View Full Version : Wheels,Tires & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27]
  1. Powerslot rotor + HAWK pad combo *truehonda*
  2. tires
  3. stock brake problem
  4. downer
  5. Lug Key with Torque Wrench = Bad?
  6. Tire and wheel help
  7. New Brakes, Rotors, and Tires
  8. brakes and clutch odd when cold
  9. Recommended tires for STOCK 2001 EX Steelies
  10. Almost time for brakes
  11. Weak Brakes on my 2005 SI Hatchback?
  12. Rim Recommendations PLEASE!
  13. Help with rear disk conversion?
  14. Accidently drove with e-brake
  15. What rotors to get???
  16. Rear Disk E-Brake Cable Problem
  17. 225/45/17 on 17x7 +42 offset?
  18. tire size for 16 inch work rszr???
  19. New Rims with Rubber!!!
  20. TE37..what color>?
  21. bolts under fenderwell
  22. Wheel & Tire package
  23. Center Caps
  24. Out of Control!!
  25. brake lines......hard lines
  26. Offset with DC5R brakes
  27. Hawk HT10 pads for street?
  28. Bridgestone Blizzak WS-60
  29. DIY Brake Pad Install
  30. 185/65/15 or 195/60/15?
  31. 7th generation stock 2007 EX wheel weight?
  32. Firenza ST03
  33. Brembo 4 discs
  34. Does anyone have pics of 15" rims on a non-lowered Civic?
  35. Quick question
  36. Different brake pads for '02 vs. '03?
  37. Yay or Nay
  38. Enkei GF1's????
  39. Anyone have pics whit 205/50/15 and 195/55/15 lowered?
  40. Hawk HP+
  41. Falken Ziex Ze-912's or Kumho Ecsta ASX?
  42. Tire sizes for 16 inch tires (search did not yield anything)
  43. Giovanna Or Gianelle??
  44. 15 x7.5 need or no need for spacer
  45. Rear Right Brake Noise
  46. Toyo proxes 4 vs. Yokohama Prada spec-2
  47. New Tires + Rim Size Confusion Help
  48. question about rim sizes
  49. 5zigen Fireball? Help!
  50. Tenzo dc-6
  51. Front Brake Squeeky Noises
  52. oem brake pads
  53. 2001 civic lx sedan on 18's what tire size
  54. anyone have these rims on their ride?
  55. 3 Tire choices!!! ALL opinions appreciated...
  56. Tire suggestion??
  57. my new Brake setup, my stops just got lighter, cooler and stylish
  58. 215/35/18 in the front and 215/40/18 in the back?
  59. Problem driving straight? (at times)
  60. stock calipers/break pads with aftermarket rotors?
  61. Front Brakes and Rotors
  62. Need advice for new rims
  63. Would these rims look right on my car
  64. Will It Fit?
  65. ASA -AR2 OR Motegi SP10's ?
  66. brake fade
  67. Need some help in rim size
  68. tire size for 17x7....updated
  69. 01 coupe with 17 wheels vibration and gas mileage
  70. 2001 civc ex wheels
  71. need help with choosing new offset and fit
  72. help me with me D17A2
  73. Rotors and Calipers Q?
  74. Thread pitch
  75. Which tire size???
  76. Bigger rims overstating true reading?
  77. 2007 Honda Fit Sport 15" wheels fit?
  78. New to rim/tire buying - few questions
  79. Question about tire size
  80. 16" Konig GT-R
  81. How to fix Curb Rash
  82. install on extended wheel studs
  83. 15" rim + tire combo recommendation?
  84. Would These Fit Our Civic? Big Lip.
  85. Rim Help
  86. help me with me D15b
  87. +33 Offset, Will it fit?
  88. Which tires to get?
  89. reccomend me some new brakes
  90. Question about the right tires and Rims
  91. Enkei wheels?
  92. Confirmation on 2002 Acura EL / Civic Si Brake Torque Specs
  93. Hawk HPS Brake Pads vs EBC Ultimax Brake Pads
  94. help with tire width and type?
  95. brake noise (metal on metal)
  96. 8th Gen Wheels on 7th Gen
  97. pads for drilled & slotted rotors???
  98. 17X7 +45 offset?
  99. Dashboard ABS and Brake light.. how do they work together?
  100. Winter is a coming! Which one?
  101. torque wrenches worth it?
  102. Did front brakes last night and now have a problem
  103. 17x7 +40 offset
  104. what do you think?
  105. Clean and adjust rear brakes for 2005 Civic sedan?
  106. Rims Basics
  107. Nitto NeoGen ZR, comments?
  108. wheel lug question
  109. scuffed my lip
  110. Hawk HP Plus brake noise
  111. si rims?
  112. Time for a change
  113. Winter Tires
  114. type r brake swap
  115. Magnum Rotors
  116. quick tire question
  117. Maximum Section Width (for a stock wheel well)
  118. what do you people think about the buddy club P1sf's
  119. Boring out a center hole in a wheel
  120. 2005 dc5r brake swap = JDM FD2 18" CIVIC TYPE R rims
  121. looking for rims
  122. civic wheels and tires
  123. Confused About Rims
  124. OEM brake life lasts longer than 80kmi
  125. 02 rsx-s brakes on 01 civic
  126. tire size ?
  127. who's running HFP 16" rims?(EP-5 or SS-7)
  128. Which Rims?
  129. New wheel choices....need input
  130. can i slam with these rims????????
  131. tire stretching???????
  132. personal dilemma ???????????
  133. biggest tire on 18inch wheel
  134. Hubcentric rings help!!!
  135. Will this Acura rim fit on 02 Civic
  136. Just got rims installed!!!!
  137. 94 EX- What size rotors?
  138. How long should they last?
  139. Weird ABS operation or is this normal?
  140. Help on proper tire pressure for 245/45ZR/17
  141. HAWK HPS brake pads
  142. Anyone tucking tire with 18s?
  143. Rotor replacement
  144. Tires & Rims for a 2002 Civic EX-what fits ?
  145. Who's running BBK?
  146. brake question
  147. 35mm offset
  148. why are rims so expensive
  149. New member, Wants wheels
  150. Will 18s fit our cars ?
  151. how many lugs
  152. 5 lug conversion without swap parts list and modifications
  153. will these rims fit and what u think?
  154. 04 Civic VP brake upgrades
  155. 2004 civic hybrid
  156. Which Center Caps?
  157. Install brakes myself?
  158. Dealer told me 205/55r16???
  159. I hate to be asking another one of these but... Will they fit?
  160. New tires
  161. Konig crosshairs
  162. New wheels for my 2001 civic ex
  163. 18" on a 2001 civic ?
  164. Pics of lowered car on 15" stock wheels?
  165. Wilwood BBK owners step in here
  166. Shimmy shimmy ya
  167. fit rimssss
  168. Can these tires fit these wheels ok?
  169. rim question
  170. 16" or 17" rims on a Civic 02 LX without lowering?
  171. SSR Professors SP1's 19" x 7
  172. Brakes
  173. brake conversion list
  174. 2004 honda civic brake fluid
  175. 2004 honda civic brake fluid
  176. 17's or 18's on stock height???
  177. help with rims
  178. Will these tires damage my suspension?
  179. Tire Size vs Speedo??
  180. New to rims and tires and I have some questions
  181. 15s 195/60R15
  182. Will These Rims Fit?
  183. Brake Reservoir Cap Parts Break down help
  184. 00 GSR Calipers could they work as well?
  185. Odd question
  186. where can i find these rims...
  187. 5 lug and brake swap information em2, es1 01-05
  188. How to paint DRUM BRAKES?
  189. Tire Sizes?
  190. need help
