View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. 2K1 Civic Question!!
  2. I FINALY GOT MY CAR BACK
  3. Know What Sucks?
  4. 2001 Civic Recall
  5. ANyone else have a problem opening their gasoline cap door?
  6. Resonator??
  7. Automotive Recalls and Technical Service Bulletins, 2001 Honda Model Selection
  8. Nevermind, the power locks work now (strange)
  9. Door Problems.....
  10. Low Brake Fluid
  11. WHO'S SRS LIGHT KEEPS COMING ON?????????????????????
  12. To Turtle
  13. Speed Bumps wit new civic
  14. Back Seat Clicking sound
  15. power loss...
  16. Curise Control "Cancel" button sticking in the cold
  17. Anyone Else's Doors Leak??
  18. TSB's
  19. Transmission slip
  20. SRS Airbag Light
  21. Rattling Door Lock
  22. What is meant by kick back?
  23. Stallin and low idle
  24. I need a electrician!!!!!
  25. Seat belt not retrackting all the way???
  26. Coil-over: How do you lower it?
  27. Camber question
  28. Rattles from side air vents
  29. clutch problem
  30. Windshield Cracking in Cold Weather
  31. stock spoiler came loose
  32. Grinding going into 5th? LX Coupe
  33. hyper white
  34. Help Condensation in my Headlights!!
  35. TO EVERYONE WITH LOWERED CARS:
  36. Do you still like your Civic?
  37. u want to know we have trouble shifting [stick]
  38. Radio gets messed up when i turn on the car.
  39. damn noise above 45mph
  40. Doesn't Honda N.A. learn a thing or two?
  41. WTF MY CAR FOGS LIKE WHOA!!
  42. not liking the sidmarker thing
  43. 2001 seats not as stiff as previous generation
  44. This question may be retarted but...
  45. Trouble Shifting In Reverse (manual)
  46. installed cai now check engine light is on
  47. bad smell
  48. vibration when driving in rain
  49. WUT THE HECK!!!!!
  50. when you have a window or moonroof open...
  51. MAINT. REQ'D light flashes...never noticed it before, what could be wrong??
  52. second gear problem in 2002 ex 5-speed?
  53. Squeking Sound on Strut/shocks
  54. Clutch "Squeak" Solved
  55. worst car jack ever
  56. Engine lugging in 1st & 2nd gears
  57. I wrecked my civic
  58. SRS Side Airbags Light
  59. vibration at 80mph
  60. just put in my injen cai have a q...
  61. Ricey noise around 3K rpms
  62. Sort of worried...
  63. Shifting Problems - 5spd EX
  64. check engine: bypass control solenoid valve
  65. Defog Thud
  66. car not starting
  67. How long did YOUR firestones last?
  68. Does anyone's car do this?
  69. Gas/RPM problem
  70. OEM Alarm problem
  71. MY E-BRAKE rattles!!!!!!
  72. Problem with my brakes...........
  73. Thermal R&D on coupe
  74. HEADER for LX
  75. fire in the fuel tank!!!
  76. fire in the fuel tank!!!
  77. clutchless shifting??
  78. Gas pedal feedback? Anybody else notice it?
  79. Gas Meter
  80. idling not constant
  81. My trunk locked up
  82. Question about metal grills
  83. Head lite bulb blew up !
  84. can i get rear strut but front
  85. plastic piece under dash getting in the way of the clutch
  86. Meeting with HONDA rep. over seat rocking....?
  87. AC DEFROSTER FEUL DRAIN
  88. ANNOYING CIVIC 2K1 Problems - time to nit pick!
  89. dealer installation of my license plate scratched my paint - warranty?
  90. Shifting to D4, slight jerk.
  91. The roll back is annoying.
  92. Flap on fuel door getting stuck open??
  93. Strange Sound After Startup?
  94. Dirty engine compartment
  95. Why does my gas door never open???
  96. gas gauge problem
  97. Front axle is bad.
  98. Static noises from speakers with power windows.
  99. damn seat belts!!!!!
  100. Maintenance Required Light
  101. URGENT! PLEASE READ/HELP!
  102. "Rough" Shifting on an automatic
  103. Is there an actual gas gauge FIX???
  104. on my black lx coupe
  105. Motor Click Sound
  106. water boiling sound from front...
  107. Civic Warranty
  108. Brakes GRAB under steady braking
  109. how much for a replacement key?
  110. Clearing Headlights Question...
  111. Warranty Repair #5
  112. Seats eat wires.
  113. help! blown shock
  114. problem on my civic
  115. Front Bumper
  116. Foul Brake/Rubber smell from rear/psngr wheel well... lots of what ifs - plz help thx
  117. loosing my tracktion on both wheels
  118. cruise control!!!
