View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. knocking suspension fixed under SERVICE BULLETIN
  2. Link to site with TECHNICAL SERVICE BULLETIN numbers
  3. WTF??? Speedometer "breaks" this morning...
  4. Rear bumper of Body kit
  5. Rear Window Tint Removal...
  6. seatbelt making sounds
  7. Major Stereo Prob (please help)
  8. Carpet Lumps...
  9. turn signals...
  10. exhaust touching bumper
  11. Moonroof Rattle
  12. mysterious rattle
  13. So many problems?
  14. Wierd sound after letting go of gas...
  15. tire prob's
  16. speed sensor...???
  17. lug size??
  18. White stuff in engine oil
  19. Cold air intake problem!
  20. Car moves in NEUTRAL???
  21. Downshift Adjustment
  22. Why so High?
  23. What to do if a dealer will not fix a problem with a car?
  24. car stalls is it because of aftermarket shiz?
  25. Auto-Down Window stops
  26. Rattle in driver's side pillar '01 Sedan
  27. whats the +'s and -'s of the new 1.7 liter?
  28. Have any of you ever called Honda Client Relations about your problems?
  29. Stinks!
  30. Is this Murphy's Law or what!
  31. 2k2 civic owners
  32. Is there something wrong with my civic??
  33. Dumb question
  34. steering wheel emblem
  35. engine check light "emissions light"
  36. Class action suit against American Honda???
  37. Bad Oxygen Sensor?
  38. My post is gone
  39. rattle when AC is on
  40. 2k1 Civic Aircon Foul Odor
  41. Rear brake drum service bulletin
  42. I stalled my car twice!! just really worried
  43. Obstruction in Gear Shift
  44. wierd noise when revving
  45. at how many miles did/do you get new brake pads?
  46. ABS Light is on
  47. BROKEN HEADLIGHT
  48. Interior Lights just winked out!!
  49. Rear seat belts tension up and lock??? (sedan)
  50. Has This Happened To anyone Else???
  51. CAR WONT START !?!?!?!?! HELP!
  52. Car Wont Start!?!?!?!? HELP!
  53. check engine light
  54. Dealer fixed two of my problems
  55. When Does the damn vtec kick in???????
  56. Konis installed...
  57. door panel rattle on coupe
  58. SIDE AIRBAG ISSUE/SUGGESTION
  59. My dealer sucks, does yours?
  60. Any Probs with the 2k2 Civic?
  61. Help!!!... Some Oil Stains on Floor..
  62. Reverse Indiglo problems....
  63. passenger seat walk-in feature with memory
  64. WTF? My car ALMOST did not start!
  65. Wrecked my LX
  66. Shocks seem kinda "crunchy" in cold weather.
  67. Parking Lot Dents
  68. Annoying vibrations when idling. Please help!!!
  69. Many problems, any solutions?
  70. License plate rattle
  71. Dent on hood
  72. Clutch?
  73. A/C Problems & Surges
  74. PIAA Extreme Wedge Parking Lights Warranty
  75. has anyone's "check engine" light come on yet?
  76. Deck lid not Latching
  77. Injen SRI burning hose??
  78. Weak Braking
  79. HELP ! clutch problem turning to nightmare.
  80. HELP ME!!!!!!!!!!!
  81. check your seatbelts
  82. are these problems
  83. Pain in the A$$ Dealership
  84. warranty issues
  85. preventing rust off care in the winter, practically impossible
  86. Sensitive Steering
  87. books on fixing or my civic 2001 "mechanic books"
  88. Key won't come out ignition revisited...
  89. do I need need to get certain tires for rims
  90. Is my clutch going?
  91. scratches on audio console
  92. DC headers question
  93. hittin rev limiter...
  94. Gauge Problems
  95. Problem starting car !!
  96. shifter problems
  97. how do i remove my dash?
  98. Rear suspension squeaking.
  99. dent in hood from hail, how to remove?...
  100. Piaa Xtreme White Bulbs.. How long are they suppose to last?
  101. AC Reverse indiglo problems...
  102. OEM Motor Mounts
  103. shifting in auto
  104. Crazy Auto Tranny
  105. WHat is the difference between the EX and the 1.7i ES model?
  106. closing power windows slow/seize
  107. TELL WHAT YOU THINK ABOUT WHAT COLOR .....
  108. Synchro gear problems
  109. INJEN SRI QUESTION
  110. cold air when turning
  111. Sticky something
  112. Whew...car stalled and almost got hit...
  113. Door rattle by hinge
  114. maintnence light at 10000
  115. Recommended Maintenance
  116. 2nd gear getting off
  117. do you guys get static shock
  118. 6 beeps
  119. Speedometer stop working....
  120. Faint Burning smell..
  121. Help with Front Vibration
  122. stock intake ?
  123. grinding noise
  124. Problems with trunk latch
  125. Swapping new rims back with my old ones??
  126. This an electrical prob?
  127. Strange Hum while accelerating
  128. Rear Bumper Paint Difference
  129. Glove box or passenger side vent rattle
  130. the honda dealer is the sh*t
  131. Alternative to suspension leaking and shifter
  132. Where is the air filter in our cars?
  133. shifter problem fixed
  134. Broken motor mount/ coil packs not sealed also
  135. Keyless Entry
  136. any one elses shift boot to tight?
