- Front conrtol arm bushing?????
- Green Light Picture Of A Key Blinking Nonstop
- Cannot get catalytic convertor nuts off.
- Different tires!!! What a...?
- i need code for the radio 04 civic
- HELP! Cranking issues...and low idle issues!
- Wheel Shake Problem
- Difference in LX/EX axleback exhaust??
- nastly clicking noise
- Tranny problem?!Or steering...?!Help pls
- 08 Civic Ex Smack nosie when rolling forward from reverse
- Car Bucks Forward
- How to get windshield rubber/trim off at top?
- Cruise control light out. How to replace?
- Weird Noise When I Accelerate
- Terrible Mileage?? HELP!
- 3rd gear grinds...
- auto LX engine w/engine harness into EX ecu. problems?
- srs dash light on
- scraping sound coming from driver side wheel
- IAT Sensor MISSING !!! Damn 2nd hand Dealers!
- Type R grill install = unwanted gap
- Some tranny problems? Not sure if its a problem with my shifting.
- Click on slow acceleration
- rapid clicks trying to start
- 1st & sometimes 2nd gear sound like straight cut?
- Window Regulator question..
- clicking noise
- DRL Lights
- Rubber piece hidden under front bumper stripped off... need to replace?
- Is repairing "compliance bushing" necessary?
- Clank under passenger front wheel
- HELP! A/C blower fan is not working!
- Exhaust Manifold... CRACKED!!?!?!
- engine knock? grinding?
- Window problem( didnt mean to post 2 times just found a better topic place)
- Timing/Timing belt tensioner help
- 03 civic got hit today
- is body repair worth it?..
- driver's side door lock
- 2003 LX transmission hesitation
- friction plates in clutch...
- Vented cap for coolant tank 01 coupe SI?
- Couple problems lead to big decision, nee some help.
- Battery or starter?
- Insufficient Air Flow To EGR????
- Air/Fuel Meter message
- squeaky driver side window
- Rear engine Mount 5spd vs Auto
- Left wheel shakes pretty bad at high speeds
- problem with my civic ex 03
- electrical, lights problems?
- Thermal R&D Catback Exhaust Problem
- Idling Problem! Help!
- Vtec problem
- Went to have tires put on... was told I have bad hub bearing.. how to replace?
- Does the 7th Gen Civic have an interference Engine?
- Suspect Speed Sensor
- Exhaust Cat-Delete!!
- Side airbag off light comes on randomly
- k i have two wiring problems
- Fuel injectors cleaners + problems
- Control Arm Bent?
- Can I have The Front Sway Bar Off?
- Think im starting to get a transmission problem (5 spd)
- CEL P0171 Check Engine Light Code, After Timing Belt Replacement
- *FIXED* Misfires- Loss of Oil & Oil Residue in Intake Manifold
- '03 steering issues... doesn't centre
- 02 civic tranny issue
- Can't get a correct reading on the oil level on my 01 LX coupe
- HELP - Just completed head/gasket service
- Where can I get good parts?
- LOUD KNOCK! newly installed motor w/ freshened up head
- Weird problems with the fuse box.
- need help...
- ?? other reason for white smoke other then head gasket related problems??
- 2005 no longer blowing hot heat
- Blowing coolant into overflow tank
- Gas pedal not working well
- Water Leaking Into Trunk
- power window issue
- Loud buzzing noise...fuel pump??
- Crash
- heater problems
- TEIN BASIC question
- Lower control arm replacement
- hot and then cold.
- My Car Got Keyed...
- Torque steer.
- Valve Jam Nuts
- Car Maintenance sucks!
- Alternative to Honda ATF?
- Can I replace 2001 auto transmission with 2005?
- So they said I have a transmission bearing problem.
- OBD II code P1258 my converter?
- Error Code: P0497 (EVAP System Low Purge Flow)
- 03 civic Ac/heater problems
- How much?
- Seatbelt in Civic Locking Up
- Power Door Lock Problem PLEASE HELP!!!
- Rattle in Wet Conditions
- Reseting the Maint Required light
- Hazard light not working!!!!! need help please!!!
- Won't shift into 5th and reverse, now what
- 2004 Civic Si Door Panel Removal
- Input shaft is on its last leg, what transmission should i get?
- brake switch issue
- water on driver side floor
- engine hesitates during acceleration
- Shuddering under light driving conditions
- Steering wheel is wonky
- EX magnaflow bolt up to lx
- Windshield Wipers not working at ALL
- Vtech Lags and car stutters...
- header/downpipe what to get?
- thoughts on engine replacement (piston slap!)
- Catalytic Converter broken... AAAAHHHHH!
- Auto Tranny Price
- Catalytic Converter...
