View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. which fuse goes to the cigerette lighter?
  2. Rear right wheel noise???
  3. Rust and salt problem
  4. rolls backwards in drive
  5. intake broke under my hood
  6. Strange vibration noise at 2500 RPMs???
  7. Just install Exhaust.. problem ...
  8. Help Dealership Is Raping Me!!!!!!!!!
  9. Piping Hangs Low & Frame Pos. bend, Why? Pics Included
  10. Hot exhaust clicking noise
  11. DC racing headers
  12. I need you input on my headlight...please help??
  13. check engine light P1457 Evap. bypass solenoid valve
  14. Warranty Question
  15. Right Rear Strut Creak and another Pop?
  16. Cleared headlights having blowout issue?
  17. Car sometimes wont start!!!
  18. help with my headlights
  19. Racing seats/SRS light....a different problem than the usual
  20. Door not staying open
  21. Coin box?
  22. Clean rear box dust
  23. Yup, All Read and help me out :(
  24. fluctuating idle
  25. Removing coins stuck behind the coin box
  26. Man I'm frustated at my Vic
  27. my friends maxima has a problem
  28. Honda 2003 Civic LX
  29. transmission noise please help
  30. HELP - Problem with Car CD player
  31. HELP Headlight Problems, Low beams wont work wtf!
  32. Woah...rust?
  33. Door won't open from inside
  34. Car running like crap
  35. Need suggestion on misfire in startup
  36. Drum Brakes water noise?
  37. Is my clutch not disengaging?
  38. Help me please!
  39. Cruise Control On/Off Button Light burnt out
  40. Faint 3000 rpm Rattling Sound
  41. gargling sounds
  42. Another problem!
  43. P1519 Idle Air Control Valve Circuit Failure
  44. roof trim unglued from TOP
  45. can you hear the gas swoosh around in your gas tank?
  46. Irritating RATTLE!
  47. Brake light flashes on and off
  48. glare on front window from dash
  49. Wierd noise coming from the brakes
  50. Anyone a real tech here?
  51. no functioning gauges
  52. Mirror Probs?
  53. Bored Throttle body
  54. Timing belt tensioner failure.
  55. car stalling...(amp power cable)
  56. Rear quarter panel
  57. My Wheel Shakes
  58. brake n clutch noises
  59. intermittent starting Problem
  60. exhaust sounds louder in the rain...
  61. Motor Mounts
  62. knocking noise
  63. Noise from front passenger wheel??
  64. cel is on again!!
  65. Front passenger seat defective?
  66. knocking sounds
  67. Help!!!!!!!
  68. Help me figure this out!
  69. banged up my fender in the parking garage
  70. help please.. car won't start and late for school
  71. Burning smell after driving? HELP!
  72. water inside the passenger door
  73. HELP! can't stick it in.....and pull it out.
  74. WTF..dealership wont fix..
  75. Auto tranny conversion
  76. Keyless entry problems
  77. windows
  78. why car wont start
  79. '02 Civic Si/SiR Typhoon Intake Problem
  80. Brake "knock" noise, exhaust "spitting" noise on '04 EX Coupe
  81. Mysterious Disappearing Gas
  82. Problem with trunk light and turning signal (fixed it 10/16)
  83. 3rd gears goin
  84. Cel
  85. Headlight problems (drivers side does not work) - No.. Not a recall, please help ASAP
  86. Short ram problem
  87. This is how help should be asked.....HELP please
  88. Trouble Starting
  89. there goes my power steering
  90. weird problem sometimes.
  91. painted my turn lights with glass piant....bad news
  92. A/C blowing warm. Fan not turning on.
  93. ****ing SRS light is still on...
  94. Fixing an exhaust leak
  95. Seat rocks around
  96. Cig Lighter stopped working?? HELP!!
  97. car shakes when i hit the brakes at high speeds
  98. HELP: transmission fluid leaking
  99. Eng cuts out at 4k.
  100. engine rusted, need some help
  101. Engine hesitation when a/c is on (on an '04 EX Coupe)
  102. Gasoline
  103. Revving weird
  104. best jacking point for rear of car?
  105. fuel milage
  106. clicking sound while turning and braking
  107. Problem with headlight
  108. does anyone know how to reset the maintence light?
  109. immobilizer woes
  110. Projectors fogged up from rain
  111. Civic sedan problems
  112. 2001 Civic Speakers / Turn off AC / Keyless
  113. p1298 code(electrical load detector circuit high imput) help please....
  114. injectors
  115. problem with my hood...
  116. Stock radio problem...
  117. weird radio problem
  118. I think I broke a motor mount..............
  119. blown about 4 fuses already
  120. 2 problems
  121. General trans? question
  122. Cam Gear=Bad revving?
  123. My car is overheating
  124. Alt light question
  125. Cruise control not working
  126. Car going mad!!! Electrical issues....Help me!!
  127. Car Alarm's not functioning
  128. 01 civic stalls w/ out warning
  129. 2001 Civic EX 2DR Replacing blower
  130. Steering Wheel Is Nutz0rz!
  131. trunk lock ... help!
