- ARRRGGG RIPPED BUMPER OFF
- Maintanence required?
- Brake noise I guess?
- My '02 EX, again, failed to start.
- First Oil Change....
- removing shift knob
- Dim Headlight Issues
- question about a click/creaking clutch
- Sound between 1500-2000 RPM.
- Couple Questions
- more power
- my baby just died at 12:45
- Broken Exhaust Hanger
- Argh! My N1 Iz Rattling!!
- Factory Fog Light Owners - Broken lenses?
- Damn Hood!
- MANUAL tranny FAILED, need help!
- Question about reading a TSB
- Speed Gauge No Longer Correct
- WTF (tail light question)
- small part of wheel rusting
- Took '02 EX to dealer today for rattling noise in engine
- When A Broken CV Joint would be fun!! I need help:(
- Not passing smog after intake install?
- Generic front upper strut bar?
- Crappy Honda suspesnions...
- Some a$$hole hit my mirror...what should I do?
- rubber under front bumper
- notchy sound in first
- Wind Harmonics?
- Neutral, Clutch Out, Wheels Turn... WTF?
- Brake Lights
- Sidemarkers
- "Jiiiii" sound from PEDAL when stepping on the brake
- Fogged up Headlights
- Rest padal screw broke!!!
- Need Help Taking Off Air Filter Panel
- Fuel Gauge Problem!!
- Signal Indicator Problem!
- Weird Noise coming from outside?
- blown tranny!!!
- headlight keeps burnin out
- HELP!
- Got '02 EX back from dealer today concerning rattling noise in engine
- 2nd gear...grinding sometimes.
- Seatbelt
- bad struts!?!?!
- Problem with the Nokya bulbs
- Keyless entry & power door lock problem
- dirty throttle
- seat problem(not the rocking problem)
- Tailights fogged up...
- G-Tech Pro Comp??
- dnyamat fluke?
- Windshield rock chip
- New Transmission
- Ice chattering noise from back window area?
- Rice Krispies
- new front window seal!!
- Air Leak? Where? What?
- Very strange problem...
- Whine sound at idle!!
- Moonroof rattling - FIXED!
- Squeeking noise coming from THE transmission.
- strange sound from front passenger side
- Another horrible experience at the dealers!!
- Clunking clutch?????
- "knocking noise"
- scratching and knocking soun gd when i left the garage.
- OK, HERE IS MY PROBLEM!!!
- URGENT HELP!!
- Gas Mileage Sucks, part II
- Injen CAI = right turn signal not working?
- obx b3 anyone know if it will pass smog?
- battery dying!?
- Cold Air on Feet (2k2 civic)
- I'm averaging 15k km's between shocks
- Dome Light problem
- hmm strange.. help?
- Maintenace Required Light
- Car Battery Problem!
- Gauge Needles Moving Randomly
- Flaking Paint on Bumper
- finally got rid of my si coupe
- ignition failure after updating support tools for emanage main unit
- 02 cup holder lid
- Please help: noise coming from engine
- rpm's jumping
- Visor rattles...
- HOW MANY OF THESE ARE WE GOING TO HAVE??
- i need some help! My car is overheating and its 30 degress OUTSIDE!
- is it normal the main req light blinks when i start my engine?
- Howling noise from tires
- strange noise, passenger door?
- Noise when opening door
- auto trans grinding??
- new bumper
- > > > Common Problems... < < <
- '01-'03's STEERING WHEEL - Clank, Rattle,Clunk,Noise
- Raaarrrrrrrrr sound at Highway speeds
- Returned Car?
- Goldline suspension problems....
- Clutch wear question...
- power windows PRoBLEM!
- What to do????
- Help Adjusting Sensitivity On Stock Keyless Entry System
- Radiator/Thermostat problem
- Engine Shakes and Check Engine comes on
- HELP PLEASE!!
- car wont start
- Horrible sound coming from car
- mods lowering gas mileage?
- how much for maintance
- Alignment FRUSTRATIONS
- Shifting to 1st
- trunk lock wont work
- Headliner fit issue...
- maintenance required light question
- Cracked Coilover Plate, Will Eibach Send Me Another One?
- Rattling noise when going through water...
- Engine shake on start-up
- hit a curb and my camber is messed! HELP!
- manual tranny problem 03...
