View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30
  1. My Civic won't start PLEASE HELP ME
  2. Squeaky chirp in the front end... stumped....
  3. Ball-Bearing on Pressure Plate??? and one more thing HELP!!
  4. Can't get screws off intake box
  5. Cracked Manifolds?!
  6. How to silence your trunk , the CHEAP way
  7. Headlight Help!!!
  8. grinding noise with motor, sometimes??
  9. Got a Problem
  10. slowwww retracting seat-belts
  11. Passenger side Power window problem
  12. suspension problems
  13. A/C Whistles
  14. Car wont run *pics*
  15. Weird electrical problems
  16. 04+ not OBD2??
  17. Driver's Mirror not work but Passenger's Is
  18. nuts and bolts...
  19. If i get a new ecu with the key with i have to reflash the ecu or do i need anything
  20. 6th Gen HX and CVT
  21. Yikes! CEL Ecu reset and radio problem! HelP!
  22. Help me out guys!!! Stripped bolt (pics)
  23. clunking noise from shifter assembly
  24. Problems with Injen CAI install
  25. does engine check light usually come on when installing aftermarket turbo?
  26. Installing Fog lights gone horribly WRONG, NEED HELP
  27. AC-HVAC Diag Trouble Code #9
  28. Broke the tranny mount
  29. Trip Odometer partially burnt out
  30. A/C Lag
  31. A/c, power locks and e-brake light malfunctioning!
  32. A/C Not functioning as well as it should.
  33. What is a Fender roll and how is it done?
  34. Rpms Going Crazy...honda Techs?
  35. Weird steering related noise...
  36. what the ****. (Headunit 02 civic ex)
  37. Left Rear Vent window replacement (4 door civic)
  38. synchro replacement?
  39. civic exhaust
  40. P1361 Code - Help!
  41. Belt squeeking...?
  42. Quick help oxygen sensor
  43. Steering Wheel
  44. Drivers Side Door Lock Problems
  45. Need Help Quick
  46. vtec help
  47. What parts of Revo SS to grease?
  48. My car is NOT WORKING!! HELP!
  49. Car Start Up Rpoblem
  50. headlight not working
  51. exhaust rattle
  52. Timing Belt problems
  53. subframe alignment marks? Why?
  54. auto tranny noise shifting into D or R
  55. still cant fiqure out where my leak is commin from !!
  56. Exhaust problem too louuuud
  57. Manual transmission noise.
  58. The latch that pops the hood broke off, how do I get my hood open?
  59. changed Spark Plugs and now i smell gas
  60. Replacement of black molding/weatherstripping on coupe door?
  61. honda civic check engine code P0172 Fuel mixtiue rich
  62. help- lost a bolt where can i get a new one??
  63. 02 Civic Ex Wont start!!
  64. A Few General Questions
  65. Sticky clutch pedal?
  66. my car is driving me INSANE! HELP
  67. Clicking noise when I turn
  68. Oil pressure help
  69. windshield washer light
  70. P-2647 ????
  71. No Clutch....Pedal issue..PLEASE HELP
  72. SRI+hot weather=overheating (heads-up)
  73. Civic TSB site
  74. P1456 & P1457????
  75. Squeek from rear window area
  76. Gauge Cluster Help me I'm falling.
  77. 99-00 cf hood for 01???
  78. Help ASAP need done by 5 today.. plz.
  79. Help plz this is wrong section but need done by 5 plzzz
  80. TYC projectors - low beam probs
  81. Need Help With No Power!
  82. Installing Gauges but confused on a few things help would be appreciated
  83. how can this happen? can i fix it? PICS(56k no)
  84. help?!
  85. Problem after timing belt replacement.
  86. Civic expertise needed Please Help
  87. Spots on rear windshield.
  88. Radio Code
  89. HELP!!! Right Front Brake Dragging
  90. Question concerning gears
  91. SRS light
  92. Dash lights probelm
  93. oil light after headgasket replaced NEW INFO POST #27
  94. Exhaust problem.
  95. a/c button won't go out
  96. 2k1 Lx Struts...
  97. Question About Cat Pls Help
  98. Paint Issue...NEED HELP
  99. ABS and Brake lights ramdomly lighting up + F the dealer story.
  100. Humming noise , sounds like im in an airplane
  101. my key gets stuck in ignition
  102. Both Headlgihts Out At Same Time
  103. oil sending unit? where?
  104. alternator swap
  105. VTEC cut off, help!
  106. Tech Serv Bulletin 205
  107. Engine won't run smooth - advice needed
  108. Lug Lock Breaker
  109. What to do??!!
  110. Worried! Funky Whistle Noise
  111. keyless entry
  112. Transmission Rebuild Question
  113. paint got eaten off...
  114. Exhaust Manifold
  115. NEED HElp - ASAP
  116. WHo has replace crank bearing yet?
  117. Rewiring Spoiler LEDs
  118. swap
  119. Mileage
  120. Spark plug question.
  121. 02 Sensor and check engine light codes
  122. 02 Sensor and check engine light codes
  123. Help!! idle rough!!
  124. issue with 2nd gear
  125. A sure fire was to tell???
  126. Paint and Body Maintenance and Repair
  127. Running Too Slow??
  128. don't use bosch plat. 2 plugs!
