View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. can you tell me whats wrong with my car?
  2. Fuel Gauge Incorrect
  3. car wont start!
  4. Squeaky noise from suspension
  5. OMG almost phuked up LARGE !
  6. Projectors
  7. light recall
  8. 2001 ex sedan problems
  9. reverse actin weird
  10. Well this chaps my ass
  11. Well this chaps my ass
  12. Dang the Engine Light
  13. clutch cylinder problems
  14. blown transmission!
  15. Blower Motor
  16. Never Ending Vibration Problem? Any Ideas Here
  17. tyc headlights
  18. 03 center console question
  19. how do you deal with...
  20. black oil in h22
  21. Power Stearing Fluid
  22. passenger mirror easier to clean?
  23. anyone with trans probs?????????????
  24. 2004 Civic EX sedan weird noises starting from a complete stop
  25. recalls!!!
  26. 01 civic problems?
  27. rear dome light
  28. Replacement spare tire??
  29. Every window but driver doesnt work :(
  30. AC problem
  31. Engine Light On Code P0113 Help!!!
  32. 04 EX Civic Engine Noise
  33. problem can't figure out . . .
  34. i have a problem
  35. Noise in front end
  36. Solid motor mount question...
  37. Arhrggg I think I just Busted a Coil Spring on my 05
  38. engine coolant leaking
  39. Hydrolocking?
  40. My car makes me sad
  41. Sunroof question
  42. Got a new transmission!
  43. valve lifter noise/vibration
  44. Shaking Brake Pedal
  45. Clicking sound when parking.
  46. 70mph and the shocks break!
  47. Wtf
  48. Need A/C Pollen Filter
  49. Exhaust: Heavy vibration
  50. do i need a new clutch???
  51. Help out with stupid hazard lights
  52. car thinks is in drive when in park
  53. WTF?!?! My windows jus stopped...windowing..
  54. Strange noise, I've never heard on a car!!!
  55. break problems!! help
  56. 2nd gear poppin out
  57. EX Civic Front Bumper Flange
  58. Heater problem
  59. Clutch Problem.. ?
  60. How many miles are on your clutch???
  61. Transmission problem - RPM flaring
  62. loud catback system (help)
  63. O2 sensor wire harness
  64. rear springs sag
  65. Everything rattles in my '05 interior after 3000 miles.
  66. whirling freeway noise
  67. Strut replaced under extended warranty...
  68. Wierd Noises...
  69. damn suvs
  70. steering wheel shakes over bumps,etc.
  71. stupid honda
  72. The stupidest problem ever.
  73. Check Engine Light
  74. Carfax Here!
  75. shift knob shakes
  76. Question for anyone who knows about wrecked vehicles getting fixed
  77. Car Takes Longer Time To Start - Why?
  78. Strange sound when Turn to left
  79. Drivers seat crooked
  80. question about gauges
  81. Hit a Pothole :(
  82. Steering Wheel Does Not Lock
  83. Lost radio code
  84. New exhaust hangs to low
  85. wtf piece of shit 10a fuse - speedometer dead
  86. engine noise in '05 Civic LX
  87. Speaker/3rd brake light rattles
  88. squeaky brakes?
  89. projector headlights problem
  90. Maint. Req'd light reset and information
  91. Headlight Help ...... Please????
  92. Headlight Help ...... Please????
  93. Compliance bushing????
  94. Shift Lever..........
  95. Car Hesitating bad.. Please help.....
  96. SRS light won't turn off. Did I break a wire?
  97. I hit a cat - Crack on front bumper!!!
  98. Thunking Sound
  99. downpipe hits sway bar!! (help)
  100. Rev Limiter Kicks in at 3900rpm
  101. Lambo doors.
  102. Car kinda struggles in 2nd
  103. Ignition problems?
  104. sounds when turning left and seal peeling
  105. Intake/Fuel Rail Plumbing Question
  106. Daytime Running Lights...
  107. CEL Came on. Rocker Arm?
  108. my car was side swiped
  109. wats wrong with my car?
  110. warranty issue
  111. Abnormal Tire wear??
  112. TSB's Technical Service Bulletins
  113. Different Clutch and Tranny Problem
  114. seat belt alarm on 05 accord
  115. RPM signal wire?
  116. Should I do my timing belt?
  117. Loose Steering Wheel
  118. license plate frame light
  119. Stiker Plate
  120. wierd sound
  121. wtf is up with my auto tranny? HELP!
