  153. Tein Basic, SS, SS-P, Flex users... chime in!
  154. is this a decent deal
  155. re: squeaking noise on rear suspension..
  156. Mugen hardened steering rack bushings for the DC5
  157. Anybody tried NEX Coilovers?
  158. goodies from tanabe
  159. Sway bar/strut bars
  160. Bilstein vs. D-Spec on stock springs
  161. D-Spec, which sleeves fit?
  162. Monroe And Tokico Shocks?????
  163. Megan Springs..
  164. Strut bar to fit over intake
  165. Strut bar to fit over intake
  166. passenger side higher than driver side?
  167. Eibach Pro-Street Coilover Kit #: 4051.711 (2001 & 2002)
  168. Underdrive pulley belt size
  169. Dropzone struts/springs
  170. help/coil spring spacer
  171. Ground Controls with AGX
  172. Megan or D2 Coilovers?
  173. 7th gen ball joint DIY
  174. Eibach springs/Tokico HP Shocks Upgrade
  175. Inner Tie Rod
  176. bump stop
  177. Are civic and RSX trailing arms interchangable?
  178. Squeaking Noise From My Suspension
  179. Need helo from anyone who owns any Tein Full-Coilovers
  180. KYB GR-2s or tokiko blues
  181. coil-over shock thrust bearing
  182. help! progress front sway bracket broken--again!
  183. Where to buy Tokico HP's for my '02 EX
  184. Got My list installed
  185. Rear sway bar endlinks question
  186. 02 coupe lowering questions
  187. Camber Kit.. Bolts.. Front Rear?
  188. Pro-Kit v.s. H&R Sports
  189. Susp. Question Help LOOK
  190. Rear suspension noise
  191. plastic bushing on rear needed?
  192. What Do I Need For A 5lug Conversion?
  193. Question About My Ride Rubbing???
  194. Bolt size of bottom strut
  195. Shock question
  196. Rear camber kit.
  197. dose anyone have 03 ex lower control arms???
  198. control arms
  199. Rubber Piece Between Springs Torn
  200. how to adjust rear toe?
  201. air ride camber question
  202. spring question
  203. Coilover's vs Springs/struts
  204. front sway bushing size?
  205. Camber kits
  206. Dropping the ride...
  207. Suspension Question ( Coupe & Sedan )...
  208. RSX Suspension Compatible with Civic Sedan?
  209. Squeeking noise in rear strut
  210. Suspension ?
  211. Tein S.Tech lowering springs question
  212. Need some help suspension i'm assuming
  213. 8th gen steering wheel
  214. Need some help
  215. Tokico Blue Installation
  216. Tokico Blue V.S. KYB GR-2 Question???
  217. Tokico Blues + Tanabe DF210's
  218. Need New Suspension I think?
  219. Lowered at different heights.
  220. Little advice needed
  221. Sitting at 83k miles. Do I need shocks/struts and what are the best?
  222. Alignment specs.
  223. Droping the ride
  224. Is there a diff when it comes to ball joints?
  225. Lug Swapping?
  226. Front and Rear Strut Bars
  227. ek strut bar??
  228. Slightly suspension retarded
  229. 01 LX Rear Sway Endlinks....NEEDED!
  230. Topping out.
  231. Struts for 2001 Acura 1.7 EL Front Struts - Where and What to Buy
  232. How to make it handle like its on Rails?
  233. Looking for a better ride
  234. Neuspeed front strut bar problem
  235. ....listen to this...
  236. 2001 Honda civic plastic strut bearing question! please help!
  237. coilover question. seasons.
  238. Lower control arm question
  239. Progress Springs, Tein S Tech's, H&R Springs
  240. function form (f2) coilovers
  241. Tein H Tech Springs
  242. Creeking sound coming from the front
  243. Skunk2 Coilover Spring paired with Tokico Blue's
  244. Need Help On Diy Installation!
  245. Rear Sway Bar Question..
  246. Tokico Blues
  247. good drop for DD
  248. pros, cons, and opinions please
  249. opinions??
  250. camber kit
