View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30
  1. A Sag!
  2. Need help with 95 Civic. PLEASE HELP
  3. Car Temperature when AC is on.
  4. Race Header?
  5. Rusty Window Trim
  6. Tranny CLICK
  7. Question about removing Auto Tranny
  8. Changed my door lock actuator!
  9. Wut is the light in front of my shifter?
  10. How can I check Transmission Fluid level ? (M/T)
  11. Types of Bearing in our Manual Transmission
  12. Need Help Finding Replacement Headers
  13. a\c clutch bad? maybe?
  14. question about IAC valve gasket
  15. help.....i !@#$% my car up
  16. what type of gas
  17. Couple Problems.
  18. Braking Problem
  19. 2003 civic keys suck! cant unlock doors with them
  20. Aftermarket Kamakaze header???
  21. o2 sensor simulator/eliminator
  22. Possible bad coil(s) code?
  23. 04 Civic Si - Harsh 2nd gear engarement.
  24. No Headlights!
  25. my car revs to 1500 in neutral
  26. So how much is warning light going to cost me?
  27. Whats it called???
  28. newbie here......popping noise
  29. 3rd gear pops out
  30. Steering?
  31. gas gauge not working
  32. D17 Engine jerking
  33. '02 CRV ignition coil
  34. Hi, Require some assistance with my 96 Civic DX
  35. d17-d16z parts questions
  36. engine light = uh oh
  37. Manual shift lever viabration
  38. Replacing tranny fluid??
  39. Air/Fuel Ratio problem??? Confused...
  40. checking for battery drainage
  41. HELP !!! Annoying bearing kind noise STILL DOESNT GO AWAY !!!
  42. battery light came on !!!
  43. sqeaky clutch pedal !!!!
  44. Need to fix all these cylinder misfires (continued from an OLD post) Help please!
  45. LX/DX vs EX axle
  46. aftermarket stereo, no antenna signal
  47. strut bar installation messed up my alignment??
  48. First time pulled over!!
  49. Cold start leads to low idle
  50. How do I degree the cam?
  51. Question about A/T Pressure Control Solenoid Valve B
  52. motor flush with tranny fluid
  53. Car won't crank?!?!?!?!?
  54. woosh noise?
  55. okay now a new problem
  56. Damn annoying squeak
  57. Looked far and wide, even SEARCHED! Can anyone provide some TSB PDFs for me?
  58. Alternator/Battery/Gauge issues
  59. Clutch Stuck
  60. SRS Diagnostic Code 9-3
  61. Very Weird Problem.
  62. Checking the auto transmission fluid level.
  63. Screeching Noise
  64. Tranny / Criuse Control Issue
  65. Air bog light on a 2003 Honda civic ex
  66. manual trans shifting issue
  67. Central Locking and Head Unit not working, plz help
  68. HELP with ECU/ECM Part Number
  69. Can I borrow your crank pulley holder?
  70. is it my tranny??
  71. Keyless entry /door locks
  72. timing belt help...
  73. coolant tank
  74. Do chip mods work ???
  75. inaccurate fuel gauge
  76. 7th Gen Manual Transmission Fluid Change
  77. rpms fluctuating *fixed*
  78. Help!!
  79. 2002 Honda Civic LX: Help! Engine stalls/bogs on a cold start
  80. Manual Transmission issue
  81. hey guyz how do u replace?
  82. Having Problem 2001 Civic
  83. Alternator Rant
  84. Manual window..
  85. ATF changeout
  86. Funny Noise Help
  87. Timing/Valve Question
  88. T.D.C. Sensor
  89. Tps
  90. Losing Gas Significantly! Help!!!
  91. bent axle back pipe
  92. Headlight problem
  93. Rattling/knocking noise coming from head
  94. Battery Sensor
  95. timing belt fun...
  96. HELP!!!!!! 2001 - 2004 Civic Ex Auto Trannys.
  97. Clicking Noise
  98. reaplacing front wheel bearings
  99. synchros...read this!!
  100. Idle surge after new head gasket-my mechanic cant figure it out
  101. entire EX set up w/ lx waterblock = no egr valve, how to engage vtec?
  102. EGR Problem major
  103. Keys Locked Inside Help Asap
  104. Weird power loss?
  105. Installing Oil Pressure Gauge
  106. Shifting problem
  107. clutch pedal....sqeaks
  108. Windshield Fluid Light Won't go out
  109. door handle/lock removal
  110. will headers fit on a lx motor?
  111. P1361 Code, Engine Runs with half the power
  112. srs light problem
  113. turbo whistle
  114. weird noise
  115. Brake clanking noise over bumps
  116. Driver side door won't lock or unlock (help)
  117. (UPDATED!) big coolant leak from back of block, cant figure out. HELP!
  118. UPDATED (AGAIN) oil light on. HELP! i searched.
  119. No heat
  120. grinding noise from clutch
  121. Ball Joint or Bushing? What am i looking at here?
  122. acceleration noise
  123. Cruise Control
  124. Harmonic Balancer Bad?
  125. changing alternator
  126. 95 Civic Auto Trans problems.
