- Hood Trim
- I think my clutch is about to go?
- Headlamps burning out
- Guage Cluster Problem!
- Can anyone tell me whats wrong with my car????
- My progress rear sway bar hits my evo2 exhaust. Got any ideas?
- vtec malfuction
- CEL On, Car Feelin' WEIRD!
- Would you recommend your 7G civic?(esp 05HX)
- Auto Shift Mechanism Problems
- Heater doesn't work???
- my civic=K.O.
- Service Bulliten request 97-009 FEB 00
- Sedan tail Help
- Sounds like water stored in my engine bay when I accelerate slowly.
- short shifter adapter
- cooling fan issue
- please help!!!! my car won't start!!!!
- First Gear Won't Engage
- am i missing something?
- hmm i searched and no correct answer
- Water draining back
- RIP Driver-side eyelid
- Noise when steering and breaking...
- Removing A/C, what belt replaces the old one?
- Can Working on your car yourself, void your warranty.
- brake problems at 30k?
- left front of car sags?
- Smack that Guage cluster!!!
- Squeak when accelerating hard and shifting from 1st to 2nd
- 91 civic Help!
- ODB II Codes
- Help on ecu
- p0138 code ecu
- windshield sprayers drip
- flat repair: plug or patch
- Clutch noise
- Dash trim panels. Carbon, Brushed etc...
- double click window button
- Starting problem
- slight hesitation at 50
- Reset Maintence Req'd Light
- Reset the Maint r'qrd light
- Questions about this.
- civic 92 dx,not much power
- another o2 simulator thread
- struts........yea i need help
- emblem problem
- Adjust power steering asist?
- 02 Celica GT. 5speed Tranny prob.
- Car randomly won't start sometimes
- V-AFC2 Programming
- High Pitched Belt sound .. am I overreacting??
- help side taillight bulbs not working
- section under bumper ripped off
- rough cold start in the moring
- Yeah so... car won't start (video)
- door locks
- Would 4-dr oem sides and rear skirt fit on 2-dr?
- Finally
- spun rod bearing....
- power steering is now fixed!
- 2002 Civic EX brake pad (failed inspection)
- Im getting some horrible gas mileage....
- squeking sounds!!
- factory recommended maintenance list
- Head gasket
- Please Help
- parts
- bogg....
- New Engine, what kind do I get?
- wil my warranty cover this?
- people with autos
- engine mount crack??
- Pounding noise when turning and shifting?????
- interior plastic faded by alcohol!
- can't stand no vtec
- cd player used as piggy bank
- stock suspension
- Loud popping noise when revving @ high rpms
- Cold air intakes hate the cold!?
- Brakes Scraping
- Bumper not flush with fenders
- Interesting thing happend last night...
- Tick tick noise from the rear
- Tick Tick noise from the rear
- Hole in rear bumper
- I'm stumped-and need help ** single POP when turning at low speeds
- First Oil Change
- light vibration from glove compartment area
- ummm... hot?
- crazy idle? wtf?
- cracking noise at 2k
- Speedometer not fully illuminated
- Warrantee almost up, what to do
- turn signals died
- Car started like SH!T today?
- cold weather
- DIY on Radiator flush
- Paint chipping on hood
- Moonroof wont vent all the way on its own
- WTF!! Bottom of car is dented/cracked and protrudes into car
- All of a sudden very hard to shift gears?
- Squeaking noise for about 5 minutes after startup?
- engine problem ?
- car shakes at high speeds
- popping noise w/ rsx rear sway bar
- Help!!! Major Problem After Installing Injen Cold Air Intake
- tyc headlight problem
- Paint cracking on urethane kit HELP
- Hesitant Acceleration 04' Si
- please help, engine stall on automatic transmission
- wierd noise. intake???
- My car not the same car it was 34,000 miles ago...
- some wierd noise and feeling
- i think somethings wrong...
- power windows
- My stock spoiler n trunk are getting spots
- Truck Won't Start
- lighting dimming problem on tyc's
- my car stalled
- O2 simulator fix P0141 obd2 code?
- CEL map/baro low voltage detected?
- So pissed!!
