- Auto tran shift from P to D, feel 2 jolts?
- transmission problem - $2,450 - wtf?
- Control Panel Woes
- lower control arm help!!!
- nasty smell
- throttle body heater bypass
- How does Honda diagnose SRS light issues?
- 5 speed HX problems.
- Suspension / Brake Problem
- Another 7th Gen with a ****ed up Tranny...
- Please help!!!!!
- motor tapping
- Side Spoilers keep peeling away.
- Anyone here done a o2 sensor yet?
- reved up and shifted at 7k (past redline)
- weird clukcing noise
- is my clutch on its way out?
- passenger axle nightmare !!!
- passenger window ??
- I damaged my passenger DOOR HINGE!
- M/T - Shift Lever Difficult to Move/Hard Shifting
- Creaking Sound When Turning
- Some weird noise, I can't figure out!
- 1994 Civic DX Won't Start
- no oil leaks, no coolant drips...but overheating and low oil.
- Transmission maybe??
- Engine swap
- will ex trans on lx work?
- Hazard button doesn't light up
- Strange problem...
- cleaning cylinder head?
- Trunk/Gas LEVER stuck...
- Getting this burn smell
- 1994 Honda Civic DX Fuse Diagram
- passenger window
- takes longer to start up...colder weather perhaps?
- serious problem...
- Malfunction Lamp!!
- brakes? metalish rattling,screechy sound
- Stupid bumper clips won't come off!!
- 4rd gear slipping?
- omg rattle season again!
- AT Slipping
- Road Noise!!!!!!
- Think I may have a problem.
- Steering Wheel Vibration Between 50-60MPH
- Steering does note return properly when returning from turns in both direction
- Engine temperature gauge needle drop when heat turn on
- please help out...
- My Back Wheel Locked Up
- slave cylinder broke
- broken shifter
- Door wont lock/unlock
- p0138 code ecu
- wierd noise when i steer and gas??
- gas milage
- Heat only works while driving.
- 2003 Honda Civic Coupe LX - lots of issues
- well im lost and the honda scanner didnt tell me nuthing
- Another 'Engine Noise' Thread
- interesting electrical problem
- Exclamation warning light goes on and off!
- HELP: 01' civic EX whinning noise ONLY on cold starts. 66K
- Adjusting idle and throttle cable
- Car Spuddering! Need Help
- Parking Brake Light always on...
- Transmission Slip....I know...this has been done to death
- Front end/left side of car sits lower than right side (stock shocks/springs)?
- Will warranty cover...a foggy headlight? Alignment?
- 02 sensor causing bad gas mileage?
- reseting srs on 2002 ?
- Head lights (bulbs)
- Bulges in rear roof
- Oil in Intake
- Car chokes trying to go over 4000 rpms...
- Engine Problems
- trans problem.
- too much oil
- SRS Light On, Alternator Voltage Too High, Accessory Socket Doesn't Work
- HELP!!! Gas door wont open!!!
- Code: P0401 Exhaust Gas Recirculation Flow Insufficient Detected
- Would a B20 fit our cars?
- CLutch chatter?
- removing sticky shit????
- Power Lock on Passenger Door is Now Broken.
- 1997 Civic not starting and cutting off
- smoking exhaust?
- steering wheel viabration q's
- Another Shot Tranny - Honda to the Rescue
- Tanny Problem...I searched
- Ticking noise
- Power lock doesn't open
- Won't go into 1st gear
- Question about warming engine up
- Car stopping and vibrating.... :O
- Gas Mileage intake related?
- Keyless Entry
- HELP! Major Tranny Problems
- Something wrong with the beater!
- Crap!! my 01 ex auto tranny went out. only 66K too
- Car just dies
- high pitch sound
- Electrical Problems - 2001 EX
- rev low Around 3000 to 3500.. help
- All Lights And Gauges Went Off..but Car Still Running...
- Bubbling Noise/Water rushing while braking!?
- auto tranny.
- Anyone know the effects of a crapped up heat shield?
- Wood pecker sound in the rear???
- Falling mpg
- Electric clicking from ignition
- hood rattle how to adjust?
- New auto tranny put in... having problems...
- rattling noise when accelerating
- Brakes locked up???
- caliper seized....?
