- dead speedometer, battery light(new battery) cel
- Weird auto trans behavior? or normal?
- 7th gen DIY ATF change
- Change transmission or just sell it as is
- CEL P1167 - which oxygen sensor for 2001 Civic HX?
- Reverse wont always work, just revs with scratching sound..
- Turn lights do not flash when using remote locking
- Need transmision! grrrr...
- front left side squeaking
- Dealer saysa clutch is toast...what to do???
- Transmission issue - Slave Cylinder?
- Custom Gauge problem
- Stalling problem, threw P0420 code., help?!
- Trunk Release Handle Stuck In Locked Position
- Quirky electronics...OBC?
- Vibration problem
- Need help with an heater issue on Honda Civic 2003
- 02 Civic Si Coupe - Engine Mount
- Another a/c problem
- Do my air vents need Viagra?
- Trouble finding exhaust for 02 Civic LX Sedan
- Wet Drivers Side Floor
- Need some Help... Gauge Cluster Light Turns off when parking lights come on...
- post engine swap issues.
- Annoying noises
- Replacing rear driverside bearing
- Bizarre SRS light issue
- Is this a problem w/ battery? Or something else?
- My trip to Firestone today. Opinions wanted
- K20A3 to a K20Z3 swap!
- Taking out a D17A1 engine. How much do I have to raise the car to take it out?
- Tag light is out, need simple ideas
- Car...Bucking.
- 2002 Civic - Alignment Issue
- Limp Home Mode
- stupid vibrations!
- Rear suspension repair
- Dimmer doesnt work
- 02 Civic Timing Belt changed but....
- 2003 EX sputtering in idle with Check Engine light
- AC compressor on the way out
- new here, have an oil leak question
- new here: anyone ever have a melted ignition coil/spark plug
- AC Compressor - A victim of low freon?
- Spark Plug issue??
- 7th Gen TDC Sensor Problems
- new to honda - bad consumption?
- 2001 AT Civic Trans slip problems
- Need help!!! My cluster was Smokin!!!
- Cannot read error codes
- Please Help
- IDLE problems!!
- Clicking noise and dash flashing
- Rear of car rocks side to side
- idling problem
- Valve Guide/Seal Replacement
- clutch slave cylinder bracket broken?!
- Not another fog light question!!
- 2002 lx coupe civic weird problem
- 01, civic one issue after another
- grinding noise from transmission...no idea what it is
- airbag light is on and will not go off
- emissions light comes on and goes off at random
- Pcv/egr
- Horn Ground
- Civic Transmissions
- Blinking D light!
- This bliner problem is driving me crazy... HELP!
- non-working center consel. and brake lights.
- Oil After 100k
- Brake Light Issue
- Horrible noise coming from Transmission
- 2003 Civic - mechanical smell coming from engine bay
- side mirrors on 97 civic
- Auto Tranny Problems (go figure)
- Taking apart Tailight?
- civic 93 4 door automatic not shifting properly
- DIY HELP... Dc5 seat swap into em2
- NYC Parking Enforcement wrecked my car!
- 97 civicex hesitation
- 2k1 Civic LX sounds like death!
- Is the 09-3 SRS code covered under the lifetime seatbelt warranty?
- Post-accident lighting woes
- Help!! Clicking/popping noise
- Clunking/clicking when car weight shifts
- Lost pickin struts
- Whistling engine
- replacing & painting bumpers
- 98 civic ex just dies
- Shuddering, bucking at just below 1/4 tank
- clank clank i need help
- 5th gear is out
- Clicking while transitioning to / from idle - fairly detailed conditions
- What you guys think ?
- 04 Civic - shorted the dash light circuit, now only partially working
- 2006 Civic only clicking when...
- Creaking/clicking when going slow.
- 02 civic: My driver's side window just dropped down when i pressed power window...
- Problem after cold start up
- Can you identify this o2 sensor?
- clancking on passanger front end
- Clutches on the A/C pump wont engauge
- Exhaust rattle hitting underbody.
- Washer Fluid Light
- Broken Spoiler Help!
- Cooling problem '03 Civic
- Old Member - HELP with choosing clutch PLEASE
- OBD2 port location
- 1999 - depress gas pedal, engine will not rev up from idle
- Tell me why the check engine light keeps coming on ...
- do i change trans fluid or flush the trans?
- Muffler Hangers !???!?
- Stock Honda Radio Stopped Workin...Not Fuse Problem
- Timing belt FULL service due....questions about parts.
- Wierd CEL issue
- JDM ES3 Civic SRS light reset ??
- HELP!! Can someone diagnose this for me please?
- Control Arm Removal Gone Wrong, Safe to Drive?
- auto transmission leak
- lots of road noise
- CEL on a 2004 coupe
- clicking noise on idle/accel transition
- Oil filter seal leaking?
