- DIY Diagnostics???
- Civic won't start!!! PLEASE HELP!!!
- My vents won't blow any air...
- A/C compressor oil
- ShAkInG FeLt On RiGhT SiDe
- 04 vp wont start help!!!
- 05 civic coolant leak
- Squeeking Rear all of a sudden?
- change of TDC Sensor
- Replacing axle, cv joint, etc..anything else?
- honda civic sport vtec steering problem
- ?¿?NeEd A PrIcE?¿?
- What to do to car at 60,000 Miles (Need Consensus)
- my suspension is popping
- Driver's Door Lock stopped working
- Help with Valve/Cam
- Noises in the rain
- headlights take time to come on
- Catalytic converter heat shield?
- Weird problem
- Who has done a d17A1 to d17A2 swap
- odometer
- tranny
- Break bios
- a little confusion with cats, downpipe...
- Anyone ever change a door lock actuator?
- Clutch issue at 57k??
- Could someone post the name of that act of congress protecting warranties?
- ignition help
- Smoky fron the front
- battery light keeps flashing
- ABS Light after Cluster Swap
- P0420
- A/C popping is normal
- 2002 civic making noise
- Exhaust noisy at cat/header
- i think i got a serious problem... wheel,axle, rotor assembly is loose? HELP ASAP!!
- Engine Sounds Like A Diesel Engine???
- Sideview mirror fix
- Will 4dr headlights fit on a 2dr?
- idle drop
- Ecu Help!!!!
- progress rear swaybar
- $$$$$$ How Much Will This Cost?????
- ac condensor is bad,anyone have a spare, will warrenty cover this?
- Humming noise coming from front?
- Cutting off Catalytic Converter??
- clutch pedal squeak!
- a/c noise??
- Hit a curb the other day Question
- Noise and bad shaking from front rightside
- HELP nothing lights up
- Does anyone kno how to rip off the ignition on our 7th gens!!!
- brake squeking like a mofo
- Helpppp
- Name That Part!?!?!
- Warranty Issues
- 2001 Tranny re-call?
- a/c compressor
- Accord engine noise/grind throttle only
- 5 check engine light flash.
- It got caught...
- squeaky brake pedal?
- My dilema need help
- Two Separate issues, Clutch and CV Axles?
- Transmission ?'s
- Brake lamps don't work (rear brake lights and the small one against hte rear window)
- "compliance bushing" ?
- Timing Belt due?
- Almost stalls with AC on
- Anyone have loose door latches?
- Torque Converter Clutch Malfunction
- tranny noises
- wheel bearings
- I need Schematics please help
- HP Racing header
- 2002 Civic Automatic Transmission Problems HELP!
- I keep blowing alternator sp fuses
- Smoke from exhuast
- Window Problem...
- Paint chip on roof
- Brake problem and random noise!!! HELP!
- Battery Light Refuses to turn off
- Spontanious Decelleration
- HONDA FOR LIFE but NEED HELP PLEASE
- CAI after install
- Jack Accident (Laff at me)
- I tried to search but nothing... Steering wheel alignment
- werid sounds commin from the vic
- rattling noise at idle and under load
- OBX headers 2nd O2 sensor question
- Engien Light on ?
- OBD P0135 for O2LX 2000
- A/C Sucks
- Aftermarket Tachometer on DX 05
- Failed AT Transmission
- 3 rear left speakers broken in 4 years
- Trouble diagnosing P0563, P0141
- Wheel Sounds
- Shifting Problems..... HELP!
- Checking with others: Funny problems in my cars
- Front Driver Side Creaking
- how do you turn off maintenence required light???
- gas door...can we lock it?
- For ppl with turbo and 3 inch catless exhaust
- Clear Coat Peeling
- wierd noise at low rpms
- code 1259 vtec malfunction
- Nothing coming out of lower air vents
- Check Engine Light clears upon restart, no codes?
- P1298
- TSB's and Warrenties
- Abs Sensor, Broken Mirror Gas Remote Broken Need Help
- gauges all @#%&!* up...
- Noise Diagnosis ..
- Honda is Covering my 2002 AT 100%
- Yep, so it happened today. The vics auto tranny is now completley shot. Towed away :(
- Clutch makes popping noise
- mt shudder when cold
- Weird Motor Fuction..... Might be an Idle Control Valve
- Acura EL Automatic Transmission Problems?
