- change or flush coolnat/anti-freeze
- foggy windows
- Car Shakes
- problem with driver sided headlight
- Problem with heat
- Srs Dashboard Light, Wtf?
- Smell of gasoline in the oil....
- rattling noise,,no help from honda
- Anyone else's seat alignment off?
- TSB help
- shocks(struts), low control arm bushings
- air filter box screw
- Heater Overheating
- o2 sensor heater control?
- re-fill coolant
- 2 interior questions
- Best way to remove stupid decal??Plz Help!!
- CEL Problem Solved!
- Side Air Vents
- Dead Battery?
- oh snap
- Tranny is GONE!
- oil leek????
- Help Asap!!!
- Whats wrong
- is normal to your 02 civic?
- Oil has strong Gasoline smell....
- has anyone else had this problem?
- Clunk Sound when Braking is normal?!
- right turn woes
- Popping out of 2nd gear.....
- Anyone had the same problem I had with the motor?
- Man't Req Light
- Power Windows
- Crunching front squeaking back
- Parents just don't understand...
- Parking and Tailights Out
- whats broken?
- Hood Not closing all the way
- Some Punk Dented My Car!
- Oil pan "wet"?
- Popping sound on cold engine 01 Coupe
- How do I oil my bearings?
- window lockout button
- Squeaking front suspension - due to poly bushings?
- left turn signal gone crazy!
- Gas Door
- whats going on w/ my car
- Normal current draw when car is off?
- Firestone Recalls
- subfrmae question how much?
- lower ball joint boot split at 41,000 miles
- When to change brake pads
- serviceable joints
- My car stalled and died while makin a turn!!!
- Fuses?!
- 2nd gear clicks
- I can't take this sh!t anymore!!!
- Help with Alarm Scanner, please
- Hesitation in Acceleration..
- Tips For Better Gas Mileage
- Bogged Acceleration..
- Clickin Noise
- weird sounds
- Hood Rattles like a BI@TCH!
- maintenance light?
- maintenance light? to Ronin
- Broken Slave Cylinder...WTF?
- transmission wont shift??
- Air Conditioning Compressor
- rattles when accelerating
- ac dont work
- Clicking Noise In Engine ?? What to do..
- normal coolant loss?
- 2004 Factory Lip Kit Cracking
- Stupid SRS light
- Question bout rear bumper
- Honda Low Beam Headlight Recall
- Heat shield rattle help!!
- Steering wheel shaking
- Clicking Noise When I Back Up
- 2003 Civic Recall (Automatics)
- Does anybody else have any annoying rattles in the interior from their exhauist?
- AC light?
- Thinned out oil...Potential Problem?
- Engine Problem...
- Rattle when idling coming from clutch mechanism?
- Front Brake Question
- rattling coming from somewhere
- Vibrating Problem
- touch up or not? (looking for a different way to fix scratch)
- kaminari side skirt getting caught on door
- Car Lurching, turning off... Help! *UPDATE*
- Hey cool, the bumper's peeling
- Thumping noise when turning and making U-turns? Need help?
- looks like rust oozing out of my spark plug coils....
- The mysterious whistle problem
- Strange brake grinding condition
- WINDOW SHATTERED.. HONDA won't help as always
- Gauges Fading in and out
- whos says theres recalls on our civics!!!!!!!!
- How many miles from OEM Pads?
- Advice needed
- my radio stolen, ne 1 knoe how to install a clip?
- weird nose at high speeds
- Problem with your Heater? BLOWN HEAD GASKET!
- Map Sensor Connector Broken Wire
- A/C and heating
- automatic trans question
- unusual smell when accelerating
- im gonna hit 30k miles
- Door and window rattle
- Is My Clutch Done For!????
- was there a 10k or 15k check up? ...
- broken power door locks
- 2001 Trunk Mat Problem
- Simple Oil Question
- Automatic Transmission problem...HELP!
- Grinding Noise from front of the car
- Clicking noise when accelerating
- car start trouble
- 8,000 mile Maint. Req. LIGHT
- Help!! Car Backfiring!!!!!
