View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. fog in my headlights help!!!!!
  2. Inaccurate Fuel Gauge
  3. axle boot leaking
  4. Hyper Blinkers
  5. Tailights!
  6. TRUNK RATTLE LIKE WHOA
  7. Peeling Paint
  8. Squeaky noise from engine!!! What's up with that?
  9. crashed front............
  10. HONDA FRONT AIR DAM
  11. horrible mileage
  12. Warranty/Exhaust Info
  13. Front Struts
  14. My little horror story
  15. sand in car seals
  16. Is the problem with Honda Coporate or Honda the dealer??
  17. shaving red car???
  18. Hot headlight
  19. Slow braking 7th Gen Civics?
  20. HONDA QUALITY......PROBABLY AS GOOD AS IT GETS
  21. squeeky clutch pedal
  22. Noise in front end (new springs)..Need help!
  23. AIR CONDITIONING
  24. New Rims and Tires = Alignment
  25. Can your driveaxles be bent?
  26. accidents SUCK!!!
  27. AC not getting cold enough
  28. Damp Seatbelt and Wet Window
  29. engine noise
  30. this engine grinding has got me worried.........wtf...........
  31. My steering wheel is shaking! Help!
  32. Gearbox grinding!!!
  33. If you got new tires/rims, alignment is NOT required
  34. What do u call this problem?
  35. Breaking in a new 2k2
  36. Bouncing in the back of car
  37. HID & Projectors...
  38. Suspension FIXED
  39. Your biggest problem with your 7th gen...
  40. Antenna sucks
  41. KEY STUCK IN GAP BETWEEN WHEEL AND COLUMN!
  42. Engine running too rough. Please Help!!!
  43. WRITE HONDA TODAY FOR RESULTS...
  44. muffler install headache
  45. transmission?
  46. ECU Wiring Harness Layout Question
  47. Leak Underneath When Using the A/C
  48. 2002 Honda LX - Lemon because of noise
  49. whats up with the ticking engine??
  50. Headlights dimmed briefly when you take your foot off the pedal...
  51. alarm.....wierd
  52. idle problem
  53. Satin Silver Metallic Bumper Paint - Hard to match??
  54. Another Honda with excessive clutch travel!!
  55. warranty work- fix one thing, screw up four things
  56. headers turning red
  57. My Car Going Crazy!!!
  58. I AM LOCKED OUT !!!!
  59. brake noise
  60. got a squeel under your engine???
  61. Is the armrest too small???
  62. EXHAUST RATTLE?????
  63. 2002 Civic Coupe LX is hard to start
  64. Engine problems
  65. Windshield Cracking
  66. GASoline smell???
  67. Fenderwell trim
  68. how often do u change the oil and do u need to buy a new oil filter
  69. how do u know when brakes should be changed
  70. Rattle when I accelerate
  71. Not always starting up?
  72. Free Dealer Car Wash F*D my Car.
  73. Symptoms of a lugging engine?
  74. Windshield Cracked
  75. PAINT ON TRUNK FADING!
  76. Power Window Problems
  77. Tip on locking driver's door with stock power locks
  78. clicking noise
  79. lemon law ma?
  80. shaking at 75mph+
  81. Coupe Seats Head Tilting
  82. DEAD CYLINDER!!!!!!!!!!!!!!!!!!
  83. bad seats?
  84. Grinding Gears
  85. hole in seat
  86. Please search.
  87. Paintless dent repair/removal : review
  88. weird problem in the rain
  89. My ECM is blown!!! What could cause this?? I NEED HELP NOW!!!
  90. squeeeeeking hmmm 2k2 civic sedan WADDUP WIT DAT.
  91. Some dash damage, help?!?
  92. Air conditioner filter source?
  93. reflective tint in FL
  94. problem inside the gas tank
  95. Engine - Uneven power when cold ( lurching)
  96. Roaches in the vents...
  97. driver's side floor Damp/Wet.
  98. Firestone = Poo
  99. Interior Panels
  100. Recall For Idle Problem
  101. WINDSHIELD WIPERS SUCK!
  102. Air Conditioning - Not too cold...
  103. 2k2 Civic LX... Clicking when brakes depressed in park...
  104. Armrest or Elbowrest?!
  105. car stalled and wont start...
  106. vibrations due to low rpm
  107. roaches in my intake
  108. kinda sluggish
  109. cracks in your gauge cluster cover.
  110. leaking?
  111. Revo Short Shifter Bad Review
  112. Carbon Fiber Spark Plug Wire Bad Review
  113. Squeak in hood hinge
  114. Driver's side seatbelt part rattle! HELP!
  115. 2ND GEAR KEEPS POPPING OUT...HELP!!!!
  116. 2k1 stalling problems, thinking of selling car
  117. tranny mount.....damaged gonna be replaced under warrantee
  118. I HAVE NO LOWBEAMS HELP!!!!
  119. Coolant Level
  120. WANRRANTY...OVER 20,000???
  121. i have a problem
  122. Has anyone had any hesitation when starting the engine?
  123. please help...