  122. Radio/security
  123. bad shake when i start
  124. i need alittle help
  125. srs
  126. RPM drop during idle
  127. Tranny problem...
  128. Alternator
  129. Leaking Strut and Torn CV Boot
  130. Speedometer not Registering.
  131. ops, delete this one
  132. !!help peeps.. fuse keeps blowin
  133. 2001 Civic LX with EX parts?
  134. 2001 Civic LX with EX parts?
  135. removing the rear deck
  136. removing the rear deck
  137. my left back seat wont unlock wtf
  138. what honda says vs. what you guys say
  139. Loud bang after 1st or 2nd gear redline
  140. Loud bang on 1st and 2nd gear redline
  141. high pitched sqeaking noise while driving
  142. Help with Swapping Auto Transmission
  143. my car making metal scraping grinding noises!! help
  144. lost a wheel lock/lug nut
  145. need motor #3?
  146. 05 problems??
  147. fog bulbs are smoking help
  148. 18" wheels??? Please Help???
  149. gauges
  150. Bubbling Power Steering Fluid
  151. oem headlights
  152. Hood vandalized!
  153. Insurance Company problems. Need help
  154. headlight went out
  155. Shot Power Steering
  156. Ringing Noise
  157. Top speed?
  158. I was at Wendys today and...
  159. Rear Brake Light Question
  160. ABS light
  161. starter relay
  162. some rattle when I press on the brake while stopped
  163. idle control valve issues
  164. Service manual on CD
  165. Air bag light
  166. Struts
  167. fixed vtec myself
  168. weird noise
  169. Car not under warrenty, TSB Still apply ?
  170. Over-Reved (Check Engine Light On Now)
  171. My door pin is broken
  172. Help With My friends AC problem?
  173. Anyone know how to fix that annoying rattling sound from the rear????
  174. Women drivers should be considered a road hazard...
  175. engine is loud
  176. lx headers
  177. Hondacare and TSB's
  178. help, car idling weird, gas mileage going down!!
  179. water inside car - windshield help
  180. Clutch Problems?
  181. I have a lot of problems
  182. shaky steering at 70mph
  183. whats the part# for this?
  184. R134A Refrigerant....
  185. ticking sound from left side
  186. Idle at 1500
  187. Powerful brakes
  188. Car Leaking Air From Front
  189. starting trouble?
  190. D17 transmission needed!!!!
  191. my alternator dying?
  192. how much is a new automatic tranny? ****...
  193. lights dying.. grrr
  194. blinking check engine ligh
  195. Field day for the Dealer!!
  196. disconnecting srs
  197. weird noises
  198. Squeeking Sound? Help!
  199. nothing works when key is out?????
  200. Metallic Chain Sound
  201. Transmission Trouble!
  202. Tire wearing issue?
  203. Cruise Control is not working.
  204. SRS Light
  205. Innacurate Fuel Gauge
  206. any other 7thgen out there with these problems????? arggghhhhh
  207. Steering problem
  208. Power Locks that don't work...
  209. Funky Sounds
  210. Any advise anybody, check light on lumpy idle
  211. deafening intemittent humming
  212. broken engine mount
  213. My AC compressor doesnt turn on
  214. Rain water in cabin
  215. o2-speedo problem...help...
  216. trunk and gas opener resisting
  217. crazy squeaking in the back of my civic...
  218. Trunk Lock
  219. hood rattle
  220. intake rubbing on hood
  221. headers..
  222. Tranny is gonna blow
  223. Hazard Lights
  224. Car won't start help...
  225. Tranny??
  226. Typical Noise............?!?!?
  227. Tranny gone? Auto
  228. driver's door doesnt lock, but actuator seems to be making noise!
  229. need pics of hinges of the trunk
  230. Brake oil
  231. Help! Engine Dies While Driving!
  232. Dont know how to explain the problem, please read the post...
  233. whats wrong with this??
  234. alternator died already!? help!
  235. Gas Guage n Some Squeeking
  236. Transmission
  237. 2002 Honda Civic SI Axle Breakage
  238. Tranmission Problem 03 Civic
  239. Clunking noise, possibly transmission? Help!
  240. Funny Plastic Smell from Undercarriage.
  241. Cat
  242. 02 ex will not run right....pissing me off
  243. weird sh!t gas cap won't open stretched cable
  244. driver side rear door lock malfunction...
  245. Clicking Noises 7k miles!
  246. Leaky Strut? I just got a brand new one free @ 130000km!
  247. Clutch or tranny??? Need help fast, Im stuck at work!
  248. Engine Stalling
  249. 3 trannys later same sH*&!!!
  250. Buzz after downpipe install...