- Check engine light problem!! HELP
- Is this too good to be true?
- 05 EX SE Body upgrade, downgrade?
- Idle Problem
- hard start after fill up
- Check engine light: P0138
- [D] green bulb in cluster dead, how to replace? (Auto)
- Battery Light Flickering?
- Stiff shifting into gears
- How to disable the valet key on an 05 Civic, can it be done?
- sound from driver side (cv axles?)
- slight rattle under acceleration
- Irregular idle..bounces around
- "Hybrid" air intake?
- Creaking sound on passanger side
- wiper not returning/no intermitent
- Window keeps jumping off track?
- Engine problems
- 2000 honda civic hx/flasher...
- attn: aftermarket clutch users
- brake issues ...
- Eng mngt light displayed
- Runs Bad When Cold Outside
- f0ck! blown engine
- Multiple electrical issues
- HELP : Car wouldn't start when really cold.. like below -20
- Separate A-pipe and B-pipe?
- Oil Change..?
- 2001 canadian si tranny slip
- 2003 Civic keeps popping a fuse...read inside
- A/C Bypass belt size
- Drivers Seat and entering rear seats
- Car stutters in reverse
- MY05 Civic Coupe Flasher Replacement
- Where can I find bumper clips??
- 7th gen help!
- 02 ex a/t charging system problem
- Backed into Brick wall! (T_T)
- Help with ECU compatibility, 01 EX auto
- Car Sometimes won't start
- Motor Mount Problems/Reviews
- 03 civic transmission swap
- problem starting - fuel filter?
- need an advice
- 2001 clutch problems
- 04 LX -- Question about throttle body and license plate lights
- changing a clutch on a 2001 civic ex
- 06 civic lx front bumper
- Problems After Timing Belt Change
- 2005 LX Cig. Lighter
- headlights not aligned?
- Somethings Fishy
- NEED HELP PLEASE, narrowing down problem.... long thread though sorry
- will a 98-01 Intergra axleback fit 01 EM2?
- i need help please !!!!!!
- water in stock headlight...!
- Clutch Noise/Feeling
- Bank1 sensor 2
- Bumper noise
- 2nd and 4th gear issues
- Window doesnt want to work
- 2001 Honda Civic Check Engine Light Issue
- the wrong year taillights
- Front end damage - Need a diagram PLEASE
- Need Help, leak from ignition coil
- 2001 (2001-2005) 1.6 vtec manual making a click sound once when moving forward
- CE Light Annoyance
- Trunk Vent
- Clutch "chatters" in cold weather
- manual tranny kicking out of 5th gear
- help
- help!!!
- 2002 Civic Trailing Arm Replacement
- What is wrong with my car??? Need help!
- bar jawn
- '03 tranny problem...any ideas?
- sound when turning.. sometimes
- oil filter
- Engine Whine
- New purchase, frustrated, long post.. Need advice.
- HELP on vibrating steering wheel!!!
- Need some help - planning a long roadtrip
- 2001 EX 5-speed (speedometer/tachometer/cruise control/starter don't work)
- Rev problem?
- Help on paint scratches!!!!!
- help!! d16y8 vtech head on d16y7 block
- Help with CEL - P1259
- difference between si and si-g
- radiator help
- New Used Engine, Losing Water ?
- how do i use a clicking torque wrench
- halo's...help
- My G/F got a free beater but it has lots of rust..
- plastic strut bearing help!!!!!!!!!!!!!!!!!
- DIY: replacing power window motor assembly on my civic coupe
- Blower motor not workingq
- Seat belt replacement
- Ignition Problem Please Help!
- another ignition problem
- Mysterious problem!!!! >=o!!
- 2nd gear popout... problem?
- civic 2004 clusters not working
- Run 8 seconds and die
- Transmission problems?
- MASSIVE manual tranny issues!!! been to the shop twice, and still have same problem!
- Arggg! So pissed. TRUNK Wont stay CLOSED
- Odd Problem
- Rust
- Wrecked '02 Civic TN
- Throw out bearing or input shaft bearing?
- Any Ideas?
- 5-speed won't shift
- quoted 3000$ to replace stock engine and auto tranny
- Looking for some good advice
- '02 Civic LX - Screeching noise while starting cold
- I think tranny prob. not sure though???
- Brake rotors....AGAIN?!
- which code reader to buy?
- Formal intro
- specific question about my/your civics
- leaky headlights!!!
- 01 civic problem (electrical?) please help
- sohc obd2a to sohc v-tech obd1
- hood doesn't close completely
- Loud thumping when shifting and hitting bumps
- HELP!!! lights not working, battery draining...
- clutch to floor after clutch install?
- 1998 honda civic lx headers
