View Full Version : Suspension Performance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30
  1. ok alignment stuff
  2. coil over?
  3. 2001 LX. Does it have a rear sway stock?
  4. need help pickout out shocks
  5. 01 GCs on 88 REX?
  6. Megan, plus a question for those w/ RSX Tie rod ends...
  7. my rear is one side higher than the other?!
  8. Tein Basics camber adjustment?
  9. 01 Civic Camber Help
  10. tein clunking fix?
  11. pains of a lowered car
  12. rsx rear sway
  13. air ride for daily use...
  14. installing konis
  15. Omni Full Coilovers Sports (01+ Civic)
  16. People with Neuspeed Sports and Tokico Blues!!
  17. Eibach's and Koni's too high in the front?
  18. Question for you wheel experts...
  19. K-Swappers w/ x brace?
  20. my air ride videos
  21. questions about dezods kits
  22. I Need Major Help Please!!
  23. An Alignment Question *UPDATE post 12*
  24. Post-install spring popping noises
  25. Cutting eibach's??
  26. Rims... no drop?... confused!
  27. Which Shocks/struts To Get For My Skunk2 Coilovers?
  28. Bilstein Struts/Shocks - Update (very long)
  29. Sway bar
  30. Progress Sway Bars And Tanabe X Brace
  31. RSX control Arms fit?
  32. shock/strut ?
  33. Neuspeed Strut Bar and Fujita F5 Cold Air Intake
  34. question
  35. K-mac time!
  36. Lowering with D2 Full Coilovers (for those with D2 Coilovers)
  37. Megan Front upper/rear upper strut bars [noob]
  38. Help Please...!
  39. Hey Guys !! Help The Noob From Montreal :d
  40. spirngs from other gen?
  41. Question about B&G Coilovers
  42. Shock boot for rear coilover?
  43. Comfort Ride / Resistant Shock
  44. 03' rsx and 01' civic suspension: same or different?
  45. Will 04 stock springs and shocks fit on 01?
  46. Got my springs on today!
  47. Springs without shocks?
  48. Coilover Problems! Help plz!
  49. BuddyClub Suspension!
  50. People with neuspeed sports
  51. WTF is wrong? Steering wheel shimmy....
  52. Alignment - cost vs quality.
  53. issues with stock suspension dynamics on wider tires
  54. Squeeking noise when bouncing front end
  55. 4 new tires - Getting crazy shake at 100kph
  56. ****technical question on shocks****
  57. help-suspension problem
  58. Skunk2 Camber Kit fit?
  59. Megan rear upper strut
  60. ? Energy suspension in front control arm?
  61. Tein Spring Fraud Alert
  62. Issue with Progress Bar
  63. how much should i drop my civ?
  64. 01 coilovers in 05
  65. Need the part #
  66. Changes with tokico struts w/stock spring
  67. My Tokico Blue Install...
  68. Megan upper strut bar rattling
  69. Crashbolt 50mm or 55mm?
  70. Tie Bar Template
  71. Lowering Spring Experts Needed !!!
  72. Coilover Sleeves?!?
  73. Most comforable suspension for 01 vic, but still real low...?
  74. WARNING!! counterfeit Tein Springs
  75. 5 lug conversion help please.
  76. 02 Ground Controls/ Tokico Blues
  77. D2 Suspension better than hayames?!
  78. Need Help
  79. RSX trailing arm
  80. Air cylinders
  81. certain torque for nuts/bolts?
  82. Strut bearing plate.
  83. noob alert lol
  84. Coilover ???
  85. RS*R Springs (01-04 Civic) experience?
  86. Where can I get progress rear tie bar from?
  87. Neuspeed Race Springs roll call.
  88. Koni yellow's + GC
  89. question??
  90. MIR Lowering Spring?
  91. how to get access to rear shocks so it can be adjusted??
  92. New Dampers on a Budget
  93. What you can do with air ride on your 7th gen
  94. Air ride on ebay..is it legit?
  95. Kazera StreetSport Springs.. A good deal or bad idea?
  96. Pounding Noise When Turning.
  97. just front camber kit
  98. stock spring rate
  99. Rear stabilizer bar issues
  100. Why won't these work on my 2004??
  101. tokiko d spec adjustable
  102. 4/18*UPDATED W/PICS*Rear strut assembly...???
  103. Questions on rear sway bar
  104. Looking for Bump Stoppers for Shocks PLEASE HELP
  105. Got another set of TEIN's for free.....PIC now.
  106. Possible to use 2 different types of springs on same car?
  107. C-Pillar Bar
  108. Greasing for Clunking
  109. PLZ HELP!! Non-Rebounding Shocks??
  110. **Need Help**
  111. I Need F&r Camber But Which Brand To Get?
  112. camber plate vs camber bolts
  113. Will RSX struts fit an '02????
  114. Are upper pillowball mounts universal?
  115. 2005 Civic Suspension options
  116. Anti-Rust Agent for Endlinks
  117. Neuspeed Upper Strut Bar
  118. front is not low enough
  119. to those who have tein ss
  120. want to tuck 205/50/15 what are my options?
  121. bought koni's, and ground controls
  122. Wife's suspension review Tokico Blue / HR Sport
  123. Air suspension questions..... :)
  124. Hotchkis F & R endlinks
  125. Acura RSX Rear Sway Bar Part # and Site
  126. dropzone strut/sleeved coilover combo any good?
