View Full Version : Suspension Performance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30
  1. Camber Kit
  2. installed the RSX sway, have some issues now
  3. Does this thing work?
  4. lowering help~
  5. Shocks help
  6. TOKICO HP STRUTS SHOCKS for 02 civic coupe
  7. Hurting Story
  8. Quick almost retarded question
  9. Suspension Problem Question?
  10. Suspension for everyday
  11. ***Want to lower more, will I have problems***
  12. Progress Coilovers installed!
  13. pics not shown up in the sticky
  14. Can the stock bolts be used on tokicos?
  15. 99 civic fit 03 civic
  16. why are my sides different height?
  17. Tokico shocks and Stock springs....anybody?
  18. RSX-S Rear Sway Review, need input
  19. lowered car rant thread...
  20. urgent ! RSX springs on 03 civic
  21. HELP: steering wheel is creaks while turning
  22. RSX suspension on civic ( sry ! again ! urgent..)
  23. alignment specs from hydroplaning to curb....
  24. My left strut is leaking
  25. TEIN Front upper Strut bar
  26. Anybody that has lowering springs
  27. Strut Bars
  28. need opinion
  29. Function 7 LCR ..... when did these come out
  30. Difference between EP3 and ES1 tein SS? INSTALLED EP3 KIT!!!
  31. polyurethane suspension bushings?
  32. carbing ep3 & dc5 bars !!
  33. Eibach Prokit Part #
  34. I apologize in advance !
  35. progressive spring
  36. Camber Bolts
  37. 8thgen suspension the same as ours?
  38. honda Oem sway bars...
  39. Tein ss vs. Tein flex
  40. Tein ss in winter....is it good or not ????
  41. rsx sway on a 01 DX coupe (canadian model)
  42. KYB AGX or Tokico DSPEC
  43. a little help please
  44. Great News!
  45. ? on 03 civic and rsx front springs
  46. Cleaning Tien SS CoilOver
  47. 16mm drillout 03+ = only on front, correct ?
  48. ground control coilovers
  49. Tokico Hp
  50. i only want a 1 inch drop
  51. AWD Conversion
  52. Eibach Sportline Springs
  53. Dumb Question (Cuz im dumb)
  54. Help plz. How long till i can get an alignment after i raise it?
  55. how logn do springs last
  56. 02 euro type-r EP3 rear sway for my 01 sedan euro es (ex)
  57. pics of carbing bars installed !!
  58. These alignment specs alright?
  59. I found yet another brand of coilovers!
  60. Tokico HP's
  61. how do you adjust the Ground Control Coilovers?
  62. sugestions for suspension setup
  63. sdfs
  64. Can I Use Oem Springs With Tokico Shocks?
  65. neuspeed race, sport,(tein s-tech) for 18x7 with 205/40/18
  66. tein s-tech to neuspeed....need advice
  67. Strut bars: Solid piece vs adjustable
  68. Tokico blues/H&r's
  69. GC coilovers wont lower in front.
  70. 17's & rubbing HELP
  71. GC's w/ DSPECs or AGXs??
  72. Looking at redoing my front and rear sway bars? Need some help on how to install?
  73. Which coilover setup?
  74. 2001 Civic pple with aftermarket
  75. v2 intake and stut bars
  76. RSX: Type s or Type r Sway bars
  77. I Need Help
  78. camber plate and springs question
  79. Any 04-05 Civic on KW suspension?
  80. How Do I Know When My Shocks Are Blown?
  81. B&G suspension reviews???
  82. camber kits - suggestions & walk through
  83. Price of replacing front struts
  84. springs..
  85. camber kit brand ?'s....spc/ingalls/st/sre/...
  86. OEM Springs Install
  87. rsx suspension for em2
  88. anyone have exprence with tanabe springs
  89. drop on springs before shock replacement?
  90. Spring suggestions please?
  91. I think i need to index, not sure
  92. need help with shock replacement
  93. Shocking news..
  94. 55mm vs 50mm
  95. noice from megan racing coilovers
  96. Ep3 shock/struts with EM1 spring hybrid setup
  97. Help going back to stock springs
  98. Are Tein s-tech any good?
  99. Neuspeed or Eibach springs (need opinons)
  100. Caster problems...need your help
  101. Best Full Coilovers.
  102. rsx-s sway bar price?
  103. tenzo r
  104. what suspension should i get
  105. Strut problem again ???
  106. Tokico D-specs
  107. ew rims how much to raise
  108. strutbars
  109. which is better
  110. camber problem HELP. . .
  111. KYB AGX Adjustor SEIZED
  112. spring question
  113. Tokico HP - INFO HELP
  114. Different spring drop rates?
  115. Dude, WTF? (92 corolla DX)
  116. TOKICO competition coilover kits
  117. i want an honest answer on this one...
  118. tien or eibach?
