View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30
  1. Short Throw/ Exhaust Issues
  2. Rear View Mirror broke off
  3. Intake.....
  4. what did i snap??
  5. Some kind of Oil problem?
  6. K20a injector
  7. Door Sensor
  8. Low beam problems
  9. Locking Wheel Nuts
  10. Strut Spring Perch Problem: HELP
  11. Strut Spring Perch Problem: HELP
  12. Spark Plug Help!!!!!
  13. Window tint issues
  14. OBDII Code
  15. Trash bag melted to exhaust!
  16. auto tranny shift issues w/ error code
  17. Dealership Shop Service Quality List
  18. srs light on nd tried the diy for it...HELP!
  19. Engine noise
  20. Brake light & Oil Light
  21. Sunroof Rattle
  22. Horn doesn't work.
  23. Battery light
  24. Popping Noise from front of right rear lower control arm
  25. Does the Hazard button light up?
  26. Anyone have a PDF Helm's on 7ths?
  27. Tranny problem
  28. hrm....
  29. Trunk Wont Open?@ :(
  30. help! 1st time manual transmission fluid change
  31. very strange problem with my friends 7thgen
  32. Injen intake broke!!! need advice
  33. problem w/ my hazard lights
  34. Anyone know how to remove the silver surround around the shifter?
  35. Sticky Shifting
  36. HELP ME! Whining noise while driving
  37. Concern about car
  38. Have a problem..Need Help
  39. Ho d00ds, my new car
  40. help p1519 won't start
  41. Tint problem/question...
  42. Sedan '01 passenger power window issue
  43. stripped strut tower nuts and bolts..NEED HELP
  44. Need help finding a part
  45. Most annoying rattle ever...moonroof
  46. 2001 Civic Immobilizer Bypass 555h or 555i
  47. Help w/ power window regulator
  48. Aiming headlights
  49. window problem...
  50. ear piercing noise
  51. Motor Oil on Spark Plugs
  52. airbox nuts/bolt problem
  53. Update:D17A2 head swap done... but major problem... plz help!!!
  54. 03 getting real hot
  55. Vtec not Working Help..
  56. Tranny Problem in the works, maybe?
  57. Response from Honda mechanic about Honda specific fluids and our transmissions
  58. another window thread
  59. Took car in to Dealer to get fixed *help*
  60. Auto Tranny Shift Q's
  61. Door locks kinda
  62. Kill switch?
  63. Paint is flaking off!
  64. Water Leak
  65. Help! Car Won't Start!!!
  66. Do I need to use only Honda sparkplugs?
  67. Need Some Fuel Help Yall!
  68. Nasty sound and violent feel... is this the axle?
  69. sputtering civic
  70. CEL came on=== tranny slipping
  71. Civic Making Loud Noises
  72. 2001 civic cluster (need help, used cluster gauge)
  73. ECU Diagram anyone?
  74. odd smell
  75. toot toot dosent work any idea why
  76. FLB Fuse blowing
  77. how do i put my battery back to stock location??
  78. need help to take out the console
  79. did anyone have power door lock die on them
  80. Motor mount cracked in half
  81. Another ABS Light Question; Please Help!
  82. Need Help/Suggestions
  83. Funky Idle, No CEL
  84. Suspension Problem
  85. HID Help
  86. Engine shaking and idling at 2K, jerks when shifts(auto) HELP HELP!
  87. Rough Idle just appeared
  88. CV Boot
  89. My Civic Model? Big Mystery
  90. ac problem
  91. OEM fog light switch wiring
  92. car running hot
  93. Rough running
  94. HELP!!!signal stays on when headlights is on?
  95. Power Windows
  96. stupid black things under car
  97. Weird noise under the car (driving in rain)
  98. Confused
  99. 02 Civic DX-G Alternator Problems
  100. wet floor
  101. civic k20/k24 swap
  102. here is a new one for ya all...
  103. i cant get the fly wheel off
  104. Fog Lights
  105. Windshield Wiper Reservoir Repair
  106. need help on installing volt meter
  107. fuel gauge question
  108. sh1t, stripped a bolt....
  109. Any way to test the condenser fan?
  110. Auto tranny troubles!! help!!
  111. Power Windows
  112. oem fog switch, wired to neons
  113. 03 manual trans. problem
  114. Keyless Entry or Not?
  115. Oily Air Filter
  116. Radio Time Set
  117. mys srs light is on!
  118. Just look at the picture and go "WTF" with me lol
  119. trunk wont close
  120. squeaky nosie when car is running
  121. Unable to shift to park gear smoothly on AT.
  122. Valve Cover came off...
  123. Vibrate when stopping
  124. check engine light fuel temp?
  125. compressor problem!!!
  126. OIL PRESSURE GAUGE, reading incorrect. help asap.
  127. How difficult is it to change the thermostat?
  128. auto gear shft indicator lights!!
