- help please on airbag light asap
- My AC is not working....
- Altenator removal
- Melted Bumper
- Odd smell from the front of the car
- engine ?
- whats this called?
- Rear Defrost isn't working
- Can someone explainw hy this happens?
- Stalled...
- cracked exhaust manifold
- HID Bulb...help
- HX fuel economy
- Maintainance Required Sign
- Bumper Fitment Question!!!!!!!!
- Check this out!
- sister's car won't start
- Continuous Metal Sound After Turning Off Hot Engine
- Intake Problem
- noise when accelerating
- Fuel fill door won't open
- Replacement Key Immobilizer Programming
- Idling up engine
- 02 civic strut bearing in a 01
- Bad Engine Mount causing vibration?
- Back Again....
- auto tranny problems... again!
- A/C compressor??
- car is not doing well...
- VAFC2 on 99-00 si
- backed into..
- My fcuking civic turns off by itself!!..
- p1505
- Broken Upper Strut Bolt
- Road Noise...Can't figure it out...HELP
- Help with Passenger Window
- Did Honda screw up my car?
- How much for a new 2002 civc cluster?
- my tranny is slipping
- 89 honda civic, pedal down, car shuts off
- Clutch pedal problem
- pully Bearing????
- Brakes Squeaking
- My radiator fan is not working...
- Anyway I can take the key out without in parking gear in an auto?
- how do i replace a windshield wiper blade?
- parking/corner light problem
- A/C fan, motor and etc..
- Valve tapping noise?
- slow start
- Aye Carumba! can YOU make sense of this?
- flapping noise, possibly from tranny?
- do i have everything?
- Problem FOUND!
- How do I replace my Fuel Filter?
- Catalytic Converter Question
- Headlight Aiming
- Beware: transmission slippage is common for 7th gens
- knocking or shakin in drivers side wheel well
- Warranty up in 3 months
- 2003 Honda Civic is throwing a code - P1298
- Clicking noise when first turning on the car
- Suspension noise?
- Check engine light on
- Clutch problem help!!!
- A/C prob...
- Tranny slipping?
- Oil Low, Light On/Light Off, Safety Rev?
- Mechanical 02 sims are p!ssing me off
- Engine is dead
- cant drive in the rain
- Bumper mounts.
- Parking light...what kind of bulb
- *sighs heavily* help plz!
- help!!!!!!!!!!!!!!
- Tranny or Engine Mount?
- is honda telling the truth?
- Look What Happen To My Car This Morning
- SRS light on, NO WARRANTY
- cracked airbag cover
- Vtec Light prob
- right (passenger) side turn signal
- Wet floor?
- 01+ Civic "Manufacturer" Steering DEFECT
- Stock air box
- 02LX door fabric - engine mount - leaking struts
- My car is all messed up. cuz header
- tech question...
- Interior Reupholstering
- Strange noise coming from engine bay...
- Sparco/Momo
- Gauge Faces flicker!
- Clutch pedal is binding
- still reset ECU?
- engine is vibrating and acting really funny
- someone help plz!!
- DIY: Diagnose manual Tranny Noises (and save some $$$)
- TURN SIGNAL! turn signal.
- broken motor mount
- 1998 Civic EX whistling noise
- Coolant splatter
- clutch clicking *sounds*
- check engine light..bout 1000 codes
- replacement fog light help
- ECU Fried?
- heat problem??
- warranty question
- Vtec + Engine Light
- rear speakers?
- ahhh bumper plastic thingie
- help
- Fog Light Issues
- o2 sensor issues
- Oil Drain Bolt (Can't get it off)
- Update:I've sprung a leak... clutch line
- Error code problem P0102 Need help!!
- Throttle Body Problems
- Axles being dumb help...
- rear deck question
- exhaust rattle
- car over heated?
- stock shocks?
- No heat/overheating Again!!!
- No climate control lights, and now no gauges, but icons light up..
- Need Help finding just alternator belt
- whould this be a good idea?