  129. power steering suction line
  130. passenger side axle stuck in hub
  131. HELP NEED a D17 engine
  132. What's wrong w/ tach signal?????
  133. Replacement Struts
  134. Knocking noise in suspension
  135. Turbo problem!!! Help fast.
  136. i hear a scratching sound by my right front wheel
  137. Ripped boot
  138. Compression test results (good or bad?)
  139. Help.... Headlights!!
  140. Help.... Headlights!!
  141. Air Conditioner Smoke/Mist
  142. TSB for tranny
  143. Engine Troubles???
  144. Trunk / Gas Lever Cable snapped--HELP
  145. '01 Test Drive: Road noise from Rear...
  146. Broken Keyless Entry
  147. A List of Problems!!!
  148. Just bought a used 2004 honda civic
  149. Someone has got to know the name of this piece
  150. Lug bolt twisted off
  151. Spark plug question
  152. Hazard button light and AC button lights flicker
  153. Daytime running light issues
  154. So my car is at the dealer today
  155. Serious Help!
  156. low beams not workin!
  157. Rear Seal Leak on 04 Canadian SE?
  158. tsb replacement
  159. Dead Battery???
  160. Hope someone can help me!!
  161. 01 EX Engine cranks but won't start.
  162. Please Help!!!!!
  163. Need an EX stock head
  164. aftermarket steering wheel horn prob
  165. Missing oil after change!!!!!!!!!!!!!!
  166. All my engine oil is gone!!!!!!!!!!!
  167. Check Engine light and Code
  168. finish on rims
  169. hit a curb...:(
  170. Wideband Problem
  171. Trunk Weatherstripping Problem
  172. cabin filter location(s)
  173. 02 Civic SIR EP3 (hatchback) K20A3 i-vtec motor Whining noise!?!
  174. I need help finding
  175. window wont move
  176. More Problems-why Me?
  177. Adjusting headlights on 02 civic
  178. Lifespan of Tein super street coilovers
  179. Car shuts off then turns back on while driving
  180. Squeaking/Clanky sound from front right wheel area
  181. Obd P0304
  182. Bleeing the clutch
  183. using gas with the ac on
  184. Engine cut off coz of AEM V2 ?
  185. problem with seat belt button
  186. AC and loss in gas mileage
  187. where to buy this little thing?
  188. 2 prob:bad sumthin+radio
  189. Clutch Alignment Problem
  190. TRansmission Oil question. HELP PLEASE.
  191. Bad Alt. New Brushes?
  192. Back of car has suddenly lowered in height, while front has raised?
  193. Water Temperature Gauge Inoperable
  194. clutch/release fork problems? what a bad day...8(
  195. just installed radio, now gauges wont light up
  196. New Cruise Control Issue???
  197. Headlights out
  198. Need Dents Removing ASAP
  199. Turn signal problems
  200. Craftsman Bolt out works!
  201. Almost $500 in repair for replacing power steering pump
  202. Can You Find It?
  203. Clutch fork problem
  204. After my trans install
  205. cabin air filter....
  206. Slipping clutch??
  207. suspension noises after drop help!
  208. Turning right- deep growl
  209. Type-R Wing Mirrors
  210. Help, car is in safe mode!
  211. Axle problem
  212. Anyone else needed a new tranny and engine mount yet?
  213. 2001 Civic Power Window problem
  214. Clutch Pedal Pop- i know what causes it- need answer.
  215. disconnected battery - need stereo code
  216. airbag light in 04' on - NEED HELP
  217. help headlight problems
  218. 2k4 Civic Clutch problems
  219. One touch window button and axle boot
  220. transmition/clutch problem
  221. PSA Announcement
  222. Need help getting this console piece out/in
  223. cabin filter
  224. blended oil
  225. blended oil
  226. squeeling noises after changing alt belt
  227. 02 Civic ground effect fitament Problems
  228. D17a1 <=> D17a2
  229. projector headlights (aka halos)
  230. Dealer Drilled Their Emblem into my Car, how to take off?
  231. wierd steering problems
  232. Dents in carbon fiber????
  233. Weird Knocking Noise...HELP!!!
  234. please help
  235. Problem with my car
  236. Funky idle
  237. Tread wear and clutch engagement sound.
  238. 2002 Civic EX Auto Transmission Problems
  239. Under construction
  240. Throttle Prob.
  241. Is it hard to tighten a pulley ?
  242. Wierd grinding sound from wheels?
  243. '01 Civic EX Issues - Need some help
  244. Interior panel pushing in?!
  245. My tire has horrible inner wear
  246. Water Pump replacement?
  247. Gas Light
  248. I'm at the honda dealer and here's what they said.
  249. After DC header install
  250. HUGE PROBLEM - i think...