  127. Help..problems....
  128. rubbing noise under turning and braking after alignment
  129. Auto-Down Driver's Window
  130. changing my clutch on my 05 civic lx
  131. wiring problems
  132. engine cooling problems
  133. *sigh* Need car advice
  134. BAD side mirror prob
  135. seafoam
  136. ex head cylinder
  137. problem
  138. Idle Surge Solved!! Everyone Please Read!
  139. HELP Loud Clunking When Brakes Are Applied??!!!
  140. Weird problem
  141. tach not working
  142. New Turbo Install, Fuel Issue? with pics
  143. Another window thread...
  144. 2000 si with p1129 code
  145. Defoulers For Megan Cat
  146. abs light on?! driving 65mph, car seems like it turns off
  147. Anybody In New Jersey
  148. 01 Lx cracked exhaust manifold what to do?
  149. Crank Shaft Pulley Question
  150. EM2 stiff gear change problem
  151. Knocking sound when clutch is NOT pressed
  152. What to look for- salvaged '02 Civic in S.F.- good mechanic?
  153. Exhaust Rattle During Wet/Snow Driving
  154. 2001 Civic Headliner problems?
  155. Need Help ASAP
  156. secondary o2
  157. Auto to Manual done. Car wont start. Need help.
  158. Question about honda part number. help plz
  159. Hit curb really hard, what is wrong with my suspension?
  160. Turn signal noise whenever the wipers are on
  161. Timing Belt / Water Pump - Odds & Ends?
  162. Passing emissions
  163. Trunk Lock
  164. Auto Tranny Flush at 40K !
  165. Spark Plug problem
  166. Headlight bulb help!
  167. Weird Problem 4000 RPM
  168. all tsbs
  169. What did I just fuck up on my car(tried HID install..)
  170. What did I just fuck up on my car(tried HID install..)
  171. Broken Headlight Adjuster Need Help!
  172. strange noise
  173. BAD vibration between 28-40 mph
  174. Cruise Control Issues with 03 civic ex sedan
  175. More CEL problems!!!
  176. Timing Belt DIY 2
  177. Tuning your VAFC 1 or 2... FYI
  178. The tach is stuck at 3k car shut off.
  179. white smoke... what to do next?
  180. 2007 Vs 2008
  181. Rear suspension squeeks!
  182. Transmission ?
  183. Is this a GOOD DEAL ???
  184. I crashed my car!! How much do you think i'll have to pay?
  185. Need help finding this part!!!
  186. Gauges kinda work???
  187. Strange noise???02LX
  188. Cracked bumper repair?
  189. Hate life....
  190. Indicator lights problem !?!?!?!?
  191. loud BANG from rear - into and out of driveways
  192. What Maintnance Do I Need?
  193. daaaaammmmnn CAR!
  194. Help??? Please..
  195. Clutch won't disengage, fully at least.
  196. car wont lock from the inside
  197. DIY - Minor Bodywork
  198. Need Help Finding Trunk Lid Lock?
  199. Engine Whine
  200. Car won't idle. plz help
  201. Bad gas milleage
  202. Hard upshift...Any ideas???
  203. Clutch Chatter & Clutch Life - Post Your Experiences!
  204. replacing guage lights in speedometer cluster
  205. Oem air cleaner problem !
  206. ABS + Brake light on when cold
  207. Interior Door Handle
  208. List of tools to remove these parts?
  209. 1987 Automatic transmission problem
  210. Car is having problem starting HELP!!!
  211. fuel injector help
  212. My lights flicker!
  213. Rear bumpers??
  214. Shifter moves in 2nd and gears dont engage (continues after tranny overhaul + reman)
  215. head light issue
  216. Power Folding Mirrors on Coupe ?
  217. A question about DOOR HANDLES !
  218. how many oxygen sensors in my 05 civic
  219. Need Good & Economical Place for Clutch Job in Orange County
  220. My 96 ls turbo civic is bogging under load
  221. check engine light? turbo?
  222. CEL P0420 after installing a Cat Converter
  223. 01 civic dies when cold.....runs good hot
  224. CarSound High-flow Cat #94166
  225. belt squeaking
  226. Anyone From Tampa?
  227. 02 civic starting to burn oil
  228. does this mean i need new engine mounts?
  229. No heat while idling
  230. Oxygen Sensor - Need advice!
  231. Found Part # for 01 civic fuel filter....16010-S5A-932
  232. Question about changing thermostat
  233. ::: SOLVED ::: Idle problems.. uhh Help please.
  234. tanny dead?
  235. only when it rains
  236. Rubbery Shift
  237. What oil/filter do you use?
  238. how to reenable vtec w/ lx engine harness (full ex setup)
  239. Cruise Control..HELP!! >>>
  240. 1992 vti civic pressurizing coolant system
  241. hit a puddle, possible hydrolock?
  242. Driver Seat Loose
  243. How to change engines out
  244. steering issue?
  245. 205,000 miles of reliability and now this...
  246. Idle surging with other problems HELP!
  247. Power Steering Fluid Leaking Into Car
  248. 2001 Civic - Fuel Door release problems - HELP!
  249. Electrical Guru's Please Help, Dashlights Blow Fuse
  250. Gas milage problem