- Help pls! Door handle replacement
- Car jerks just before stopping
- Air bag light on
- With No Cat?!?!?!?!?!?!?
- tranny
- how do you remove rounded wheel cylinder nut?
- Need stereo instal help
- Possible Transmission Problems with 02' Civic LX. Help please.
- Possible axle or bearing failure?
- Break Pedal Issues...Maybe something else???
- car getting wet on passenger side
- my amp makes my speakers go woowooo
- Door Lock is broken
- Stock 04-05 EX header fitment
- I need HELP ASAP...what are the differences between a LX and EX A/T??????
- Help P0122 TPS Sensor
- Honda Key's
- Keyless Entry Question...Need some Imput.
- is my reverse gear f'd up?
- small crack in windshield help
- REmoving wheel cylinders
- Turning RUBBINg Noise, PLEASE HELP!!!
- back brakes
- Horn and 4-way flashers are ONLY things that work!!
- Winding Noise When I First Start Car?
- Annoying squeaking sound coming from rear window
- changing engines
- dash light and parking light flash for alarm
- No alarms
- Having overheating problems
- Car caught on FIRE
- Axle Problem? PLEASE HELP
- Projector headlight problems..
- k swap imobilizer question
- Type B Skirts
- Bumper Grille
- Door Locks
- Stopping pebble noise under car
- unsure problem
- How can i install headers w/ out CEL?????
- wheel noise/vibration
- Locating the ECU
- f*cking dealerships
- Slight noise cant figure out
- rain in hawaii = passenger side flooded
- CRAZY wheel shaking!!
- Seatbelt Light Door Dinger
- Vibrating noise in the left wheel area when I turn my wheel
- wierd suspension / steering problem
- Sputter at 3500rpm
- need help removing a bolt
- what to do ...
- Road Noise Fix
- grinding on snow and ice
- Noise coming from acceleration above 2K
- Problem when starting car
- Gauge cluster problems
- led turn signal Load Resistor kit
- Changed Headgasket Car turns but wont start
- rpms stuck at 2k.
- front wheel hub & bearing
- Headlight Issues
- Need Help... Bad Idle.......
- Car Wont Start! help
- Driver chair rock back and forth
- Manual Transmission Problems in a 95 Eclipse
- 02 Ex Radiator Support
- Messin' with electrical sys, now car won't start
- squeaky clutch pedal
- pre-problem diagnosis
- roof liner sagging
- Buzzing noise coming from instrument cluster
- light on alarm doesn't work , pls help
- finding a rattle, need a favor
- Wipers and wiper fluid not functioning...
- Steering Wheel Problem!!! HELP!!!
- Anyone have trunk spring rattle?
- AC Not Functioning
- Gas tank gauge problem
- Winding noise ???
- Pulling with a spare normal?
- Power steering froth
- Side airbags or no?
- check engine light is on.............
- Check engine light won't stay off!!!!
- feul (gas) door release broken
- how much should I expect to pay for a new alternator?
- Clutch Friction Point Changing
- Trouble installing speakers - door panel does not snap shut
- spring help
- SRS Light
- New to the site and need some serious help on my 2001 door locks.
- UGH! Frame Problems
- EX owners with AEM shortram intake
- Scrappy Sound Near Right Wheel or Engine bay
- Help!!
- My car doesn't start sometimes....
- Windsheild washer fluid sometimes squirts out by itself
- Intermittent Gauges
- What up
- Loud belt noise
- got a problem.
- Power Window- Parts need to fix
- what up
- Car makes metalic scraping/creaking sound
- Spark Plugs 02 Civic Ex
- Steering wheel not returning to middle?
- transmission problem help?
- SRI and engine temperature guage
- Squeek Squeek...
- Heat problem...AARRRGGG!!
- body roll
- is this normal
- A/C Condenser falling apart
- List of common problems with 7th Gens?
- Headlight out followed by buzzing sound....
- tranny whines
- Cylinder Head weight?
- Help me find a new tranny please!!
- clutch engagement
- header CONFUSION =/
- Battery Light
- Bolts for stock airbox/resonator... Help!
