View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30
  1. Steering Noise Problem
  2. Suggestions Tachometer
  3. 7th gen
  4. Brake Pedal Click
  5. 01 Civic issues - SRS light & radio
  6. New Alternator? Need Help
  7. My driver seat rocks back and forth!
  8. questions on throttlebody
  9. Is My Motor Blown?
  10. Gauge Cluster reads wrong
  11. leaking inside coupe doors
  12. Rear power window problem
  13. keyless remote or door actuator?
  14. 2001 problem with door lock/tumbler mechanism
  15. Honda Civic Tranny Scrape HELP PLEASE ASAP!!!!!!
  16. 2003 Squeak when I let off the brake
  17. Yet another tranny question/concern....
  18. wiring an 03 sedan cluster into an 01
  19. Can somebody help diagnose my problem?
  20. NRG seat install
  21. burning smell
  22. coolant leak
  23. Vin location on engine
  24. Tricky Problem
  25. Help Me Please!!
  26. Front bumber swap
  27. Defrosting outside mirrors...
  28. ingalls stiffy
  29. question about stock intake
  30. H/G Issue?
  31. annoying engine noise
  32. radiator installation
  33. installed header and test pipe
  34. My Civic's getting HOT
  35. Nasty Fender Dent!
  36. Intake Air Temperature Sensor
  37. need an answer or two?!
  38. Rear View Mirror Mod
  39. 100k tune up
  40. Grinding noise while ACCELERATING.
  41. Everytime I put my car into park
  42. m-tranny help
  43. fustrated please help me b4 i drive off a cliff
  44. name of this tool
  45. RPM's fall after shift in between shifts
  46. I got a question about the rear seats???
  47. Timing belt/waterpump question
  48. Leaking injector, maybe seal, injector need to be changed?
  49. Engine Rattle/Vibration
  50. Weird sound when accel from dead stop
  51. Please help !!!!!!!!!!!
  52. Blacking Out Headlights!!!!!!!!
  53. Two quick questions
  54. Burnt Valves
  55. whats wrong?
  56. Hesitation?
  57. 91 accord - how would oil end up in distributor cap?
  58. Dash Noises (Creaking)
  59. oil in intake
  60. SRS light stay on
  61. How do you remove the ECU???
  62. HELP - Pin-out for OBD2 port
  63. AC/Demister/Circulation Lights Issue!
  64. clutch has pressure but car doesnt go anywhere. HELP!
  65. need new clutch
  66. check engine light threw a weird code
  67. Tranny Noise When In Reverse & Clutch Petal Is Pressed
  68. oil in intake
  69. Tranny question.
  70. front crankshaft seal
  71. 01 civic noise problem
  72. o2 sensor??
  73. hood latch hood latch help
  74. possible timing belt need replaced?
  75. orange check engine light soft code?
  76. 110k mile maintenance
  77. Clutch Problem/paint Shop
  78. Help
  79. 95 hoda civiv dx no spark
  80. Uneven wear on brakepad?
  81. High Beam lights signal??
  82. My Civic Wobble In The Back Alot Why?
  83. greddy evo
  84. Smoke & Burn't Electrical Smell under Steering Column
  85. tranny/engine noise
  86. car doesnt go, checked everything...
  87. SRS light problem/check engine light
  88. Special slave cylinder knowledge required
  89. Squeak Noise When turning
  90. Mirror
  91. new taillights problem
  92. Battery light flashes
  93. IS it worth it to try and repair a damaged bumper?
  94. Pass side seatbelt locked
  95. 2001 HX CVT tranny fluid change.
  96. Head Gasket Replacement Experiences
  97. CEL + 80% compression loss....HELP
  98. hondata issues
  99. Rough Idle? I Got You Covered!!!
  100. A/C problem, filled it up, sounds better but clutch/compressor makes noise
  101. Installing Fog Lights on 05 LX Civic
  102. new transmission
  103. HID harness problem!!!
  104. 2001 auto tranny problem, can anyone help?
  105. P1607 EGM/PGM Internal Circuit Failure A
  106. Backed into another car. new rear bumper cover and tail light
  107. When should Radiator Fan kick on?
  108. sqeeky pedals
  109. Rought idle sometimes
  110. car wont start
  111. Where is the starter?
  112. pcm replacement
  113. Manual transmission grinding in third gear
  114. steering wheel make creek...
