- 50% of time no heat, thermostat fluctuates, related issues?
- Clutch Problem
- ecu code 1331 on 02 civic 1.7 ctdi help
- 2003 Honda Civic EX Auto Stalling/Bogging/Rough
- Rumbling sound when roads are wet!!!
- Rocking Chair FIX (Where to get the parts)
- Colorado 85 octane
- AC/AC light wont turn off
- Coolant leaking and over heating
- Loud Popping Noise After Shock Install "please Help"
- so my car has been sitting
- 05 civic owners- AT tranny fluid change Q
- Ex Secondary o2 sensor wiring Help!!
- 2004 LX: weak cabin heat
- Another Broke Fuel Door 2005 HELP NOW!
- Ebay Timing Belt Any Opinion on Quality
- removal of air bag seats...need help
- slipping above 6k rpms
- ebay bumper cover/fender
- Coolant Help
- hesitation/sputter in 1st gear
- LOTS OF ENGINE CODES! dont know where to start! help!
- bit of a knock/tick/some other noise
- F*cking immobilizer Honda techs please help
- would this be my alternator???
- any have DIY for cv axle/halfshaft
- 2001 Civic Ex transmission question
- used to love my honda................
- messed my baby up
- Engine Shakes A Little When Turning Off
- crashed my 2005 civic! need door!
- Corrosion under the hood??
- How to replace tdc & ckp sensors?
- Rumbling noise when the roads are wet 2
- EGR Simulator
- Fuzzy radio when rear defrost is turned on.
- Noise when reving/driving in rain from passenger front side
- Odd problem w/heater
- Overheating
- Yet another no-heat thread. ..... Fixed!!!
- Clicking sound coming from the Gear Box?
- Timing belt kit on ebay
- Need help finding out where noise came from!
- car feels sluggish...help
- Spark Plugs??
- Help... Noises coming from (tranny??) when downshifting
- Testing a Crank Position Sensor?
- I know someone has to know the answer plz help
- Belt Buckle Jacked up, SRS tripped.
- No Spark, after changing spark plugs
- Does anybody know the answer to this ?...sorry to be so persistent
- My right front seat belt is malfunctioning
- Lug stud problem?
- rough idle and no power
- Weird issue with left brake light
- Diy: Fuel Door Fix
- Key Light On while driving
- Clutch Pedal Problems
- Gasket leak?
- Idle drops and car won't go faster than 20 mph
- help please
- radiator fan not working
- Smoke: smells like burning hair from headers!!!
- Tail Light Issue
- Fuel problems ???? I need help !!!!
- Another no spark
- engine no start after clutch/timing belt change
- Squeaking Exhaust??
- painting over stainless steel
- leaky trunk (final pics p.2)
- help needed!!
- Temperature compensation. Engine won't start when below freezing.
- Car is vibrating while driving
- Car problems. in need of help!!!
- MIL keeps coming on ???
- water on windows... need your diagonsis
- 01 LX Manual Shifting Problems
- input bearing noise 2001 ex
- Help with wierd (electrical?) Noise!
- AEMV2 & DC Strut Bar Compatible?
- 04 d17a2 overheating some help here
- Headlights crystallized
- CEL Problem
- Electrical Problems
- greddy g18 turbo sucking oil in through the intake
- OEM foglight installation instructions???
- DIY: Crank pulley bolt tool......$6 bucks
- Motor swap Problems need some help..
- Will this CAI work in my 02 lx
- quiet exhaust
- A/C Compressor
- Cracked my Type B front lip
- alternator/air compressor belt loose...
- Distilled water instead of type 2 coolant?
- Tachometer acting up
- Help, need to change my cam out!!
- Truth of the check engine light?
- halo/angel eyes no longer working properly
- Electrical Problems with the ecu
- Ac problems...
- r134 capacity on a 2001 civic ex?
- DRL Problem
- headgasket gone?
- axle broken or transmission
- Accelerator /Gas pedal issue
- 2005 Coupe EX getting horrible MPG
- Possibly cracked manifold (header)
- shift knob adapter discontinued?
- Funky handling
- Alternator Fuse Location?
- vibrating and more vibrating!
- sticky gear
- koyo radiator problem with coolant resv tank?????
- newly rebuilt engine[misfires],replaced both o2 sensors but still get o2 sensor codes
- Aem uego help
- Hoda civic 2006 lxi speedometer
- Cant Read Codes - Odd Problem
- How do i program a IR Keyfob type (valeo)
- more problems
- hear a noise when im turning
- really stupid question
- overheated and car won't start
- wiper blade arm replacement
- clutch pedal
- Head gasket changed, but now the timing is off.
