View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30
  1. viper alarm stopped working
  2. Exhaust Hangers?
  3. Damaged rear bumper cover
  4. my car idles to low
  5. blinker issue
  6. Rubbing Wheels
  7. n/a blow off valve
  8. engine cut off.....what happened
  9. Hood Won't Open
  10. Possible electrical/alternator problem? Need help.
  11. easiest way to remove tint?
  12. Noob Question, how to set the clock on a 2002 Civic?
  13. New ECM = Progam Keys?
  14. viper 791xv alarm problem
  15. Broken side mirror - can I use glue to fix???
  16. Minor grinding between gears
  17. Quick question
  18. Thrown Rod Bearing on D17a2
  19. Heater problem?
  20. Either shock or spring bad need advice
  21. coupe to sedan exhaust?
  22. d17...poor little thing?
  23. Need some Help please
  24. Im going to get my tires re-aligned tomorrow, what are OEM specs?
  25. B16/B18 head on D17?
  26. Need help - Nuespeed rear tie bar
  27. how rigorously to follow maintenance schedule?
  28. Motor Mount Problem
  29. Axle question
  30. Header and straight pipe. WORTH IT???
  31. ticking or knocking?
  32. lock assembly or actuator?
  33. Blower Motor
  34. what did i do?
  35. fuck zip ties
  36. steering wheel/column
  37. Clicking Noise
  38. 4th spark plug coil oil???
  39. wont always start
  40. Check Engine lights came on.... But I felt nothing wrong with the car!
  41. "Timing Belt" broke at 11,000 miles...!!!!
  42. headlight fog!
  43. Installing springs= problem @#$^%!
  44. intake problem please help
  45. Stripped bolt!! :(
  46. Apexi' V-AFC II Problem
  47. *removed
  48. Emergency! Tie Rod Warped
  49. Problems with the rear-windshield integrated antenna?
  50. why is it doing this?
  51. Rear Brakes Squeeking!!!
  52. civic tranny shifting real hard
  53. 2002 Civic No Start
  54. need some big help...
  55. Lightpole=Hell... take a look
  56. big problem need help
  57. TYC Help.
  58. maintence light won't go away
  59. Where is the Fuel Filter located?
  60. Aftermarket Alarm/Factory Alarm/Car Starting Problem
  61. Auto Transmission prob
  62. headers rusting (not even month old)
  63. 17s creaking noise
  64. Defrost
  65. Engine cuts out in civic
  66. MIL comes on out of the blue
  67. New Rotors, New Pads = Still shuddering
  68. New Rotors, New Pads = Still shuddering
  69. 02 EX Coupe Intermitent Overheating
  70. Steering vibration
  71. loud valve or lifter noise on d16y8
  72. no catalytic converter = engine light?
  73. Ghetto Brakes Make Grind When ABS
  74. Handbrake
  75. Squeak Noise on Seat when turning
  76. Dead battery, need to reset immobilizer?
  77. ABS light and Brake light problem?
  78. Need to replace windshield wipers!
  79. Tranny cooler install help pls
  80. Horn doesn't work...
  81. Trunk carpet ???'s
  82. HELP: Squeeking from rear drum -> not worn pads
  83. was thinkin?
  84. hesitation????wants to stall
  85. vafc 2 ? I need a little insight ?
  86. emergency flashers
  87. Vehicle Speed Signal Circuit (VSS) question
  88. '05 civic SE InDash CD/MP3 player not working properly
  89. Rear Bumber Removal for Popping out a Dent
  90. Shifting Gears & Double Clutching
  91. Ebay OEM Fog Light Kit
  92. CEL on, P0420 Code threw
  93. Airbag question
  94. A/C Problem
  95. 01 interchangable parts ??
  96. So my car makes a whoosing noise
  97. door lock problem
  98. wants to... but just can't stall. help?
  99. trunk lock rattle?
  100. Daytime Running Lights won't go off.
  101. Painting Intake Pipes?
  102. Help Honda Warranty WTF!!??
  103. Car shakes when come to stop & while its idling
  104. Clutch might be bad/ its easy to grind in 2nd & 3rd gear Y
  105. Removing side air vents?
  106. electrical problem....
  107. Steering wheel viabrations
  108. Grinding noise....
  109. Need help. Thinking it might be clutch
  110. Brake and clutch questions
  111. car vibrates
  112. Car overheating NEED HELP
  113. Belts squeeling.
  114. Help with installing AEM short ram
  115. cell phone on seat
  116. C/F Hood Not looking right help
  117. Power steering problem
  118. Got some A/C Problems
  119. Shop Manual for 2001-2005 Coupe
  120. Enough to pass SMOG??
  121. $500 to replace o2 sensor???
  122. Check This
  123. yeah yeah, what is up with my Tranny!! Shaking!
  124. Front Main Seal Replaceing!!!
  125. Front Main Seal Replaceing!!!
  126. Cold Weather
  127. Cold Weather
  128. engine coolant problem/little or no heat at times
  129. Vearing to the left bad , until i hear the pop...HELP
  130. heater: burnt smell
  131. need help please!!!!!!!!!
