- RPM range
- HELP PLEASE ASAP WITH TACH
- Engine Light is ON - code (41)
- SRS Light
- splash guard is rubbing a groove in my intake
- Warranty Work
- Blown Shocks
- malfunction indicator lamp
- common probs to fix before end of warranty?
- Warrenty law that Save's your a$$
- Alternator died on me
- crunch in reverse (5-spd)
- Blinker Not Working
- 2K1 Civic Oil Changes
- 4x4 help!!!!!!!!!!!!!!!! ASAP!
- HELP!! My Rear Night Light Doesn't Work
- exhaust rattle?
- Right Side Squeaking like Mad, Door and Etc
- Any resolution to...
- Engine "Pull" Seems Weird
- Great Gas Mileage all of a sudden? What happened?
- Tyc projectors
- Cracking noise from font of car
- battery busted?
- rear axles sqeaks when hittin small bumps
- pwr locks
- cabin air filter ??????
- weather strip on my windshield
- wheelwell inner cover problem
- HELP!! ASAP!!
- engine light at 2700K!!!!
- power steering fluid leaking !
- Maintenance Req'd
- ABS light
- HELP DEAD CAR!!
- Power Steering?
- Hp Short Header
- I HATE POTHOLES/HONDA SERVICE
- Engine redlines at 4000
- Rough Idle
- Check engine light drama!
- maintenance required light?
- Help Please
- car takes a while to start
- Weird rattling noise when I turn right...
- Low Brake Fluid
- Weird Shaking
- VTEC kicking iN?
- gas MPGs jumped up!
- is it just me?
- right door panel rattle/vibrate with VIBE
- Gas Needle will Not Read Gas.
- Mileage Concerns
- Problem with Radio, PwrDoorLocks, chime
- 60,000 Mile Tune-Up
- HELP!! Exhaust burning bumper
- Your answer may be here! TSB / Honda Complaint Address / Etc...
- Water Leak Under Corner of the Dash on Drivers side
- Manual Transmission Probs WHY???
- Unsafe ride
- Twang
- Backfiring?
- Trunk Ajar Light
- Clusters
- alternator whine (non-stereo)
- This
- My rear is odd???
- Quick Help Please
- Help Pulled Bumper
- Car Trouble
- shift boot
- need sugestions
- Auto Trany noise ?
- rear right corner suspension squeaking
- exhaust options for a lx
- Warrenty stops Problems start
- Touching up paint
- Engince Ticking
- Help. Engine light came on.
- Main't Req Light
- SRS Indicator...
- temp very high
- Oxygen Sensor?!
- Reverse Noise *adivise?*
- Noisy clutch return spring
- Sorta rough idle when first started in morning
- squeaking
- trunk rattle
- air conditioner problem
- Engine Light came on....and bypass valve
- I'm having serious car trouble...
- remote problems?!?
- POS plastic under engine bay
- Is the 20,000 mile checkup worth the money?
- Oem Fog Light............
- clikcking sound when i turn right
- Auto. Door Lock Broken?
- gas milage and muffler....
- Bad Sound When Braking
- Leaking something from my bottom of my car
- WW rear came off
- What is wrong with my door????
- help with getting front hub off
- Hydrolocked or NOT!?!?
- Help! Wet Floors
- Radio Back light on
- Clicking noise
- Clunk Clunk
- My car won't redline!
- UPDATE:engine light came on my stock sedan. went to dealer & this is what they said
- Oil Pressure Sending Unit
- Bottom strip of radiator coiling falling off
- Has anyone heard of a "purge control valve"??
- trunk springs
- Manifold Glowing?!?!
- Smoke from cat....
- 10,000 mile checkup
- 30,000
- CV Boot and Honda Warranty Help!!
- hesitation on start up
- Unbelievably tight screw
- SRS Light
- 3rd gear problems
- Resetting the Maint Req'd light...
- Puddle problems in stock sedan
- Check Engine Light?
- Grinding in 3rd gear
- Is this an alternator problem?
- Fuel Problem Or Something
- pulsing coming from clutch
- Chirp while rolling
- Check Engine Light(Searched)
- white powder stuff from steering wheel
- something is broken
- Question for anybody with injen race division intake?
- side mirror fell off
- 30,000 miles major maintenance due soon
- front vibration
- Maintenance @ Other Honda Dealerships?
- 20,000 Maintenance Schedule
- Which fuses?
- 40k mile maintenance
- Maintenance requirement light
- Grease
- Door Dents, Dings, Scratches!??!?!?!?!?!?!!?
- Cold air intake
- Please help... screws stuck in air filter housing
- Vibrating Sound with A/C
- AC not cool at all
- Honda = Sheeit
- Wimpy clutch
- gx piston problems (removed them)
- Horn/SRS/electrical?
- auto-locking in door doesn't work
- How stupid is this...
- bumper melting...help...
- I fixed trunk rattle!!
- S-afc problem
- Fuse keeps blowing.
- What should I do...???
- it's fixed!
- Ploblem with AC and signal
- this just came to my attention...
- when do u get your oil changed?
- check engine light
- 2 pipes on the back...
- some type of exhaust problem
- Rear Suspension Squeaks?
- Burned Clutch
- HELP: Need to replace 3 wheel studs
- 2k1 Suspension and Clutch
- Big Problem!
- SRS light problem from neons!?!?!
- The Problem W/rear Suspension Squeaking
- Rear deck
- My marker light is running with signal light, help!
- Fuel Gauge
- To the dealer...
- Car not starting, 3 times to dealer
- Signal Help!!!
- Booooiiiiing (spring noise)
- Dents! Help!
- Having a problem.
- .:Bumper Predicament:.
- 2001 LX won't idle
- How many miles until we should change our FUEL filters?
- Terrible gas mileage
- 3rd brake light not working
- anyone else have screwy doors locks
- idle problem..
- Here we go... again...
- Headlights problem!?
- Clicking when accelerating?
- There's a dent on my dash :(
- battery dies and humming
- do you change your own oil?
- aem cai broke!!
- SRS light
- do i change oil filters, transmission fluids at 20k or still too early?
- My civic gets dents too easy
- High Idle After dropping engine
- Serious Problem Here!!!
- Driving cycles?
- 2003 civic rattle
- my trip to the dealership
- Aftermarket Shifter w/ Stock Boot
- alarm problem
- Any1 have these problems
- Loud Ticking When I speed up and Slow down?
- need help with rattles from my system
- Where the f**k are honda civics made.
- HELP I cannot get my octane sides to fit
- damaged bumper support on 03 and dealer won't do anything
- HX Problem
- Maintenance Required Light........???
- Blown Motor
- Maintanence question.........?
- hard time taking off the silencer help help
- Electronics in Door?
- Rattle in door. Any suggestions?
- Is it Normal for a closed sunroof to rattle a bit while driving?
- Please help! Problem with rear turn signal lights!!!
- left front stabilizer link, how important?
- body kit problem
- sqeaking coming from belt in engine
- Rattle in dash
- Hey Need Help with BP Valve
- A whistle inside my car
- door panel removal
- V-tech
- Car shakes when A/C on
- Front Valance
- Headlight Dillemma...I NEED your opinions asap!!
- Car starts but guages dont work!!!!!
- 2001 DX with no A/C help!!!
- Click when pressing clutch
- Is it just me or the car
- 2 questions...
- getting screwed, help!!!
- 2 Questions Pleez
- my car JINGLES!!!
- One window is slower...
- Recalls
- Immobilizer being weird.
- KNOCKING NOISE when turning: resolved
- theres a big ass bug stuck in my tyc
- How much drain should AC cause?
- Finally some good news!
- Projector problem