- manual trans - shutter problem *UPDATE!!*
- CEL P1166 Code (Fuel Air Metering) (Primary HO2S (No. 1) Heater System Electrical)
- Heater Only Working While car is moving, Thought Mechanic fixed...
- Cutting Down Exhaust Noise!!
- exhaust gasket question
- 99 civic si power locks?
- Steering Problem
- 2000 RPM's max.
- rims are stuck!
- Links that print out TSB's???
- rear speaker panel diagram ?
- Blown Engine NOT on WARRANTY!?!
- Transmission slip
- is it too late for the MIL eliminator?
- Annoying brake light...
- Automatic Transmission..
- honda civic 2000 ex brake lights aren't working. help
- How to Tighten Door?
- Problem with Headlights
- Power Door Locks and Windows???...
- Sulfur smell
- Aem Cold Air Installation!!! Help
- strange heat problem
- Weird Noise 2005 Civic LX SE
- car is in safe/limp mode?
- Stick will only go into park sometimes????????
- CV Axle Problem, please advise.
- Whats da cheapest a 5spd convtn shld be?
- Driver side door panel rattle
- gas gage
- Tail Lights Wont Come On
- Need help with my 5spd!!
- Shifter Lights Don't Illuminate!
- Bad O2 Sensor at 59k miles? Legit?
- Dents/Dings
- exhaust
- front bumper removal problem
- Noob Question
- damn ticking and squealking noise!(and no its not the axles)
- Misfire On Cylinder 4?
- Gurgling Sounds and Overheating
- Tranny slipping....
- will it work? speed chip??
- Idle Surge
- RSX won't start after Viper alarm install
- a video from me, to you guys with your slippin tranny
- Steering wheel shakes
- Light dimming while driving
- Shifter rattles in 5th gear
- P1607 code on civic 2002
- Confused about warning lights
- VTEC question
- quick question
- OBDII Code Explanation?
- automatic tranny - noob question?
- Chenk engine blinks
- Tranny bumps before car is warmed up?
- My car is dead!!!!!!!!
- Service Question
- OEM Spoiler nutz driving me nutz
- I'd like to know if I've gone crazy....
- 1 month old alternator, screwed!
- Clutch question
- 40K noises
- Black piece on bottom of bumper
- Is my car overheating?
- exhaust problem, skunk 2 rattling on tranny
- Clutch Clicking...
- HELP! My engine is smoking a little after I park...
- help! car shaking/rattling and transmission light blinking
- passenger side blinker going way too fast
- No corner lights.
- Problem with a 1997 toyota camry radiator flush
- water bubbling or gurgle sound?
- M/T Weird symptom after long drive.
- Bolt Question *Need help asap so I can buy and fix*
- Throttle body
- Speedometer "freeze"?
- Seat Belt Bolt
- Help! Three OBD II Codes
- When do I get new clutch?
- kinda annoying
- Din? Iso?
- Exhaust
- side airbag question (leather seat covers)
- Whining Noise From Engine
- slow passenger power window
- prob with idle
- Floor Getting Wet? Wtf
- passenger side power door lock problem
- Car shaking upon braking
- clutch and steering wheel vibration issue
- Gas Cut off early
- Master Cluth Cylinder
- driving problem...need help plsssss.
- defroster light wont illuminate
- Idle Problems no its not when its cold start.
- Sliced Windshield Fluid Box
- Alternator
- help ASAP civic wont start
- i need help...my speedometer stop...
- rattling when accelerating
- Any one ever have...
- Reverse not engaging sometimes
- Transmission Problem?
- Exhaust!!!!!
- Power Window Switch Broken??
- exaust...check engine?
- It won't start...bad starter?
- Tranny....Help!!!!!!!!!
- 67k miles and flashing cel light
- Weird whining noise while reversing?
- Exhaust!!!!!
- Motor Mounts
- Civic 2002 diesel won't start
- check engine light. no obvious problems.
- Two Problems: Mirrors and Door Lock
- Signal lights and hazards go out.....
- rebuild engine
- New Member about to do first fix-it...
- EACV Questions
- i think i have a supercharger
- Air Filter Replacement
- Fan Switch?
- did search need help
- 03 civic ex transmission.(already searched)
- Fan Blower issues
- Anyone know if the shifter cable can be adjusted?
- Help..flickering battery light issue
- Car won't start
- 04 civic tranny grinding
- C.v. Axle
- throttle position sensor
- loud noise coming from driver side engine