- Need To Know Where to Ground
- to all my tall people
- Aftermarket Paint???
- Should I take my car to the dealers?
- Car got towed and now can't run
- aem cai hissing sound?
- will alarm/remote start void warranty???
- Does my engine sound normal?
- Front suspension clicks with left turns
- maint soon light timed at reg intervals?
- Ticking noise when heater is on
- failed state inspection for projetor lights
- Chipped/Cracked Paint
- couple questions. please help
- Paint already peeling on new '02 EX...help!
- Engine Ticking
- i hear a poppin sound when i turn
- Original transmission but motor swapped. Will this cause problems?
- cracked windshield
- Driver's side door lock is dumb...
- battery indicator
- Fixing Rear Deck......
- Help, idle drops when engine cold.
- AIR VENTS
- FrieD clutCH!!!
- door ding
- speedometer stuck
- gauge needle problem
- Maint. Required Light?
- high speed shakes on cold engine
- Trunk won't stay shut!
- Inside of rear window fogging up
- Water And CAI
- Knocking from Koni's?
- Suspension concern
- SRS light question..
- AEM SRI ?
- DAMN TRUNK!
- Gas Cap Release
- My struts are shot
- Steering WHEEL PROBS HELP
- NOISES AFTER U TURN YOU CAR OFF? ANYONE?
- HELP Interior lights going
- Car bouncing
- I swear this car......
- You need to check this out
- Passenger window and rear windows
- can a spc camber kit(front) fix this prob?
- To anyone who has had the suspension noise....
- hard starting
- just hit a curb
- 2 rev limiter???
- Ive got gauge problems again!!! Need help!!
- exhaust problem!!!!
- moderate shaking when going between 63-68mph
- problems with the starter
- Rough clutch engagement/disengagement
- cross threaded
- what the f@(k...always the same headlight
- model DX w/out RPM guage . . .
- Once again I've got problems with my gauges........................
- Stock CD Player messed up
- turning back mileage
- Rust from wing installation
- Maint. req. light flashing on new EX
- Air Con problem
- CHECK ENGINE LIGHT?? DIFFERENT SCENARIO
- headlight bulb explode...????
- Manual Shifting???
- Maint Req'd keeps on blinking then turns off?
- Poor Highway mileage - may dump Civic
- CEL = exhaust
- cig plug not working!
- 2K1 Civic Problems....CRAP
- What does it mean...
- door panel popping off
- help! door lock
- I have condensation in my Headlights
- Engine air flow not smooth...
- Water in Intake?
- 2k1, I need your help(2001+ Civic LX coupes)
- engine light on HELP SOON
- Tie Rod End Broke....
- noise?
- rubber thingy under front bumper falling off
- Weird Sound??
- Grinding in 3rd w/ Shortshifter
- Seat Cover Side Airbags?
- Stock head light went out?
- cruise buttons????
- HELP FAST!!
- need some help guys
- OMG.. what the hell is that noise?!?!?!
- Spring Noise What to look for?
- Scratch in bumper
- ATTN: 2001 Civic LX Sedan owners please reply
- knocking?
- reversing
- crack in windshield
- Where Can I Get Interior Air Filters For Cheaper Than Honda??? Cause I Think I'm Due For A New One!
- frozen gas door
- Transmission Jerk
- Water gurgling sound when.......
- Snow bank run in...
- grinding...
- Air Vent Clicking??
- Getting a rattle when in reverse?? suggestions?
- CLEARED HEADLIGHTS NEED HELP!
- Hard Thump when car hits small bumps on road
- Fuel Door Messed Up
- my driverside foglight is fogging up
- MY TRANSMISSION JUST WENT OUT TODAY AT 40,000
- does this take off warranty?
- Car starting to reek of mould or somethin.. UGH
- Muffler heat messing my paint HELP!!
- DC Sports TCS ?'s
- Auto tranny issues
- e-brakes
- Tranny be slipping >8(
- Problem with my moon roof?
- Honda has no record of my CD Player Serial #, Part #, or Reference # !!!!!
- WHATS HAPPENING TO MY CAR???
- Suspension after 35 thousand...crap
- seat belts??
- My FeNdEr BeNdEr
- 2k2 Civic sedan taillight noises
- drops of water inside the rear window??