  124. fog in back
  125. passenger side door is messed up
  126. when (where) does you steering wheel lock engage after taking the key out?...
  127. Found mouse nest in my trunk
  128. Engine whining noise
  129. Maint Req. Light
  130. Blown Struts?
  131. have i voided my warranty?
  132. the new honda's
  133. Hot day, now my gauge needles are stuck :(
  134. cable broke for truck and gas tank
  135. Rattling noise on driver side door
  136. sputtering when enguaging clutch in 1st gear
  137. BIG PROBLEM AT DEALERSHIP
  138. A/C with WHITE SMOKE occasionally
  139. SNAP!(not POP) when steering at stop/low speed
  140. Burns in upholstry
  141. mileage question
  142. Injen intake sucked up water Engine is dead
  143. power steering system or the rack...........
  144. the grinding/scratching noise again!
  145. another waranty problem....
  146. steering wheel turns funny
  147. Car Hesitates on takeoff...
  148. Buzz/Squeek/Rattle: Driver Door
  149. HELP!
  150. Taking my car in for service... Do I Get a Loaner car?
  151. question on maintenance light on dash???
  152. weird smell form air conditioning
  153. squeeking rear shocks
  154. Scorching summer heat: how many of you still use 5w20?
  155. KEY STUCK IN IGNITION
  156. paint chips
  157. Braking-A/C PROBLEMS
  158. Grinding / Clicking noise on hard right w/ acceleration
  159. rear suspension in big trouble
  160. Spark Plugs
  161. how do you know when a strut is blown?
  162. Suspension leaning?
  163. Foggy windows??
  164. brake light doesn't work
  165. 22000 miles and the brakes vibrate
  166. rear seatbelt grinding sound
  167. Cargo net
  168. errrr. .. side airbags
  169. Dents
  170. Headlights & Interior Lights Dimmed (Part II) - Civic GLI Australian Model
  171. Are the LX,s less trouble prone than the other models....just curious
  172. any problems with...??
  173. any one having a problem setting the clock?
  174. THROTTLE RESPONSE GONE TO SHI7
  175. Engine Shuts off
  176. CONT. ITS OVER ........I can,t take it anymore.
  177. trunk messed up
  178. Drivers' Side Windshield Wiper Hits A-Piller
  179. Any Advice on Steering Shake with new wheels??
  180. Need help!!!!
  181. Paint peeling/chipping on '02 LX?
  182. The non-US Civics...
  183. Ticking noise fixed
  184. 10k mile check, HOW MUCH $$$$$$??????
  185. turning question
  186. heh, I just did a search for 2k2 service bulletins...
  187. A/C vents
  188. Hp headers with High flow cat
  189. Spare Tire Came Loose!
  190. RPMs drop WAY low
  191. How to drive the 2k2 civic lx with AT?
  192. i can't get my pics smaller than 100kb??help!!
  193. Coilover noise
  194. to all moderators, and any with major engine experience
  195. question on maintenance icon in dash
  196. Neon ?
  197. My Car Shakes...Do these Hub RINGS look right
  198. What would a leaking strut affect? Just curious
  199. NOISE!!
  200. Weird noise after disengaging clutch
  201. Cars turns off for no reason....
  202. Rear deck rattle
  203. LX Launch Technique / Shift Points anyone?
  204. Finally found the most annoying rattle
  205. how lound is your engine at redline??
  206. Wire in engine bay.
  207. Rear seat lock
  208. Melted fuse box
  209. HID problem/ stock fog light
  210. dealership woes (venting: very long story) *update*
  211. Octane Ground Effects
  212. ATTN SOMEONE GIVE ME THERE IDEAS????
  213. MAINTAINANCE REQUIRED LIGHT
  214. Is the air conditioner filter necessary?
  215. Stupid Annoying problem
  216. Window creaking when rolled all the way up?
  217. is it my guages???
  218. 2002 LX 5 speed manual problem
  219. Parking on a slope facing upwards
  220. A/C line has a hole
  221. Seatbelt Whistle??
  222. how often between recharging A/C??
  223. Any advice on my civic?
  224. calipers sticking??
  225. Getting New Struts!!
  226. my EX wouldn't start
  227. ***Knocking Noise!!!!!***
  228. Squeeky air intake - just me or what??
  229. Rattling while driving
  230. honda brakes
  231. Fragile Alignment?
  232. TO everyone having stalling problems
  233. CHECK ENGINE light is on...!!
  234. 01 Ex coupe, finally gone a best forgetten
  235. Indiglo Gauges Problem
  236. Clutch Question and Squeeking
  237. Burn Mark in Fabric above drivers window
  238. need some help on a 1995 nissan altima
  239. Coolant level dropping
  240. Knock sound from the BACK..not a rattle!
  241. Automatic: Uphill Parking
  242. door handle goes in too far
  243. When coming to a stop
  244. Car Performance Problem
  245. *****URGENT-my 2k1 is playing drum while i drive*****
  246. problem clearling headlights
  247. recall for stalling
  248. Check engine light-intake?
  249. Paint chipping off bumper
  250. PLEASE HELP URGENT.. SQUEEK from Engine when AC is on??