- stupid noise around 2500 rpm
- second gear slipping
- SRS light
- Rubber Guard under Front Bumper
- Exhaust rattle against sway......
- 30k Maintainance
- Heated power mirrors
- Healiner Removal?
- Crack in Windshield / Warranty?
- Low idle weirdness?
- Tip for clearing condensation on windows
- bad indaglo gauges
- Scratched Headlights
- Wrecked my car
- Air Leaks
- Manual trans service
- HELP!!! Engine Popping
- Manual Tranny...
- Help me out with my vic not startin
- Check engine light from snow "drifting"
- Trunk Bounce?!
- ABS and SRS light come and go
- Bubbled Paint
- automatic window troubles
- HELP!! my civic is f***ked
- Help!!
- '04 SiR Fuel Capacity Myth
- blown headgasket...warranty DENIED...please read.
- engine idles w/ a different sound
- How cam I reset my cluster?
- Knock Knock....What's there???
- Wierd metal grinding noises?
- Ending to Tranny Problem
- Big Noise when it rain in my trans
- you think this is covered under warranty ?
- MP3 and Text...???
- Problems.....
- Exhaust question
- uh oh?
- HELP: oil pressure light comes on, car stops accelerating; restart and it's fine
- tranny
- rattling sound from dashboard
- how to retrieve a screw that fell into front vent holes
- Well I encountered my first Problem with 2005
- Subwoofer setup wires?
- Tach prob
- Tranny/Clutch Problem
- car giving off smell
- Overhead Lights?
- here we go again. b!tch wont stay in gear
- P0141 OBD2 code
- Bent Valve
- Malfunction Light
- AHH Audio Code
- 01 -03 exhuast install Q
- Momo Steering Wheel Installation
- SRS Light on!
- seatbelt tension on 01'' coupe
- 04 coupe pulling to the right.....
- Clutch Pedal Squeeks
- Maintenence required etc.
- Brake Fluid Low
- Maintenence Light FAQs *Please read before posting*
- Need Help!!
- Should I take out my AEM SRI before going to my 40k maintenence checkup at the dealer
- whining noise?
- adjustable fuel regulator
- Cracked fog lights covered under warranty!!!!
- Problem with Charging System?
- Maintence required...
- Who Has......
- Abs
- transmission solenoids
- SRS Lights
- Alternator went bye-bye
- Knocking Sound when shifting
- Still having cooling fan issues...
- OEM Header Problem
- To Those Who Have a Automatic Transmission, Please Do Me A Favor???
- Automatic shifting into ?3rd? revs..
- Possibly fried some wires
- problem wit lights
- plug under right headlight goes to nothing???
- oem cd player reads cd error
- If You have A Automatic Transmission, Do Me another Favor?
- No more beeping sound
- Why the heck does it double post weird
- Anyone know how to get around the OEM Radio code???
- Help with gauge cluster!!!! Speedometer is reading wrong
- is it a dead battery or alternator?
- my custom gauges dont work
- warrany troubles please read
- 5w-20 or 5w-30
- Manual Trans Fluid
- Bringing the car to the dealer again...what do youthink is wrong? **UPDATE**
- Idles at 400 and kinda sputters like its gonna die
- Turn signal blinker not working
- wheel stud removal??????????
- o2 sensor question
- Rear brake Drum question
- 2002+ Si Shifter
- whirring sound on startup
- help..car would not start
- Hey you Auto Tranny guys...
- fuel injectors? 1988 corolla carb
- Clutch failing under warranty.
- cam gear
- I got a leak somewhere!!!
- Any chance Honda will hook me up? If not, help me please on DIY.
- CEL P0505 Help
- Please help me out guys!!!
- Shaky rear view mirror
- 04-05 fogs, anyone have a lense crack yet?
- Windshield Scratching
- Help...
- inside door handle is pealing
- "THE GREAT BLIZZARD OF 05" SUCKS!!!
- My 04 Civic EX Coupe needs your help.
- electrical stuff won't shut off
- Should I be worried....
- bad struts in 01s? recalled?
- How does you car sound??
- RPM 4100 and check engine light
- sway bar problem
- alternator
