- Where To Get The Lower Control Arm Bushings?
- Radio Screw Size?
- Ticking/Rattling noise at 2.7k RPM
- What else is needed for Timming Belt change?
- Oil pan gasket change
- Brakes make grinding noise and feel gritty....
- Ball joint and KNUCKLE
- Engine Delay?
- check engine light
- dome lights and remote wont work when car is off?
- stalled and wont start- glowing cat
- stupid car wouldnt start
- 4k RPM Rev limiter, and 500 RPM drops for split second
- rear lower control help!!!!
- Sub problems
- Problem w/ stripped plastic screws at the bottom ends of front bumper
- Car stalled...why??
- Radiator fan(s) not working.
- Freakin' froo frag windows...
- CEL Code P1456
- Manual Transmission Fluid Change...
- Bunch of questions...plz help...
- Ball Joint question.
- Transmission problem
- Replacing 01 Civic Ex Front Wheel Bearing?
- exhaust shakes car slightly
- *******clicking Noise And Power Loss******
- brakes question
- help 7thgeners! noise from bEehInd!
- AH! Air in Radiator, Coolant pushed to Reservoir
- potential tranny prob
- Civic engine swap?????
- waterpump prob.
- front inner fender plastic warping
- srs light acting weird
- air box(es)
- Please someone help me
- CEL on and sometimes flashing, lower MPG and performance. HELP!
- car turns off when wheel is turned need gas to start
- bosch spark plug wires, and platinum = bad.
- Alternator problems...
- Slipping clutch when cold
- Blinking Battery light
- SRS Light and Paperclip DIY
- A/C not blowing cold air. HELP!
- A/C light stays illuminated
- A/c removing
- check engine light is ON!!!!!!!
- Need help, car shaking
- What can it be?
- Steering Wheel Clicking
- need custom body work
- Condensation, heads, get it out?, help...
- Sound / Vibration when I hit a puddle?
- AHA! It was a loose injector plug wire
- intake fire???
- shifter fork????
- Clicking in manual tranny got really bad...
- Misfire on cylinder 2
- uphill and rolling back..
- cruise control still not working
- Horn not working
- Heater problem
- speedo help please!!!!??
- why not automatic????
- Antifreeze Coolant EXPLOSION
- Problem with 1st gear
- Problem with Alignment
- I've never heard of the RPMs fluctuating.
- gasoline tank reading...
- Help me Diagnose a Problem
- Problems with Megan Test Pipe
- car hesitates when floored
- power door locks
- Grinding in 2nd gear........
- steering wheel shaking alot..whats wrong
- exhaust manifold
- Rattling Coming from under Dash
- Looking for an 01 EX header
- My transmission is dead, any suggestions?
- Exhaust Problem
- hood adjustment
- Blinker problem.
- 2002 Honda Civic & Cluster Mileage ?
- Stock Spoiler Rattle Help
- weird sway...
- Service Light
- Dash, panel, speedometer LIGHT not working.
- still rubbing... any suggestions?
- Dogfood in my resonator!
- maintenance req'd lite on - why?
- Dash, heater lights don't work.
- Cluster issue.
- check engine light blinking 5 times?
- Front drivers side clunk/knock strut area
- High Pitch Rubbing Sound When Reving Engine
- Windshield Wipers are going CRAZY!
- I think i know why SRS light stays on... Seat belt not working?
- signals and hazards
- Dash Lights Help!!!
- Below 50 Degrees, Power Steering Whines for a few seconds
- Strange noise from unknown location
- Fuse on circuit board behind guages?
- 3rd Gear Scrapes Please Help
- CF Hood Problem
- Need help diagnosing ECU problem
- Problem Relating To Door Panel
- double start anyone???
- Driver Door power lock problem ***
- engine stumbles when cold
- p code = p1248 - need help!!
- 01 civic car shakes
- 01 civic brakes
- Rattling Noise From Aem V2 Intake
- A bunch of codes!!! Totally random.
- Scuffed/worn area on side of rear struts lower section
- Center console/armrest hard to open?
- 2004 civic lx Lost code help!
- Matching dents in rear side panels
- Strange sound from 4000-4500RPM
- Replacing power outlet cover
- CEL came on last night, car kept stalling out, knock sensor?