  132. Engine Gurgling
  133. Need help... weird pinging sound
  134. Rear Defogger
  135. Weird electrical issue. Help.
  136. having a hell of a time gettin my nuespeed strut bar on
  137. Creeking noises got louder :S
  138. Sound when reversing
  139. Ball joints
  140. Brake noise & A/C difference (EX, LX)
  141. I think my throwout bearing is going bad
  142. A/C problem
  143. Clutch Squeak!
  144. windshield washer sensor
  145. PLEASE READ!!! The sway bar link wont tighten!!!
  146. damm transmission
  147. overheat today...
  148. Soot on exhaust tip
  149. Radio/ Defroster help
  150. idle problems...again
  151. Break Pedal Switch Pop/Click noise TSB
  152. Alternator = Good, battery = good, But Battery still Drains
  153. T.p.s
  154. If You Are Having Car Problems And Your Check Engine Light Is On, Please Read This!!!
  155. gauges stopped working
  156. dealer problems
  157. 5th gear vibration?
  158. 94 civic cigarette lighter fuse ... which one?
  159. Air Conditioning Issue
  160. Odometer Repair Questions
  161. 01 ex brake squeak right front
  162. Long-term storage question. a bit of a crisis
  163. Check Engine Light Problem
  164. Maintenance light on continually at 85,000
  165. how do i check to see if water pump is bad?
  166. tranny oil change help!! need help
  167. HUrricane wilma and HYDROLOCK
  168. went to get an alignment
  169. Car Battery Dead For No Reason????
  170. instrument cluster replacement potential problems
  171. Can exhaust system do that?
  172. 2002 Civic, guage problems, please help!
  173. Transmission Trouble
  174. broken shifter housing bolts ?!
  175. engine noise
  176. Could it be the tranny? Already?
  177. Scanner can't read OBD 2 codes from my civic 2002
  178. Clutch?
  179. Battery Light
  180. rattling glovebox
  181. door open light?
  182. Do I need shocks or struts?
  183. Cruise Control help please???
  184. Need Help! Removing Auto tranny.
  185. I read the sticky - srs light on after battery change
  186. ebay fogs stopped working
  187. click sound when release clutch
  188. 2001 civic pulls to the left
  189. Terrible ride in NYC
  190. air cleaner case trouble
  191. 01 vtec question
  192. Does your gas gauge suck? Mine does.
  193. One common problem and one strange
  194. anyone know how to check the timing belt or should i take it in?
  195. screws under front bumper?
  196. Possible Tranny/Clutch Problems
  197. Possible Tranny Prob. Please Help!!!!
  198. rainy day rattle
  199. trim on doors
  200. clutch problems
  201. I have no clue what happened...help?
  202. Gauge lights out.
  203. cold air coming in?
  204. Help!! My car is knocking
  205. stripped nut
  206. Ame Short Ram Caused Check Engine
  207. Need Help!! Removing alternato
  208. cat. converter rattling
  209. RPM jumping from 4-1000 wile driving
  210. screeching sound coming from auto tranny.
  211. Blinker problem when braking with headlights on?
  212. Blinker problem when braking with headlights on?
  213. Fuel Gauge/low fuel light
  214. V-AFC II Problem
  215. Tein Coilover Poping Noise.
  216. Stuck Window on 2004 Civic?
  217. Help taking out CENTER CONSULE on 04 EX
  218. Revo SS (broken??)
  219. honda civic es3 rs seek for help
  220. secondary o2 sensor
  221. Shaking at 90kph
  222. weird shaking or idle...overheating too!!!!
  223. here is a question if anyone can help....
  224. Speaker problems
  225. need help
  226. Having crazy headlight problem, maybe sombody knows??
  227. injen coal air intake grounding problem
  228. TCS Exhaust
  229. Steering Wheel No Longer Locks
  230. Block Heater
  231. Broken Motor Mount?
  232. Weird Sound After Running Into Deep Pothole
  233. car surges
  234. issue with my car
  235. 2001 Ex / Flasher???
  236. replacement bulb for climate control knobs
  237. Battery Light Blinking??
  238. E-Brake problem
  239. Greddy EVO 2 Exhaust on a Sedan
  240. Idle problems after DC sports tcs install
  241. help with adjusting valves on a frankinstein
  242. Injen SRI
  243. 01 Exhaust
  244. Speedometer help.
  245. E-Manage: VTEC Not Working
  246. High RPM's
  247. AT downshifting when braking
  248. SRS problem/complete frustration with 05 Civic
  249. Acura 1.6EL parking light bulb replacement
  250. first issue with car. dealer response strange?
