- nuespeed tiebars, somethings not right
- Front Upper Strut bolt question (for all diy'ers)
- DC5 Front Strut bar in EM2...
- Questions about GC's and Tokico HP
- Eibach spring went bad, getting a new set sent tommorrow
- Suspension experts HELP please. Wheel alignment issue
- shocks or springs makes noise
- BEst 1inch Drop
- Neuspeed strut bar
- ppl with the DCsports upper front strut bar
- Tokico HP/Blues Finally out for 03-05
- Worth it?
- question
- Steering wheel shakes at speed
- Koni Yellows
- hey need advice
- eibach sportlines
- What parts for replacing tie rod ends?
- struts, shocks,srings
- RSX rear sway bar
- newbi with aem2
- Springs Front:a little Lower) than the back
- 25mm front sway question!!!
- who makes strut mounts for our cars?
- SS Teins Blown Shock!
- skunk2 coilover kit
- Weird noise..suspension or bearings problem??
- stripped bolt
- Unidentified Shocks
- question about new springs
- Camber kit from Megan Racing
- Koni Sport Kit or just the shocks???
- Lowering question
- Part # for EM2 swaybar
- Feel a big difference w or w/o strut tower brace?
- k-sports or megan coilovers
- skunk2 racing coilover kit
- LCAs questions
- fast help gc's and o4 ex..
- Reviews on bilstein shocks?
- Beefier Tie Rod End?
- strut question
- opinions and thoughts please
- swaybar combo question.
- Energy Suspension Bushing..
- Need for "Stiffy" w/ ES Bushings?
- Ball Joint? Or Tie Rod End?
- 05 upper strut measurement
- drop setup
- New Old Konis
- 02-06 Rsx J's Racing Adjustable Ball Joints
- form and function coilovers
- Why Is My Rear Saggin So Much?
- popping sound while turning steering wheel
- Need some help.
- Could I replace 01 civic sedan upper strut mount with an 03-05
- real world practical?
- jacking point after installing nuespeed rear tie bar
- D-spec for 05?
- had u ever thought? intereting issue...
- Best 2.0-2.5'' Drop
- Koni Yellows?
- Setup???
- Civic Suspension Makeover!
- coming to a sudden stop..
- rockin 5 lug dc5r brembos on my es1
- Calling all Ksport Coilover Owners!
- isntallng camber bolts
- Smart move?
- eibach springs
- suspension problems
- what do you guys think???
- coilover question
- New Member Needing Help
- Right front Tein SS shock blew... What to do?
- suspension question?
- Lowering springs solve the problem?
- megan racing strut bar question
- suspension
- Tein S. Tech springs question
- Installing springs/ knocking sound
- opinions
- Tie Rod End. HELP!
- Tie Rod End question
- Tokico HP's on 04 Civic EX
- Noob lowering questions
- wut camber kit should i get??
- Tokico HP's
- megan coilover problem
- rubbing problem... any suggestions?
- DIY Alignment with Laser level?
- Best Lowering Height
- Tokico HP's not out??
- Any1 w/ rsx Carbing lower arm bar?
- I was just readin around
- K-sport coilovers- lower mount UPGRADE?
- noisy rear end, driving me crazy!!!
- Tein Basics
- 2 coilover questions
- Tie rod question
- tires rub
- DIY Koni/Ground Control
- Suspension is totally shot...
- i got a question about lowering springs
- help me out.
- 5 lug swap
- how low does the OEM front aero lip go?
- Will Tokico D-Specs fit a 4 dr
- Tanabe DF210?
- b+g coilvers or ksport which to buy?`
- S-Tech sag??
- --Skunk2--
- eiback pro kit
- coilovers?
- Sway bar?
- -Need Help!
- Which Coilover system?????
- Those with Koni shocks.... How do you adjust the rear damper?
- What do you think about this springs?
- Alignment problem ...
- 01-05 ground controls??
- Strut bar (Front and Rear)
- Why!!!!!!!!
- H&R or Goldline springs?
- How good is this setup I just got,
- swaybars on 04 vp
- weird noise help..
- my findings: why hotchkis plates will not work with koni yellows
- Doesa anyone not have a camber kit?
- Will Ep3 B/c N+ Fit On A 03 Em2? Need Help!
- Dropzones or Tokico BluesWHich would u get?
- What Upper strut tower brace to use?
- need help on a part
- 05 Civic Ex Rear Strut Bar ,want One But Who Offers.