- took a sharp turn and car just died!!!
- car hesitates when floored, NOT TURBO
- Exhaust Warranty
- engine eating up alot of oil (UPDATED!!!)))
- Low beams don't work
- replacing motor mount
- Anyone convert injen CAI to SRI?
- Couple problems ever since ran over curb..
- Trunk/gas lever won't pull up HELP PLZ!!!
- Warranty Question...?
- Accord seat belt light problem
- bumper repair
- Stearing wheel removal
- [B]Battery Light is on even though i have a new battery[/B]
- Headlight warning not working
- Pulling when accelerating PLEASE HELP
- pops out of gear
- ECS light came on
- Car won't start!!! PLEASE HELP!!!!
- Loose steering
- Stiff clutch
- need help installin OEM headlight switch.
- Honda Reliable?
- Braking from high speed = shake in front end...
- vertical door/wires question
- Ignition Trouble Help Needed!
- What the F is vibrating behind the panel?
- Click click click noise and minor 3rd gear problem??
- Glovebox rattle.
- transmissions... they suck
- SS Teins Blown Shock!
- Honda Civic 2001 Lx Coupe how to take off head unit?
- Serious Oil Issues
- vtec problem
- Need Help my RPM drops and car dont move?
- best shift points to shift my gears
- DX to EX exhaust swap - my luck = none!
- CAI fire
- Help!! My Cf Hood Won't Close!!!!
- busted cruise control
- cel problem.help ...
- Help, car shaking !
- Backfire?, i need help
- hey fellas
- Calling all experts! Ive got a good one.
- Turn Signals Died
- Throttle Position Sensor
- Car shakes when clutch engaged.
- Aem V2 - Car Automatically Goes!
- Smoking under hood
- trying to peel out problem
- Shifting Problem
- Battey Voltage
- rpm guage wont work
- s-afc
- Why can't I find the dummy SRS fuse?
- Issues with Door Locks, Wipers, Lights, etc.
- Hood fitment problem
- Biiiiiggggg Problem
- Installing New Tranny New Clutch!
- accessory socket help?
- Squeaky noise when turning off the car
- Just when you think its fixed.... HELP
- Need Help! Door Panel Removal
- Sos Help!
- Noise while driving, maybe steering pump
- Hopefully simple
- LX to EX exhaust problem
- broken exhaust mani bolt stuck in block. any suggestions?
- Accidentally Redlined in 2nd (Auto)
- Steering shakes when breaking!!
- Oxygen sesor and check engine light
- Alternator problem need help fast
- Dash light issue
- Squeak Squeak coming from the rear passenger
- Stuck Speedometer!!
- Check Engine: Code P1607
- 2002 EX heat control knob
- RPM's above 5k drops back to Zero!
- Finally installed my Actuator...
- I am puting new 19"s on, do i need to have to ECU reprogramed??
- power window troubles
- hood problem
- installed coilovers...now have a problem
- Battery Issues?
- Wobbled front part of car
- 04 Headlight Problem
- OEM Headlight replacement or switch to Projector/HID?
- Need some help with this one
- Bent wheel be repaired?
- Something just fell off my civic.
- How far to torque exhaust-manifold screws?
- i know its holiday but please someone help me!!!!
- My Engine Light is On, any suggestions
- rattling noise in OEM muffler
- ECU testing
- New Clutch Help!!!
- short shifter
- airbag light on.....
- PLEASE HELP ME my CEL is on and key light is flashing
- Cold weather problems!!!!!
- Alarm Issue
- carbon fiber hood damage
- P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
- any thoughts?
- Warranty for emissions issues?
- Transmission Issue During Cold Startup
- Weird sound when in Drive
- someone help me plase...!!!
- Choosing the right Oil...
- HELP! car making weird sounds, *video
- HELP! car running really wierd no CEL. URGENT
- How to Reset Keyless Entry in default mode?
- intake
- Possessed Dash Guages
- Taking off rear brake drums
- Looking for a part
- My exhaust is farting!
- Buzzing/whirring sound during ignition
- Why does it want to die?
- Rear Driver Side Tire bouncing???
- Help!! My fans wont come on
- Annoying Brake
- brakes not as strong as others
- can ex parts work for a lx model?
- Seat Belt Assembly Help??!