  119. "speedo" problem
  120. windshield wipers
  121. Frost on interior of windows???
  122. AEM cai - no sound??
  123. NOSIE IN STEERING
  124. problem with second gear
  125. Recirculation/Fresh air switches itself
  126. Right Side Rattle
  127. Brake squeak at 12k miles!!!
  128. Cigarette burns
  129. THUD noise from front end
  130. Loose Hood
  131. Drivers Seat Problem rocking
  132. Strange noise comming from the air conditioning
  133. My Pooor Gas Mileage!!!
  134. warranty question
  135. NASTY SMEll CUmmin from the ac/heat vents when turned on
  136. hard start - no apparent reason
  137. Stuck in gear?!?!?!
  138. banging sound from the back passenger side
  139. Rattling sound from the exhaust pipes!
  140. drivers seat doesnt want to latch (NOT part of the service bulletin for the seat rocking problem)
  141. You people complain so much...
  142. whining noise from engine
  143. OEM Floor mats, but not hooked up?
  144. Tire size/speedometer Question
  145. SRS light came on!!!!!!!!!!!
  146. Treeible weeeeeeening noise from engine
  147. vibrating feeling
  148. Vibrations under gas pedal in A/T lxg Civic
  149. Into the Shop We Go
  150. Having trouble taking the key out of ignition....
  151. Car shutting off in NEUTRAL!!!
  152. New findings to stalling problem.
  153. Sloshing sound from gas tank
  154. Sunroof rattle
  155. NHSTA Service Bulletins and recalls!
  156. I'm starting to doubt my civic.
  157. This is Weird
  158. Someone wrecked their 2k2 civic and the airbags didnt deploy
  159. Why the F....
  160. On going problem with dealer
  161. Side Airbags Cloth Problem
  162. Stereo Problem
  163. knocking sound in the suspension
  164. Intermittent rumbling/vibration a first start-up/warming up session.
  165. The problem has been solved!
  166. Durned Tires
  167. Manufactures waranty?
  168. Gas milage blows donkey.
  169. rattling sound near window/ air vent
  170. Axle??
  171. engine rattle, sounds like a tractor
  172. Brakes almost gone 4K!!!!
  173. Buying a Civic. Questions about theft/vandalism.
  174. cheap way to fix plate rattling
  175. abs problem
  176. Glass under waranty?
  177. Gas gauge reading way off.....
  178. Oh yea.....another strange thing...
  179. I'm tired of this
  180. rough seam inside stock headlights
  181. Problems with Coupe or Sedan?
  182. Problems? When you bought your car?
  183. Question on AUTO TRANNY! HELP!
  184. Intermitent Starting Problem
  185. 215\40\17????
  186. SRS airbag sensor problem - solved, ignore.
  187. picking up car today,,,
  188. misaligned trunk lid?
  189. INTAKE NEED HELP!!!!!!!!!!
  190. Vibration when idling.
  191. CAR TURNS OFF
  192. A NEW problem with clearing headlights! Read! Solutions welcome!
  193. E-Brake Problem?
  194. IDLING AT 6000RPM!!! HEEEEELLP **update**
  195. Tpye R and Type S
  196. Ice trick for dents
  197. my window rattles alot ...
  198. Driver's side front window SLOW
  199. headlights...is it just me, or....??
  200. <Tape deck Backlight problems!> help plz!
  201. hey im new
  202. NO HEAT ON MY FEET
  203. driving problem
  204. Extreme Wind noise
  205. Am I the only one?
  206. noise like gurgle/compression
  207. Shifting from 1st to 2nd requiring more blending??
  208. oil and gas mileage
  209. bad strut
  210. Waz up w/ my alarm
  211. imagine a dealer who refuses to fix a problem with a car.
  212. Exhaust Sound?
  213. Horn acting weird when the A/C is on or at high speeds?
  214. RECALL: Belt Buckles
  215. Skunk2 installation
  216. DIY rattle????
  217. 205/40/17 becareful!!
  218. procarparts.com SRI
  219. car shakes like a siv!
  220. Damn horns keep going off when i leave my car, anyone else?
  221. Any problems with "notchy" shifters on '02s?
  222. Anyone had their CD door pop off yet?
  223. Petitioning HONDA, is there strength in numbers
  224. COLD START
  225. My 02 Civic
  226. Rattling noise from rear window
  227. passenger side seat belt slider rattles bad
  228. BLINKERS TURN SIGNAL!!!!!!
  229. Is the 2000 civic better???
  230. ok ok ok
  231. vtec in 2k2 civic ex
  232. any clues as to where this noise is coming from???
  233. intermittantly pulling to the right?
  234. GC coilovers popping
  235. What Wheels Will Fit On Our Car?
  236. 2001 HONDA CIVIC BLOWN MOTOR
  237. HERE'S THE PICTURE OF THE CAR!!!!
  238. Sporadic Cracked Windshield
  239. has anyone noticed a knocking noise coming from the wheels when turning?
  240. Wheel Hop, Loud Bang
  241. i hate my firestones!
  242. was my spoiler installed wrong?...
  243. tick,tick,tick
  244. Blown rear passenger shock...no suspension mods...under warrenty?
  245. key wouldnt turn in the ignition
  246. Update on grill mesh problem with Tsunami bumper, please help
  247. Does anyone find the seat handle a bit clumsy?
  248. are all ex's supposed to come with rims?
  249. Stock cd player changing radio stations by itself
  250. 17" rims eats gas
