View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. One Big Problem Very,Very Slow Civic(help)
  2. shifter rattle in 5th
  3. whining noise while driving
  4. battery or bad starter??
  5. No One Knows?? Problem Not Solved!
  6. daytime running light problem
  7. Where to find a motor mount or tranny mount?
  8. deleted
  9. my tranny just died and I'm stuck at work
  10. brake pedal
  11. Seventh Generation
  12. Code explain help
  13. Air Control Valve
  14. HELP: My SRS and Battery Light on W/High Voltage warning
  15. Help a newb with a code
  16. Brake Light on
  17. Power window question...
  18. help cooling problem (searched)
  19. clutch problems
  20. TSB Question
  21. Grinding Noise in the Rain Only
  22. Auto Tranny Problem
  23. roaring?
  24. noise somewhere in the car
  25. Pulled codes and need some help!!
  26. Air Condition Problem
  27. no reverse gear?
  28. Gas Cap Cover Wont Open Help A.s.ap.
  29. required maintainace light
  30. Left axle leaking
  31. whats the part number??
  32. One Click in clutch pedal when pressing
  33. Car Not Wanting To Run
  34. Screeching noise
  35. Clutch and shifter problems
  36. Whats wrong with my A/C
  37. loud noise when driving over 75 mph
  38. weird now im pissed/upset
  39. HELP! engine malfunction light on.
  40. Radio station changes by itself....
  41. Anyone with an automatic tranny ever experience this?
  42. And the problems just keep coming...
  43. Brake help
  44. Weird noise coming from my AC.
  45. Break-in = Water leak!!!
  46. Annoying high pitched sound coming from the front driver's side of the car...
  47. Here you can find the diagrams of any Honda
  48. ECU Problems?
  49. HELP, still no pressure, all new parts!
  50. A/C air conditioning warm
  51. A/C Problem
  52. Need major help, Car does Not start after Fuel filter change????
  53. My gas door won't open, It broke!
  54. 2001 Honda Civic LX Air Conditioning Issue?
  55. Crank pulley bent?!?!?!
  56. Radiator Fan!!
  57. Flyer fell down the driver's side window.
  58. Headlights keep blowing bulbs (lowbeams)
  59. Post timing belt question
  60. Interior Shifter light out?
  61. Temp. gauge oscillating...WTF?!?!
  62. what's wrong with my speedometer?
  63. Weird Radio Problem
  64. airbag light on
  65. Power Window Switch broken
  66. first civic problem yay!!! :(
  67. Transmision Noise
  68. transmission grinding
  69. alternator low output
  70. FORUM RE-ALIGNMENT. confused? read here
  71. 0420 engine code
  72. Warrenty
  73. My civic is loud, in a bad way...
  74. tranny dead where can i go?
  75. lights don't turn on and check engine light is on
  76. Gas needle doesnt know where to go?
  77. transmission bearings
  78. Problem with Door panel - 05 coupe
  79. Transmission Whine - Normal in 4sp Auto
  80. clicking on the shifter??
  81. 95 Civic EX 1.6L - AC issues
  82. starting trouble
  83. a tricky problem
  84. RPM goes up and down
  85. tranny is slipping.. what to do?!?
  86. hood wont close
  87. Flickering battery light on dash
  88. Week of hell
  89. clutch
  90. HID problems
  91. grrr... right headlamp fogging up...
  92. What's the best way to get a dealership to work with you ?
  93. my car sucks in the rain
  94. ****Back plate touching rotor = Stranging clicking noise when turning right
  95. Slighty Bent Radiator
  96. Window Weatherstrip
  97. Check engine light?
  98. Check Engine Light on, bring to dealer under warranty?
  99. Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
  100. Who's had a bad transmission? *UPDATED*
  101. OBD II Code P0132 - O2 Sensor
  102. Engine Mount Issues
  103. I F'ed Up Big Time. i think??
  104. Sensor in intake popped out, can't secure it
  105. Creaking sound after stopping the car
  106. PROBLEM: Rear LEDs blink too fast! HELP!
  107. Coolant splatter when filling reservoir
  108. Lost Keys
  109. Clutch Pedal getting Hard
  110. nothing happens when i push the panic button...