  127. tein basic damper for 7th gens
  128. Megan coilover
  129. Better than stock??
  130. Is this info right?
  131. "Performance" lower control arm - stock?
  132. 02-03 rsx skunk 2 coilovers fit 04-05 civic?
  133. Tokico/Tein S.Tech
  134. anyone on here has gc + koni?
  135. Noisy OEM suspension, complain to Honda or replace?
  136. knockin springs???
  137. Noise After Installing Progress Front Bar
  138. EP3 tokicos on an 04 EM2??
  139. what would be the best for....
  140. How much is this car lowered? (updated)
  141. GC Coilover Question
  142. Which Neuspeed springs
  143. stuck threads
  144. 02 si and 02 ex?
  145. ?????anyone have creaky springs??????
  146. loud clank noise from koni's
  147. what height should i ride at?
  148. strut question
  149. rear lower tie bar
  150. going in for an alignment, what should i be aware of?
  151. neuspeed rear lower tie bar anyone have pics?
  152. SI suspension on a sedan
  153. Noisy Suspension HELP
  154. eibach anti roll bars 26 and 16 mm, why?
  155. Sedan Finally Dropped w/ Pictures
  156. alignment problem in back right rear but car is not dropped...
  157. anyone with HFP upgrade struts and springs?
  158. Need help...ground control owner
  159. Can you modify "THIS" to fit an 01 civic?!
  160. Looking for an EVERYDAY driver suspension? (come on in!)
  161. Lowering springs on a hybrid?
  162. Indexing Question on a 01' sedan
  163. Strut bar question
  164. 14mm fit 16mm
  165. rear stabalizer links and bar bushings?
  166. what goes lower:B&G, Omni Power or Progress?
  167. tein SS ordering?
  168. koni warranty
  169. rear control arm
  170. sway bar question
  171. Suspension Hopping
  172. Eibach Sportline On A 2002 EX?
  173. Tokico Struts and Neuspeed Race???
  174. can rsx susp fit 03 ex coupes?
  175. Is $200 A Good Price To Install This?
  176. skunk2 coilovers with tokico blues problems
  177. Suspension Nightmare, Wtf?
  178. Anybody Around Canton, Akron, Massillon Ohio?
  179. Tokico D-Spec Shock & Spring Sedan Set?
  180. neuspeed race with koni yellows
  181. Need Help on Camber Kits
  182. should i go with this rear upper strut bar?
  183. koni yellow oil leak *pics inside*
  184. Steering problem...
  185. B&G lowering springs???
  186. Suspension... am i being overly stupid
  187. guys i need help
  188. What should i get ?
  189. Picture Of My Ride After Prokit Springs
  190. Ground contorl owner...I need help again
  191. lowering question
  192. tuning the coilover...
  193. Front camber bolt
  194. same set up different results..
  195. I Just Got My Car From My Boys Shop (UPDATED 5/23)
  196. upper strut bar questions
  197. DC5R brembo brake conversion on EM2
  198. Question on Drop Cars
  199. how come noone can answer this freakin question!!!
  200. RSX-Civic Sway Bar Swap
  201. how huch can i drop without problems
  202. Buying Tokico Blues
  203. eibach sportline kit...need spring compressor?
  204. +1.5 degrees camber
  205. Huge popping issues (Not due to indexing)
  206. i don't want a bumpy ride. which suspension?
  207. 2nd time on here so please answer. thanks
  208. please give me some advise on buying shock
  209. 2002 ex sedan koni yellow fitment question..
  210. need some help before installation
  211. New suspension setup!
  212. FAKE TIENS !!! becareful !!
  213. will the GC koni work with stock front struts?
  214. Tokico HP blues shock Question!!
  215. question? on tokico
  216. When???? (ETA any1?!)...
  217. Please Help Me.... (Suspension Problem)
  218. Whats the thickest rear swaybar for our cars???
  219. shocks
  220. camber kit
  221. Does anybody have ... ?
  222. suspension issue; wobble/shake
  223. edit: delete thread
  224. Squeeky rear all of a sudden?
  225. anyone running tokico springs???
  226. difference between Tokico Hp and D-spec
  227. shock that can handle a low drop under $400
  228. Lowering issue...
  229. HELP *just installed teins basics*
  230. tire size
  231. Anyone With Neuspeed Strut Bar Pics??
  232. Dz Springs
  233. got these in the mail today
  234. Car Tilting to Side!!
  235. Front Sway NOISE is BACK. AGAIN. Opinions needed.
  236. Why is my TCS exhaust hitting my OEM sway?
  237. spring orientation
  238. question about progess sway+tie bar combo
  239. Hotchkis F&R Endlinks..installed!
  240. Understeer, how to fix?
  241. Is it worth the extra $200?
  242. Honda Civic 2002 DX Lower ball joints front?
  243. Tein and Tie rod problem, Urgent
  244. Tein looking for an ES1 for R&D
  245. 215/45/17 Kuhmo Ecsta 711's $240 For 4 Shipped ($60 Each)
  246. need an answer asap! anyone know the STOCK/OEM camber adjustments?
  247. MR Coilover or Tokico D-Spec
  248. Need Help Fast, I Think I Popped My Axel
  249. I'm going Pro
  250. ball bearings