- DC Strut Bar
- Help w/ located neuspeed strutbar in Canada
- Found some aftermarket Tie Rod Boots. Will they work?
- Did I get ripped off?
- F2 Suspension?
- Another Coilover question
- Sportlines & Dspecs
- Will Ground Controls Fit On Tokico Hp For 03 Em2?
- Coilover Fitment Problem
- PPL with Tein SS, Please chime in!
- How are you set up, and how does it drive?
- Tockico Shocks + OEM Springs
- Need an answer before i make a purchase
- question about front/rear strut bars
- Help on Skunk2 coilovers
- its time for a new suspension...but whats good these days
- Tein Basic...how low can you go???
- Tie Rod Ends?!?
- 2002 si suspension
- My Front right LCA SNapped
- People with Tokico Blues, How is the ride quality?
- neuspeed race springs on kyb gr2's??
- bushing replacement cost $250.00 ??
- fyi-rear suspension squeak
- My Rear Tire Is Rubbing Why?
- Question about full coilover
- suspension noise
- automatic axles
- Civic coils with rsx hub?
- Wheel studs???
- DC5 type R springs on 01 civic sedan..
- Spc
- Rough ride - whats wrong?
- neuspeed x-brace
- Problems after DIY shock install, help?
- Coilover Nut Backing Out Help?
- need to redo suspension and pads? recomends?
- Tein Help Quick!!!! Lot Of Pictures
- How far can I drive without an allignment?
- Leaking Struts
- Replace front shocks - NO drop
- Eibach ProKit and Tokico D-Specs Installed
- Can't decide on suspension
- Coilover Question....
- HELP: Ripped TieRod End Boot = Bad Alignment???
- Best Coilover (sleeve) and shock setup
- lowering... what exactly do i need?
- haya coils
- Kw Coilovers from 04 on an 01???
- how much negative camber will i get w/ a 0.8" drop? (tein h.tech)
- new shocks?
- Will Tein Flex from Civic fit RSX
- car in hit and run
- HELP!! Which coilovers can have stock appearance?
- 02 civic si Aqua Greenish Blue Springs
- B&G coilover problem
- eibach sportlines please help!!!!
- cheap place to buy neuspeed strut bar
- New Motor Mounts From Oem Or Modified Ones????
- Scraping on my new suspension
- All The Suspension Info You Need!! Please Read!!!
- D-spec/HTS for 03-05
- parts for Honda civic 02 EP hatch
- Has anyone tried the ebay underbrace?
- neuspeed race springs on 99 si stock 15's???
- Neuspeed Strut Bar question
- Sleeved Lowering SPring Question.
- Reducing Body Roll...Help?
- Ball joints
- Possibly have strut issues... ideas on replacements and upgrades!
- Going back to stock sway bar
- Recommended Weekend Warrior Coilover Kit for 2005 EX Sedan
- What to do Suspension wise..
- Lowering a stock civic NEED HELP!
- Sedan Springs-HELP!!!
- Tein basic coilovers and Top mount bearing
- HELP!! ONE side of my car is lower than the other
- Tein H-Tech tons of rear sag..WTF?
- Goldline Springs?
- Please help me figure this problem out!
- Rear upper strut bar....help?
- Need some SERIOUS help.
- Installed RSX rear sway but some noise
- Advice Needed, Going to Track Day
- 2004 Sedan Civic EX Shocks/Strts ok on 2001 Sedan Civic LX?
- that suspension prob!!!! help me out!!!
- Question before I install my springs
- traction bar
- Popping Noises Fixed!!!
- Mixing Eibach springs.need advice..pls
- awesome new deal!!!
- Coilover help
- tein s tech on 01 2dr
- Tein project turning into a 2-3 weeker
- Why my coil move???
- Help need suggestions
- Random Suspension opinion
- finished the drop... new pic added
- Springs&Shocks Questions
- Used Coilovers????
- Ksport - Spring Rate Choice Need Input
- help with tien
- Are there any pieces missing to these Tein SS coilovers ????
- Lowering my car, NEED HELP!!!!
- skunk2
- Need a lil info
- requesting pics of Tein S Tech springs on car
- Fixing the camber: alignment or camber kit(pillowball mount)??
- Matched Spring / Shock kits (Koni, H&R)
- why coil overs?
- Very Bouncy Ride. What to Do?
- Mügen--->>HELP!!
- A simple spring question.
- HUGE problems installing springs stripped ahh
- Need help with Spring install!
- opinions...