  111. Car not going past 3k and backfiring
  112. Check Engine Light, OBD II code P1706
  113. Steering Pop Noise
  114. AC issues
  115. Simple light Problem, But still can't figure it out..
  116. Knocking noise! Plz plz help!
  117. 70mph noise
  118. Electrical Problem (Caused by shop)
  119. Check engine question
  120. Broken Wheel Bolt and Manifold stud
  121. throw out bearing
  122. Tranny slipping?
  123. interesting idle problem
  124. Burnt smell
  125. Excessive cranking at start up
  126. Balancing Alloy Rims ??
  127. Vibration at 1100 rpm
  128. crazy problems
  129. no clutch pedal
  130. Side airbag light on/off frequently
  131. altenator bolt
  132. problem with signal light
  133. another problem: stock cd player
  134. OBDII Code P1166 (air/fuel metering)
  135. Weird noise coming from engine need help!!!
  136. OBD II code- P0730 Problem in Shift Control System
  137. What does this code mean?
  138. Grill Not Working Wiht Body Kit
  139. How to eliminate the rim or tire as the cause of my car pulling?
  140. Stock clutch
  141. cant get accurate reading on dipstick
  142. help w/finding ground wire
  143. Headlight Problems... HELP Please
  144. 2003 EX CP - P0420 Catalyst System Efficiency Below Threshold (Bank 1)????????
  145. Fender Problems
  146. Lowered Car - Now Cat Drags - Any suggestions?
  147. How low should your gas pedal go down?
  148. Blown fuse?
  149. 98 hx non vtec OBDII p1336?'s
  150. Anyone have to replace any of the dash lights yet?
  151. VTEC Question
  152. where isthe ecu located?
  153. battery light is flickering
  154. A/C Question/Problem
  155. headlight wire connector
  156. cars burning oil
  157. Which PCV and where does it go???
  158. P0113 ??'s
  159. dont start
  160. How long is Battery Life?
  161. Need Help P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
  162. Two quick questions
  163. auto trany
  164. clicking when starting to move
  165. skirt corner comes up
  166. Shift knob
  167. Brake fluid Ex.
  168. i turned the steering wheel, but nothing happened...
  169. Popping sound when shifting
  170. 94 Honda Civic EX misfire?
  171. pulley help
  172. Dash trunk light on but the trunk is closed?
  173. 02 Susp and Man Trans Problems
  174. Pedal Vibrations
  175. Shaking/Miss-firing?
  176. Growling noise from back of engine
  177. How to adjust idle rpm ?
  178. Odd Problem: Engine Turns Off When Breaks Applied with Check Oil and Battery Light On
  179. Dash lights do not come on.. car won't start..HELP!
  180. Starting to hate my dealer
  181. front light out
  182. JDM DC5 Steering Wheel Causing SRS Light
  183. Stock 01 rear suspension Sqeeek..HELP
  184. so now i have a wiring problem
  185. Car Wont Start
  186. Weird Squeak...
  187. RPM is dropping while driving
  188. exhaust rattle
  189. Does Any One What This Could be ?
  190. Headlight bulb
  191. P1106 code what to do? pls.
  192. drivers side headlight flickering..dont know what to do??
  193. Steering Shakes.. VTEC Q...
  194. three codes on 2001 civic ex
  195. 96CivicVtechE My Cooling fan wont turn on
  196. rattling noise in front after parking
  197. hood vibration
  198. oil leaking out of valve cover
  199. removing 05 civic factory stereo
  200. how to remove air filter?
  201. 2005 Civic LX air conditioner woes
  202. dont know what title to make for this...
  203. Replace the TCC Solenoid?
  204. Do you do a full stop before putting car in reverse?
  205. 2003 Civic Sedan - Hesitation (Posted Previously in wrong forum)
  206. dashlight issue!
  207. some strange problems this morning
  208. Questions on when to change/service tranny & a/c system:
  209. Spark Plugs: Iridium, Platinum or Copper?
  210. transmition clicking?
  211. need help rattling noise
  212. Blinker
  213. new radiator...
  214. Noise From Rear End
  215. Bootleg fuel sending unit / gas gauge...
  216. why does this keep happening?
  217. Brake Noise
  218. Are Honda Batteries Better?
  219. Trunk Light won't turn on!
  220. WTF IS GOING ON!!!HELP (engine)
  221. ABS comes on at low speeds?
  222. High pitched noise? help plz
  223. SparkPlug Wires question?? :)
  224. coolant issues (update on post 6)
  225. Magnaflow Installed!!!!
  226. pass. door panel rattle ?
  227. rattle clip pop chirp,
  228. 5th Gear Slipping??
  229. New spark plugs and WORSE gas mileage...
  230. rattling or grinding
  231. Sunroof Smashed
  232. Replacing broken mirror...
  233. Driver Side Wiggle...
  234. Gas Problem
  235. Air leaking through vents when off
  236. clutch grinding
  237. Aint this a *****
  238. Any other 2001 with the fix-A/C,Brake Light &P/L Problem
  239. Hit a deer.
  240. stuck in park
  241. Axle help!
  242. 2001 civic valve tick
  243. valve-clearance
  244. Problem!! Engine Check Light...
  245. How to adjust a slipped steering wheel???
  246. Ac Smells Like Rotten Eggs???
  247. How to empty gas tank?
  248. Trany popping out of gear
  249. Speedometer bounce
  250. feel the road in steering wheel ?