- driver door jammed and wont open
- anti-seize
- rear noises
- AC and Clutch = slipping
- My exhaust suddenly...
- Lagging Issues
- Brake System problem = Check engine Light
- Brake Problem
- o2 sensor wont come off....
- Doah! I Damb Blinkers. Help
- need help w/Apex i RSM Neo unit
- blown d17a1's
- HELP just changed belts now i have a turbo
- Hi GEARBOX , NEED YOUR ADVICE !
- Misfire with cam and how do i clean pluggs?
- Wierd electrical problem.
- Another Automatic Transmission Question
- Oil pump problems?
- k20z1 swap done and not starting :-(
- Air Conditioning Problem
- Idle drops REALLY low, please help
- Water leaking from dash on to passenger side floor
- Vibrations... EVERYWHERE
- hid will not work on driver side
- Front Control Arm/ Bushing Replacement
- bent piping
- hub bearings
- Need Help Please!
- Serious Question about my 02 civic
- A/C not cold unless you rev the car, 01 ex
- Whine/rubbing sound from engine. Quick help needed.
- where to buy injector o-rings
- 2002 Civic cluster problems...
- 2002 civic A/C making some funny noises...
- Fuel filter confusion
- 2004 4dr headlamp
- Has anyone bought this book and actually used it?
- Back windows on sedan
- what hose is this?
- Won't turn over
- Squeak when I shift from 1st to 2nd
- Manual Transmission oil leak. How to repare?
- Body Work in SE Michigan?
- passenger mirror problem
- gas peddle stiff as hell
- switching gear hesitation!?!?
- Power Steering Pulley Came Loose
- CEL then idle drops to 0 and car only move 15mph
- Leaky power steering covered by warranty
- Fogs lights won't turn on!
- car randomly shut off @ a light today
- 2004 LX coupe ECU location???
- Clicking Noise Turning Right?
- Help: Blinking battery indicator... [FIXED!]
- Can scratches be removed from the dash?
- Dying horn?
- Exhaust Manifold... UPDATE!!!!!!!!!!!!!!!!!!!
- way out of this cluster swap problem?????
- Noise from back suspension
- another engine shot
- Fuel filter clogged?
- Car is overheating
- problem installing my aero kit-----HELP-----
- manual trans repair or replace?
- Sound when Lights Left On Doesn't Work (Revived Thread
- P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
- Weird performance problem
- RSX seats install help
- Foggy Projectors please help
- Urgent Help with Alpine keyless entry
- Weird...possible problem?
- Idle Problem
- need help urgently please!!!
- Driver side engine mount bolt broken
- my motor is FVCKED
- 02 Civic EX died on the highway yesterday
- power steering wheel problem! URGENT! HELP!
- Uh Oh, This Doesn't Sound Good
- HELP! strange rpm problems
- clacking sound around right front tire
- its kinda hard to explain
- p1259
- Somone Help With Overheating PLZ
- Overheating at high speeds
- can someone answer me for my exhaust???
- 01 Civic EX with Power Steering issues
- Power Window - Push/Pull wire broke.
- 05 Civic sedan leaking struts at 30k miles
- problem with starting
- big problem, oil all over spark plug #1
- Rattle Problem
- When AC goes on, HIDS Flicker!
- d15b
- 01 honda civic sedan "check engine" question
- P0420 CODE and O2 sensor conneced?
- someone please help me, i hit a curb last night
- A $3,635 bill just for brakes.
- brakes making clicking sound
- HELP! hot fuel pump relay?
- Remove taillight tint
- "D" light on dash keeps flashing...
- click.click with cruise control
- how to take headliner and pillars off civic 2002?
- O2 sensor problem
- Alternator Problems
- auto to manual conversion
- CAI and Strut crunch
- How to reseting the SRS indicator?
- buzzing noise when turning the key
- how do i change the thermostat? *new info added*
- Wheel stud/hub removal
- Remote lock/unlock problem
- Hi Flow Catalytic Converters
- Trying to help a friend *not a honda*
- Rolling Back On A Hill
- What did I do?
- Keyless Entry Gone Crazy...
- 01 ex idle problem
- Stock Tach, Autometer Tach and Adapter.
- 80,000 Miles
- Rattling Noise???
- I want to blow my engine,HELP ME!
- loud poping noise
- Flickering headlights
- AC water in cabin
- fuel fill door is jammed