  137. i have these probs, can you relate?
  138. Clues for Hard Start Mystery
  139. Are Light Bulbs Covered Under Warranty?
  140. no problems!
  141. Robber Stoppers w/ new car?
  142. Worried about your rev limit in Park?
  143. Removing Door Pannels
  144. Front drivers side rattle when hitting bumps
  145. ENGINE REVS UP AND DOWN BY ITSELF
  146. changing a little light ??? help plz
  147. attn:2 cute
  148. Rattling is BACK!
  149. Dang Bulb!
  150. anti freeeeezzzee
  151. my cars falling apart
  152. Door lock noise
  153. INJEN SRI/ AIR FLOW SENSOR
  154. Speedometer Needle Problem...Anyone Else?
  155. Wheels spin when in neutral and car off the ground.
  156. Wheel hop!!!
  157. HELP!!!! WITH SECURITY?!!!!!
  158. uhh.. help with shocks
  159. GAP between the roof linner and sunroof's shade
  160. Metal Shavings in Steering column
  161. mileage question
  162. Bad tires?
  163. squeeking in the rears
  164. passenger tire clicking
  165. Making Wierd Noise from front wheel
  166. Too much coolant?
  167. my warranty is finaly up
  168. WTF!!! problems??????????
  169. Squeaky noise from breaks
  170. tire steering suspension problems
  171. Fuel economy at WOT and low RPM?
  172. CHECK ENGINE LIGHT HELP!!!!
  173. Everyone with break squeaks...check it out
  174. Help with Suspension prob
  175. Honda bulletin for rear deck rattling
  176. Talked to a Honda mechanic...
  177. Low revolutions issue.......need advice.
  178. New Car Mileage?
  179. WTF: TRANY GONE?
  180. Popping out of 2nd gear..
  181. Anyone can help with my interior rattle, PLEASE!
  182. 5000 mile gas mileage report
  183. My Muffler Doesn't Sound right HELP!!
  184. Break Groan!!... NO one else has this problem?!?!?!?!
  185. gas peddle vibration on 2K2 Civic LX
  186. ATTN: CARS WITH VIBRATION IN RAIN
  187. Auto tranny question
  188. SOMEONE WITH A SHOP MANUAL
  189. Fuel Tank Level - Inconsistency
  190. POS Governor
  191. clearing headlights for POS 4 door civic to hard
  192. fogging in headlights?!!! =(
  193. My Engine is DONE!
  194. Silicone caulk on my bumper
  195. BYPASS SECURITY FOR COMPUSTAR???
  196. PLEASE HELP!!! SRI Installation; Malfunction Light on?!
  197. Strange noise I can't get it fix.........need Help.
  198. Keeping a clean engine
  199. Radio/Defroster Problem!!!!
  200. Screetching Brakes
  201. Upgrade Wheels/ Faster Odometer
  202. CUSH HONDA IN SAN DIEGO SUCKS
  203. 02 LX ITS OVER!!!!!!!!!!!!I cant take it anymore
  204. knocking suspension only when moving slow.
  205. Rear end crazyness, Speed Bumps
  206. Warning : Your battery is about to die!
  207. I can't believe this.........went to service again.
  208. Smells like burnt plastic/rubber
  209. Vibration at idle
  210. OMG...What have i done...
  211. New Rattle
  212. SRS airbag light on all the time
  213. why cant i turn the a/c off while defoging?...
  214. Scratched rims
  215. Reloacted Alarm Speaker, Car won't start?!?!?!?!
  216. Loud "clunk" noise
  217. Running Low on Gas?
  218. Door cover
  219. Oil Question
  220. windshield washer nozzle spray stains
  221. Power steering is hard.
  222. used 2k1 prices?
  223. Cigaret Lighter Broken What to do?
  224. vibrations
  225. Brakes Grabbing
  226. brake ..... click ....
  227. Gas Mileage with Rims ??
  228. OMG what a pr*ck!!!!! Hoehn Honda, San Diego sucks!!!!!!!
  229. Why did u guys void ur warinties on ur Civics
  230. 02 LX ITS OVER!!!!!!ICANT TAKE IT ANYMORE PART2
  231. list of all service bulletins?
  232. Emblem reattachment
  233. car pulls to the left
  234. weird grinding noise
  235. Do alloy wheel improve ride comfort?
  236. Can you drive without 2nd gear!?
  237. Overcoming the Strut problems!
  238. Tinted windows weakened radio signal
  239. bad ride quality?
  240. Headlight is messed up
  241. Transmission problems
  242. weird buzzin noise from speakers
  243. Shocks Worn Out?
  244. tire rotate?
  245. FYI A/C Woes
  246. breaks squeek
  247. Meddling Kids!!!
  248. window moves the door???
  249. shifter rattle in 5th gear
  250. I am such an idiot...