  132. how to adjusting wiper blade?
  133. A/C Question
  134. Guages having problems! help!
  135. Can Thermostat go bad, if Thermoswitch Sensor went bad?
  136. Gas Mileage
  137. Can warped rotors cause steering wheel viabrations even without brakes applied?
  138. Headlight issues (stock '01 EX Coupe)
  139. need help asap!!!
  140. got a problem
  141. Glove box rattle?
  142. strange problem please HELP
  143. Temp Gauge is actin' a fool!!
  144. Programming 2001 Civic Sedan Key Fob
  145. Passenger side DRL (Daytime running light) having problems
  146. Cam gear help>>>>>>>>>>
  147. side motor mount
  148. windows off track!!! need help!!!
  149. Blinking "D" on Gauge Cluster & no acceleration
  150. noise during acceleration and rough idle
  151. Gripforce Clutches on Ebay may be a winner!
  152. "Knocking" from under car..
  153. Oh s**t, what have I done..
  154. Broken Front Bumper
  155. Car shaking in 3rd gear
  156. BTS, fog light removal?
  157. cleaning vtec solenoid screen
  158. Need to find a Carbon fiber hood molding
  159. Rattling, Noisy, clattering Greys Endlinks Help
  160. Wet tires+ wet road..but no tire spin...just.
  161. Undiagnosed Problem
  162. labor cost to replace shocks
  163. gauge cluster
  164. Sloppy feeling in Suspension
  165. Bulb fell inside reverse light
  166. Speedo question
  167. ABS Light on this morning
  168. Strange squeak + rattle is killing me!
  169. block questions???????
  170. Car can't go up to over 30mph this morning with reving to 5krpms?!
  171. Header Bolt
  172. Tranny lurches
  173. A/C Pulley PROBLEMS!!
  174. how do you change the air filter?
  175. Where is the ECU located?
  176. Front left brake... abs?
  177. UPDATE - Installed! - Gripforce Clutches Came Through! Parts are here!
  178. Fix before selling/trading?
  179. Loud whining when put in reverse on cold start
  180. help**crazy noise think its the axle!!!
  181. noise when driving slow over stuff & turning
  182. noise when driving slow over stuff & turning
  183. Help! Crashed my car yesterday
  184. suspension question?
  185. Revving, but no speed?
  186. center consul problem
  187. Help, These headers didn't do anything..
  188. Engine Shuddering?
  189. Pumping Gas Problem
  190. Valve Cover Swap, Anyone done this?
  191. Outside Smell When A/C is On
  192. Idle Problem After Throttle Body Install.
  193. Coolant leak
  194. *HELP* Civic WONT START! TRIED EVERYTHING
  195. horn dying..?
  196. Light out on oem tach
  197. Maintance Required
  198. Remote lock & not registering open door
  199. ***SRS problems***
  200. hi whats this (pic)
  201. Sohc Vtec
  202. Water sprayer for wiper broken
  203. Front bumper issues
  204. Power loss
  205. Odometers inflating distance traveled by 2.5% to 4%
  206. Transmission slipping... WTF?!?!...
  207. Knocking Noise
  208. Foglights Problem
  209. Transmission Problems...
  210. Sell car with transmission probkem?
  211. car wont start
  212. Headlight Problem
  213. i bought a wrecked EM2. .
  214. where can i find an AERO KIT ?
  215. Headlight Clip Help!
  216. 04 Civic VP HEADERS ?
  217. 01 civic shifter & noise ?
  218. Apexi N1 muffler question
  219. 01 Civic Stiff Shift
  220. No Heat....IT'S FIXED!!!!!!!!!!!!!!!
  221. Arrgh!!! No Power!! At all!! WTF??!?!
  222. Dealership visit = new master cylinder
  223. quick question
  224. Trouble Starting in Cold Weather
  225. Keeps shootin fuse....
  226. brake / vibration problem
  227. oem mirrors
  228. replacing head gasket
  229. Car bogs/cuts out... 2002 LX 5spd
  230. AC Line Vibration
  231. Dimming headlights with A/C, rear defrost, or power windows
  232. Need help ASAP (for my accord)
  233. 01 civic steering & clicking sound
  234. 04-05 front bumper question
  235. Wreck!
  236. cruise control no longer working
  237. Steering noise problem!!
  238. Battery/alternator issue??
  239. Tranny problem
  240. Car dies while in motion
  241. I need help ASAP w/ Ingalls ETD
  242. oil in my spark plugs + white smoke + loss of power and stalling = help please!
  243. maint reqd light on, wtf?
  244. Coolant System Serving Question...
  245. squeeking electric window?
  246. 2002 Civic cluster & mileage problem!
  247. 2000 Civic EX Clutch Problem?
  248. CarMD?
  249. Short Ram or Cold Air? What brand? No Idea!
  250. Honda CRV - problem - Timing Tensioner Pulley