- Updated TSB bulletin 02 clutch noise
- TPS Problem
- torn up caliper piston boot
- nasty rattling from dash?
- Excessive oil consumption on new 04
- Prob w/ car almost caused 3car accident need help
- vibrates when cold start!
- knocking noise when i turn the steering wheel
- ac wont turn on?
- Gas door problems
- Cancel warranty
- Safety Recall ALL 2001 civic's some 2002 civic and Hatchbacks
- Been nice reading this board . . . I've sold my Vic
- sound when i shift ...
- overheating why
- HELP! I cant rev past 4k
- the air stinks inside my car???
- whats up with our paint?
- bad luck or what?
- Clutch Is Deadddd!!
- Transmission is FUBAR
- 01civic wont start.
- Battery Acid Spill. Help!!!
- maintanence required repost
- Steering wheel lock?
- Loose rattling sound under passenger floor
- My girlfriends Neon...
- Need a new transmission
- turning light
- HELP! thread for lugnut is messed up
- 40 PSI on my 04 from the factory!!!
- check engine light code OBDII
- CARBON FIBER HOOD issue...
- clunk clunk clunk...
- Vibration while braking...
- clutch issue
- Does a 2002 LX Lower Panel fit an 01 EX?
- Hoods
- Drums
- Im Sick Of It!!!!
- The recall and projectors/HID
- S mode on CVT<<<
- headlight fogging
- Running lean???
- revs dropping below 500
- removing plastic wheel well?
- Chrome Strip Removal - HOW???
- What to do with that nasty seam under the doors.
- Heres a stumper
- Downshift by mistake
- AEM V2 Intake broke at the braket
- Why does my car jerk?
- Popping out of 5th gear after clutch install
- Does ANYONE know what this is?!?
- i need a list of what violates warranty
- Header Heat Shield
- Dash gauges making noise?
- Rage!!! *56K Go Away*
- glovebox rattles, notice?
- J/W if checking breaks for wear/problems is for free
- popping sound from engine bay after fipk II
- Burning smell
- struts blown at 20k miles
- Chug a Chuggin
- Cars Freaking Out!! Need Help!!!
- DIY: Hood rattle repair.
- Driver-side auto-Lock won't go down or up
- HELP gas lever..
- 02 typeR grill on 03
- body paint fade
- exhaust problem
- headlight switch recall
- Warranty Covered????
- Ruined interior!
- Stock radio problems
- 03 and 04?
- malfunction indicator lamp problem
- warranty bs
- sign this petitions (si ans rxs tranny prob)
- rpms are bouncing
- car heavy and sluggish? u too?
- wierd sound....
- tranny problem.please read
- **6 recalls on CvC's**
- 2001 head swap on a 2002
- weird muffler angle...
- Auto Transmission gone to heaven
- Clutch or transmission problem
- car shaking like mad? need help *UPDATE need even more help!
- Power Locks Don"t Work
- My car Hesitate??
- Minor Interior Notables on EX Sedan (02 vs. 04)
- help with a squeak noise from the engine?
- high-pitched whining sound on rainy days
- Car has good and bad days?
- please help! blinker problem
- Leaking Rear Brake Cylinder
- problem with exhaust...
- Problem with angel eyes headlight
- are they ever going to stop leaking?
- exhaust
- clutch feels "funny"
- Water problem!
- stock airbox broke!
- Car Problem, Fuel System
- A/C Compressor Won't Engage
- Speedometer fluctuation?
- Oh look another auto transmission dead. My legacy.
- Problems Already??
- MT problems??
- Terrible Gas Mileage
- Clutch problems
- HELP stripped bolt on cat conv. while changing exhaust
- Power Steering?
- Honda logo on valve cover?
- What is making this noise?
- RPM @ a cold start
- Driver AIRBAG?
- car starting probs
- engine dead
- Issues after Installing Speakers
- Rough Idle Cold???
- A/C condenser broken, needs to be fixed
- Help...hp header problem
- Suspension Problems?
- Need help with OEM remote door opener problem?
- Steering Wheel Noise