  129. Rear shoes, drum, total screw up. HELP!
  130. Get a new tranny or sell the car?
  131. tsi control unit problem
  132. squeaking/high pitch grindin sound ....
  133. tsi piping rubbing
  134. Headlight problem...
  135. weird noise when takeing a turn
  136. My day at the Track.
  137. Wierd gauge cluster quirk
  138. Electrical issue...ugh
  139. 3rd gear pops out time 2 time
  140. Greddy Evo2 Exhaust Problems
  141. Maintainence REQ'D
  142. my car is sick. lol *update#5*
  143. Car wont start, key won't turn?! help asap.
  144. What Are The Signs Of An Auto Tranny Going???
  145. giving up hope on my POS, tranny problems.
  146. Front windows stopped rolling at the same time.
  147. spring index
  148. Replacing bulbs in the Gauge Cluster?
  149. 2002 EX coupe: Tumbling/clicking while turning right
  150. Exhaust Manifold Crack = Lean?
  151. check engine code p1457
  152. i cant see my damn antifreeze level!!!!
  153. Sedan Rear Side Window Rattle
  154. Hope someone can help me out, major electrical problemo
  155. Clunking noise when turning the wheel?
  156. Key is hard to turn
  157. Is this normal?
  158. Cruise controll question
  159. car boggin out at maybe 3000rpm need help please
  160. alternator??
  161. Side airbag light
  162. Engine heat issue?
  163. Hhheeellppp!!!
  164. OBD2 code: P0420 Catalyst System Efficiency Below Threshold
  165. What shops do leakdown tests?
  166. cost of head gasket replacement
  167. idling to low?
  168. Need some Advice on wat had happen to my civic
  169. TCI Automatic Ovehaul Kit
  170. screeching sound help
  171. radio dead , power door locks quirky
  172. Misfire out of ideas!!!!
  173. taillight fuse??
  174. Suspension and Catback problems! Sh*t
  175. 02 Civic HX noise
  176. Need Help Radio won't turn off
  177. problems starting sometimes
  178. rim & shaking steering wheel
  179. Removal of silver trim piece around shifter?
  180. ok, header and high flow cat
  181. Had a random overheat, kinda mind boggling
  182. Rebuild or Swap... 3 questions.. Help me
  183. Cluster lights flicker on and off
  184. REQ: Recall Info
  185. Bad Day with Coolant Leaking
  186. OIL All over spark plug... ?
  187. Leak in 01 LX 4D.WET Driver Side Carpet
  188. Destroyed E-brake
  189. Sounds Like Detonation??????
  190. noise coming from rear struts??springs??HELP!!
  191. 03 Civic:MT tranny whistling? | Page2: upgrade clutch during bearing replacement?
  192. funky smell inside
  193. vibration under the car from the cat
  194. Knock Sensor
  195. cv boots.....
  196. B&M cooler for auto trans
  197. aiming headlight
  198. Dis-able the annoying loud *ss buzzer!
  199. Heat Guage going to HOT when idle or in bumper to bumper traffic
  200. SRS light / Seat Removal
  201. Fallson Its Face
  202. Slipping out of 3rd gear while decelerating?
  203. someone hasta KNOW ..PLEASE
  204. a/c not as cold as before
  205. Low beams quit working
  206. Need help with HOOD problem
  207. '05 Civic EX, 25000+ Miles, Doesn't start as easy
  208. A/C Smell
  209. radiator hose wont fit.
  210. Installing Parts and Diagrams of parts
  211. new guy with simple question
  212. Squealing whistle off throttle
  213. 2001 EX with Auto... How many quarts are you adding?
  214. Warranty Question
  215. gotta a promblem please help!!!!!
  216. valve adjustment problems
  217. Odd whoop noise when driving
  218. Where can you buy this in Toronto??
  219. just cracked the 100,000 barrier
  220. road noise
  221. take my car to the dealer or mechanic??
  222. Ex and Si crankshaft help!!!
  223. Odd sound when turning
  224. trouble with losing
  225. Question for 04-05 Civics with autos
  226. driver door lock wont lock
  227. 02 Civic Won't Start
  228. 02 Civic Won't Start
  229. Looking for recall info
  230. Rattling Noise???
  231. Stiff auto shifter...
  232. P0122 TPS '03 Civic LX
  233. Engine Grind? wtf?
  234. New Exhaust Installed but there's a burning SMELL
  235. How much to rebuild a D17?
  236. P0139 Error Code 05 Civic after header
  237. Things are bad fro the vic right now
  238. 05 engine harness rewiring
  239. Window problem
  240. clutch hydraulics
  241. Weird fuel gauge and tank issue
  242. hood lock problem
  243. should you mix your gases
  244. help!!! need help with ebay fogs.
  245. electrical problem
  246. Gas Tank Cover will Not Open
  247. It rained HARD and now this happened...
  248. Problem with trunk springs.
  249. Fan question
  250. Engine Problem