- AEM V2 Question
- Reving between 2nd and 3rd shifts
- My 2003 DX gets 42 mpg??? is that normal??
- Noise occuring at speeds over 60mph
- 2002 Civic EX/Si Auto Tranny
- ? Electrical Short in Dash/Gauge Cluster
- 2001 civic dx
- Alternator light not turning off.
- POSSIBLE OVERHEATING --tricky, but PLEASE HELP!!!
- 02 sensor heater circuit malfunction p1166
- HELP ME! Engine Issues.
- Need new factory Wing Red
- Check Engine/Battery Lights
- over-heating! help?
- 2002 HX Primary O2 sensor P1166
- Please, help me out about ECU issue
- A/C not cool, compressor works... Hmmm??
- Scratches
- Visors and HVAC vents loose
- A/C Intermittently Blows Cold
- "Growl" from engine at 3-4k rpm.
- Sorry.... Newbie Question: After Exhaust and Intake Replacement????
- How to change 2003 honda civic ex distributor cap and rotor
- Steering Wheel Shaking
- 01 civic lx Car Uneven Suspension.
- Battery wont hold charge
- 2005 EX 1.7L Vibration at Idle
- 2001 Civic sputter after starting
- 07 EX low speed engine miss
- Engine problem
- Loose steering on 2001 Civic LX
- Car Hesitates/Misses when A/C is on
- Cluster stop working in my 94 civic
- Automatic Transmission Dead?
- rattlinh hood
- Oil cap popped off
- Locking mechanism fails intermittently
- Default heat
- Thermal Protector $480 to replace????
- The strangest thing
- Suspenion clunk?
- radiator fan not turning on.
- Crankshaft will NOT spin!?
- Refrigerant w/sealant question
- Strange noise when DRL are on?
- Is my clutch gone?
- Tension on Belt keeps coming loose
- Rough Idle, Loss of Power, problem solved, and wanted to post my results!
- P0420 code with Header install
- P0135 code after new 02 sensor intalled
- weird symptoms
- 2001 EX motor/engine mounts???
- Clutch Pedal Skweaky Noise
- 2003 with skidding issues
- p1129 Code HELP!
- Battery Alternator Troubleshooting Quesitons
- backlight for tripometer
- Hey, I'm new here
- auto tranny issue and steering issue
- 04CivicLX, manual, 134k, engine noise
- Why Water?
- steering wheel shaking horriably
- exhaust size
- Civic 1.5 1999 model wont start/turn over - immobiliser prob?
- ATF brands
- Will this quiet down my car?
- Transmission problem or is it??????
- Will 05 auto tranny & 1.7 engine work in 01?
- How to open passenger door panel
- Headlight bulb replacement pass side?
- changed cam plug now car is missing need help!!!!!
- Tranny
- Tint on rear window fading..?
- Paint on front bumper chipping/flaking off?
- 03 DX - Key won't go all the way into the driver's side lock cylinder.
- Stripped Nut
- The OFFICIAL Trans Fluid Trans Flush Post
- o2 sensor replacement
- VTEC Controller
- HELP! Squeaking noise coming from driver side wheel area.
- Firestone: "Flushing trans may cause more problems"
- Help Einstein needed 01 ex
- Alternator/Battery/Starter
- seized engine? HELP!
- window pops out after being replaced
- Car Won't Start, Rapid Clicking Noise
- A/C compressor and compressor switch problem :S
- VTEC 1.6 VTi problem
- A/C Problems
- Motor or Tranny whine????
- Slight Shaking while driving 65-80mph
- diagnostics help
- P1259, P0420, P0135. . Replaced front 02 sensor
- some help needed with my civic 03
- 03 civic ex headlight alignment.
- Car overheating after thermostate replacement
- 2001 4cyl overheating when idling
- Intake manifold?
- evap canister removal
- 2001 brake trouble
- Timming problem
- Brake lights not working
- Wtf is this noise?!
- Gas Pedal Sticking
- 2004 LX Brake Pedal Pop
- '04 Civic shakes when accellerating 30-35mph
- Ticking when accelerating
- Engine sound
- A/C works when it wants to help!
- 02 civic d17a2 cat
- civic 2003 driver door
- Random Power Loss
- Cruise Control
- Fel-Pro Oil Pan Gasket?
- My car got the CEL cold... DAMN!!!
- Input Shaft Bearing - How do I keep it from breaking...again?
- Temperature gauge pegged at H
- roof spoiler
- Instrument Gauges / AC won't work
- Headlight problems
- Bumper replacment
- Radio doesn't turn on when car turn on..
- Car bogs on cold start, no check engine light
- Low Screeching Sound When A/C Is On
- gear shiftbutton
- Strange drivetrain noise