  115. Remote locking doesnt work... locks dont go up or down. But when using a key they do.
  116. front control arm bushings
  117. Son of a monkeys unlce!
  118. Battery light flickers
  119. Annoying noise from "A Column"!
  120. Problem after ingalls "stiffy" install
  121. Speedo Not Working: Any Ideas
  122. Prepping Block and Head surfaces..
  123. Should I be Concerned?
  124. Marks on tops of pistons from valve float (PICS)
  125. fan blower/hissing noise
  126. A/C prob 'n removal *prob solved*
  127. Stupid clucth problem! Can't figure it out...
  128. Tailpipe/Muffler Rattling
  129. auto tranny engine going in a 5sp
  130. Crank pulley/woodruf key problems
  131. G'Damn Input shaft bearing again!
  132. Help! Im a Dumbass
  133. Which Helm's manual for our 7th gen??
  134. removing clear coated over stickers
  135. jack stands
  136. Infamous Rain Issue
  137. loose (more turn) steering wheel
  138. Crazy noise like theres a small plane in my fender
  139. noob question/crank pully
  140. What do all these parts mean?
  141. Civic starts when it wants to.
  142. Goofy headlight problem
  143. Dash lights & Parking Lights & Radio/Clock Died : HELP!
  144. timing belt
  145. no oil pressure
  146. I think the people at the car wash messed up my car!
  147. Malfunction Indicator Wtf Help!
  148. Radiator/Temperature cooling problems
  149. revo short shifter
  150. Knocking Clunking Sounds Over Bumps
  151. valves, lifters and springs
  152. clunking sound when taking off
  153. over heating when i stop moving
  154. noise from car/transmission
  155. GRRR!! Need help on fixing this..
  156. deteriorating idle
  157. burnt wire after dvd in dash install
  158. Running Lights????
  159. Gauge/Instrument Panel Lights
  160. Camber Problem?
  161. 2004 Sedan Civic EX Shocks/Strts ok on 2001 Sedan Civic LX?
  162. windows foging up
  163. Help!!! With Manifold and cat converter
  164. Clutch Problems
  165. Solution -Grinding noise while acclerating in 1st and 2nd gear
  166. UPDATE - blown HG - but its running again, off a tooth on the timing
  167. Attention 01-03 civic owners with headlight issues
  168. 04 LX tranny slipping
  169. Taking off OEM optional wing and making the stock 3rd brake light work
  170. Compliance Bushings Sabotage?
  171. Clicking when accel?
  172. Has anyone ever had this happen?
  173. sqeek!!
  174. lighting problem please help.
  175. its alive!!
  176. Shift cable problem?
  177. couple of car problems
  178. Question about shop doing my transmission (manual)
  179. Tranny Flush
  180. Header bolt snapped in half!!!
  181. door lock issue *can anyone check this on their civic*
  182. Front Driver Side Suspension making Grinding noise
  183. EX exhaust swap.. not a repost..
  184. new wheel stud, new noise.
  185. code P1259-replacement options
  186. Got Rear Ended! Will this be totaled?
  187. Headlight Alignment Issue (after Bulb Replacement)
  188. Need Help...A/C headache.
  189. 05 VP Auto Coupe + Brake noise
  190. 2002 HX stutters after replacing o2 sensor
  191. Car starting slow during morning
  192. Parts needed for Timing belt change.Please help out.
  193. WTF wierd problem help?
  194. ABS Grunt Noise???
  195. Fixed transmission and now suspension is acting up
  196. Hood Latch Cable Replacement..
  197. Air fuel ratio sensor or oxygen sensor?
  198. Help me fix my Civic problems
  199. airbag didn't deploy
  200. EGR Problem how do i fix
  201. slight squeak
  202. Got crashed into...
  203. transmission clanking noise
  204. Car shakes when engaging clutch in first
  205. I think i lost my trans.....
  206. Fog light switch help
  207. ohh snapp - new header
  208. Oil Question
  209. Diagnose my problem.
  210. Air Condensor cooling fins
  211. Air Problems
  212. My 2001 LX won't start, Please Help!
  213. 04 Hybrid problem
  214. aftermarket clutch kits for Civic '01 (EM2)
  215. What would need to be removed to switch trunk lids with someone?
  216. 3rd Gear kind of grinding :-s
  217. Backlight problem
  218. HOLY CRAP! Never heard this noise from the trans before
  219. RPM/Other small problems with my 02 Civic EX
  220. Anybody's paint crack like this?
  221. Alternator Good or Not?
  222. Somethings wrong.. Help!
  223. Another Whistling Question
  224. Hit a puddle and get this grinding/ loose noise?
  225. will 01-03 mirrors fit 04-05?
  226. obdII code po139?
  227. Brake light out, yet bulb is fine
  228. Exaust Rattle?
  229. How much are 2001 civic keys?
  230. manual tranny noise....
  231. Urgent help:stuck in rev cant put in park
  232. Help!! Sluggish Performance
  233. Autotrans cooler
  234. overtightened valve cover bolt
  235. Engine light on
  236. Noise?!?!?!?
  237. Click sound on clutch engage. 2002
  238. Service Recall
  239. qUICK qUESTION
  240. How to adjust shift cable?
  241. cluster not working properly
  242. transmission questions?
  243. Condenser is leaking...
  244. Another squeaking noise
  245. new turbo= overheating
  246. Headlight's On Dinger
  247. Squeaking/hissing/whinning noise coming from engine.
  248. I think the alternator bolt sheared off.
  249. Squeal Like A Pig Boy!
  250. Battery light comes on?
