View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30]
  1. Air Condition Quit Working
  2. Leaking inside car from headliner!
  3. weird problems with my 04 EX
  4. Shaking Brakes
  5. Engine noise / Belt Screech/squeal / A/C issues
  6. Grinding noise? right side belt area?
  7. Keyless entry NOT working.. help!!
  8. burnt a coil pack...
  9. Gear timing?
  10. Squeaking brake pedal pivot?
  11. 05 LX Sedan right rear lower control arm
  12. Problems after header.
  13. Replaced Engine Hunting Idle
  14. need help barely made it home
  15. Vibration while braking at highway speeds
  16. Belt Tensioner
  17. 60 k on civic , what goes wrong?
  18. 60 k on civic , what goes wrong?
  19. Prestone or honda radiator fluid?
  20. coolant system hoses
  21. best brand spark plugs to use
  22. Misfiring
  23. Civic over heats
  24. Couple of "problems"
  25. civic door lock problem
  26. help with removing down pipe from headers
  27. Trying to replace right CV axle (Please help)
  28. Grinding/Vibration only with AC on
  29. Cigarette Lighter Burned!!!
  30. Replacing AC button bulbs
  31. Unsteady Idle
  32. '02 Civic "Brake light on, door lock stopped working and A/C will not get cold"
  33. tdc question
  34. oil filler cap
  35. 02 Civic EX over heat.. I Believe I Need a Head Gasket please Help
  36. srs repair costs
  37. Weird issue with turn signals
  38. 01 Civic Timing?
  39. okay to buy replacement cat from ebay?
  40. 02 Civic Ex... How Much should I Torque the head studs and Flywheel-P Plate? thanks
  41. wet floor carpet after heavy georgia rains any suggestions on how to repair this?
  42. '98 Civic HX needs 02 sensor. $300???
  43. Bent valve replacement
  44. engine revs up before shifting
  45. Solved:Turn signal issue
  46. Need Help
  47. 01 Honda starts to overheat at high speed
  48. honda civic 1999 1.4 maniflod
  49. Shaking after torque converter lockup
  50. Squealing from fan
  51. ABS Code clarification
  52. AWFUL squeal
  53. Problem number 2!
  54. '02 Civic crazy electrical problems...won't start.
  55. squeeking noise once in a while..?
  56. Civic 1.7 CDTI Limp mode issues
  57. how to lower seat
  58. Check engine misfire!!!
  59. Check engine light and AC
  60. power sun roof seal
  61. TDC sensor code, loses power
  62. what keyless remote to buy for locks?
  63. annoying noise driving me mad
  64. 60 k trans fluid change, automatic
  65. Timing belt on outside edge
  66. Engine Check Code 22-4
  67. no cat and having lil problem on hp
  68. Just bought an '01 ex and need advice.
  69. have u had tranny problems on your 02?
  70. Ignition Switch 2005 Civic LX Sedan
  71. Electrical problems? Maybe...
  72. when do u change your spark plugs?
  73. Need to Replace a/c pump
  74. VTEC Controller Post 2
  75. Help: Gear shift sticks, brake lights don't work
  76. new gauges
  77. 7th Gen. Civic - D17A1 Engine Noise. Please, please... I need help.
  78. Knocking-type noise from valve area after T-belt replacement
  79. Car shaking in rain - PLEASE HELP DIAGNOSE!
  80. external Magnetic trans filter
  81. which tranny line is return line?
  82. please help
  83. Catalyic Converter Plugged? 97 Civic LX
  84. Glowing Exhaust Manifold
  85. prelude to civic seat swap
  86. looking at a 04 civic ex coupe. any problems i should look for?
  87. turn signals
  88. Timing belt question
  89. Manual Trans. Question
  90. Car won't release key from ignition. HELP
  91. Vibration Issues
  92. aftr market dash
  93. Bondo
  94. ever change sunroof seal?
  95. New d17a1 engine redlines at 4000 rpm
  96. NEED HELPPPP With 01 CIVIC
  97. d17 VTEC Head on d17 Non VTEC block
  98. Missing
  99. throttle body hoses
  100. best web site for honda parts?
  101. Replace 01 auto trans myself?
  102. how to remove melted spark plug?
  103. Headlight/Blower Problems
  104. Timing Belt Cover Noise
  105. Power Steering Leaking inside the car
  106. Air Con Fins in contact with Radiator after crash. Danger posed?
  107. brake popping noise
  108. moon roof replace with pop up?
  109. 2004 Civic O2 Sensor help/clarification
  110. Installed Short Ram Air Intake - Now loss of acceleration and cuts out
  111. 05 vp/dx sedan cluster prob.
  112. gauges and window problems
  113. 2003 Civic LX - Replacment Bolt?
  114. 02' CIvic alt. belt tension ?
  115. need help clutch pedal has no pressure
  116. 3rd and 4th grind HELP just need some know how
  117. p0302 #2 misfire code
  118. Weird issues (check engine, fuel gauge, etc)
  119. Honda civic problem
  120. Getting a the hatch.
  121. Fuel pump not working
  122. Cabin heating issues
  123. Timing belt - cost for parts and labor
  124. I need your opinion on a transmission issue
  125. O2 Sensor,IAC, or ELD?
  126. The oil icon light flashes when I shift
  127. Side Molding Coming Loose
  128. no cooling system pressure
  129. bad auto trans? heres what you need
  130. Exhaust shenanigans/rice-up
  131. 04 civic LX high RPM buck
  132. one headlight leaking, again
  133. loss of accel after half throttle
  134. Airbag light