  119. Alignment required with minor drop?
  120. ground control coilovers from 02 civic ex coupe
  121. Tein Basics question
  122. Members w/H&R springs and Eibach springs
  123. Progress rear sway bar on 01 lx (no factory sway bar)
  124. Hit a curb, hoping only have to replace the control arm
  125. finally droppin it, I need some info
  126. did a search.. cant find answer
  127. RSX Ground Controls on 01 Vic?
  128. Question for Pro Kit installation
  129. Suspension Techniques Front Sway Bar?
  130. neuspeed sportline/tokico struts/shocks
  131. Ground control lowering springs with stock struts
  132. has anyone tried megan springs yet?
  133. Stock EM2 01 uppermounts VS EP3 uppermounts
  134. front or rear camber??
  135. RSX rear sway and Honda Civic
  136. help me adjust rear spc arms to 0 camber w/o the guesswork!
  137. RSX Rear Springs on Sedan..anyone *actually* try it?
  138. Tein SS w/o pillowball upper mount
  139. carbing bar installed with pics
  140. Who rides on Konis? Need feedback.
  141. EL 1.7 2002 Suspension same as ??....
  142. ok im confused
  143. noob question
  144. installing a sway bar on an 01
  145. Anybody know anything about Tein basic coil overs
  146. lower control arms for 7thgen?
  147. Neuspeed rear sway vs. Progress
  148. Spring Question about stiffness in pounds
  149. Lesson Learned the HARD way
  150. NRG front strut?
  151. ground-control coilovers with stock struts 1.5" drop
  152. 5 lug conversion
  153. instaled dspec on stock springs
  154. strut bars
  155. who has drilled their tokicos
  156. stock suspension on an 01
  157. Shocks and Strut?
  158. got a ? about these
  159. so if i did my whole suspension how good would this be
  160. custom Poly-urethane?
  161. what is the best springs for a 2001 civic LX
  162. whats a good adjustable suspension springs and shocks for 2001 civic LX
  163. rsx engine damper on civic 01
  164. help with SHOCKS,SPRINGS,CAMBER KIT,RIMS.
  165. 2" too much on an 05 Civ Coupe?
  166. Any quality differences in blues vs. dspec
  167. tein s tech question
  168. Shocks for 04 Civic coupe
  169. Canuck Motorsports
  170. Euro em2/es1 coilovers - G-force suspension
  171. ohhh great
  172. just installed Tokico blues with H&R springs
  173. Tein SS vs. Tokico Blues and Neuspeed Sport Springs
  174. Rsx type s sway bar
  175. NEED HELP FAST Boilermaker1 or Zzyzx or anyone else that knows
  176. Progress rear sway bar tie kit, waiting waiting waiting!!!!
  177. Ground Controls w/ 19's
  178. problem with springs?
  179. Does anybody know??
  180. What broke this?
  181. adjustable springs
  182. Rear Sway bushing brackets
  183. Tokico's and Ground Control help
  184. help
  185. H&R springs
  186. spc camber kit
  187. replacing ball joints in the front
  188. Rear Springs Higher?
  189. dampening help needed
  190. what is an "o-ring" ?
  191. almost poo'd myself
  192. what kind of coilovers are these?
  193. Tech question on Tein Basics...
  194. can i fit civic ctr si ep3 ,,coilovers on ep2
  195. New shocks/struts, what to reuse vs replace? **UPDATE**
  196. Need help with new suspension configuration
  197. Installation of RSX sway bars HELP PLEASE
  198. HELP: slid into a curb, LCA bent? *pics*
  199. Front bushings, exact type/name?
  200. tein with koni
  201. hows this for a budget suspension setup...
  202. oem front sway
  203. megan coilovers please help
  204. Bilstein Struts/Shocks (Updated -very long)
  205. need help.
  206. suspension travel
  207. 2001 Civic - Problem with Front Struts (TSB needed)
  208. front passenger coilover
  209. progress springs..again
  210. rsx rear sway bar...bushings?
  211. Requesting pics of lowered cars
  212. koni yellow adjustable damper knobs
  213. AirRide Questions
  214. Poping noise...
  215. strut bar
  216. Silly question about dust cover over strut
  217. strut bar & intake - tight fit
  218. what sway bars should I get
  219. Which Suspension to get
  220. Accident
  221. Noob rear strut bar problem...did a search
  222. suspension help??
  223. RSX Coilovers on 01-05 civic?
  224. tokico suspension package (comes w/ springs..)
  225. question on ride height, why it may be different from right,left side of car
  226. tokico D-spec shock settings
  227. Question need answer.
  228. Skunk2 Springs 01-03
  229. eibach full coilover
  230. adjusting koni yellows
  231. ? for those with Megan and Tein basic full coilovers
  232. Stock sway bar
  233. creaking (like the sounds your grandmother's hips make) not popping
  234. wtf, i cant find any tokico blues
  235. tire rubbing
  236. koni yellows and skunk2 coilovers...still ride like crap
  237. EP3 front shock absorber same as 03-05 non si
  238. SPC camber kit
  239. Front Control arm Engery bushings
  240. EL struts fit Civic ???
  241. New goodies installed, (pic) some questions
  242. Passing some Knowlage.
  243. tein or prokit w/lip kit.....
  244. strut/sway bars
  245. question
  246. adjustable springs....
  247. new guy on the forum with some questions
  248. Major problem with GC coilovers and Tokico Blues
  249. springs installed, but..
  250. any springs?