- 2004 Civic owner... HELP with keyless entry driver's side door.
- i read the timing belt and cooling system service
- Cant Rev past 4k
- 2002 Honda Civic EX Compliance bushings
- Have I destroyed my engine?????
- DRL and high beam not working, with buzzing noise
- Apexi SAFC
- I Need Help! Car wont start!
- Car Battery Problem?
- Stock ECU and Valve clearance questions
- 21mpg on a stock d17a2
- 03 civic 5 spd trans noise when cold
- trunk will not lock / latch will not fully engage
- Misfire codes
- 01 tranny
- ex ecu in lx
- Very weird auto tranny problem?
- Light Malfunction!!!
- 02 civic lx malfunction lamp is on.
- Exhaust problem, dont know what to do? Need advice
- Vibration at Idle
- Idling issues with an automatic
- just broke my throttle cable....need help
- Noisy Breaks
- Need the OEM part number for primary O2 sensor to 04 EX
- 02 civic check engine light
- i just got in an accident last night really bad can u guys help me out
- only my parking and break lights work. Can anyone point out why?
- major maintenance
- Is there a fix for this? Automatic Transmission Related
- I've got a drippy cam seal, help me?
- White Smoke, Car won't start
- Automatic transmission question(s)...
- P0335 TDC Sensor Malfunction! HELP!
- Exhaust problem Need Help
- Battery/Alternator Problem
- Keyless Entry Problem.
- Rough idle with AC on?
- question about d17 piston pin interchangability?
- Clunking/knocking noise
- second auto tranny in less than 70,000 miles?
- Starter For 99 Honda Civic
- AC Voltage
- 01 lx 4dr - need help
- Please Help! Cylinder Misfire
- Car won’t turn on
- Timing Belt maintenance interval
- Odd Rear Vibration
- wiring lighted door sills problem
- Erratic Temp Guage....any advice
- ***WANTED*** ghonda civic 02 ECU
- Power windows stopped working after speaker install?
- Startup problem - Dead then Starts
- Odd Engine Hesitation
- Weatherstripping Help?
- SRS light on, Need help..
- Engine Vibration
- What can it be?
- Aftermarket Exhaust Manifold vs OEM
- Help Help - stranded!!
- Just took a trip to the honda dealership and...
- Heater, Rad, motor problem?? Help
- HELP! MY battery lights keeps flickering!!!
- fixed auto trans shift delay
- lets see what you think what is wrong with my cooling system!!
- Lock actuator
- New rack and pinion whoa!!!!
- Battery Light Issue
- Tranny Problem--no 5th gear or reverse
- help no ac
- Problems with Power Windows
- bypassing the ac compressor????
- 2001 Civic EX D17A2 5MT Tranny Fluid
- Leaky Door
- Differential Pull?
- car is overheating!!
- No Power Anywhere
- confused on SRS code.
- headlights lost their gloss? What to do?
- How to change fuel filter
- Clutch master cylinder
- Air Conditioning working intermittently
- 02 civic DTC-P1457
- fan switch and theromstat
- Cat Heatshield Rattle
- Shuddering/Shaking around 45 MPH
- Aftermarket bulbs fryed wiring.
- 02 Civic, turn signal and hazard not working
- Windshield wiper problems
- Timing belt broke. Is my engine done?
- Power Steering?
- One last ditch effort to fix my '01 EX, any help is appreciated! FIXED!!!!
- 01 EX 5 Speed Prob. Missed third
- Engine Side Mounting Rubber
- 2003 civic sport new build
- '01 Civic EX Automatic Transmission broken?!
- 01 Civic LX No Spark PLEASE HELP!!!!
- D17 with header ?
- Will not start , Turns over fires rom gauge read 9k
- 2001 Auto Limped to the Driveway
- Warped head after only 60000 Miles?!? Really need some input here
- 2001 civic stalling, backfiring
- VTEC Problem
- Crankshaft Position Sensor
- Removing fenders, rear bumper?
- Help please can't close the trunk and open the gas door.
- 02 EX Air Conditioning problem...
- Wideband help. 03 ex w/ 04 ECU
- bad crank.. where to find aftermarket OEM cranks?
- Need Part number for Lock Acutator
- 01 ex instrument cluster
- Funny noise when making a right turn
- Noise at 2k rpms when accel/decelerating
- white smoke and EGR
- Tranny Stuck HELP
- humming
- Weird noise after I parked my car.
- 01 civic does nothing
- 89 honda civic won't fire
- main relay
- Corroded front stabilizer link
- Ignition/Shift Box Lights
- 2002 civic LX 4-spd auto tranny problems
