PDA
View Full Version : General Automotive Discussion
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Credible websites
  2. How many of you benefit from sunroof or convertible?
  3. TOPDON V2200Plus 2 in 1 jump starter and tester
  4. A new player has entered the game
  5. Civic for New Driver
  6. Brake pads bent
  7. Lifts / Garage Space for DIYers
  8. My leaking 2003 Ford Windstar of coolant nightmare
  9. Dashboard Warning Lights - Common Myths and Truth
  10. What is this plug?
  11. No crank / electronics dead
  12. Best way to junk / recycle / sell a dead 2002 Civic LX in Northern California?
  13. I need suggestions
  14. Car Buying Advice Needed
  15. wiring a engine swap - it's not easy, folks.
  16. Engine swapping a civic engine to 85’ el camino
  17. Thanx to all
  18. Rough Idle
  19. What does the stock air system do?
  20. Car making clicking noise on sharp turn
  21. Is underbody engine cover necessary?
  22. 06 V6 Accord bad shake while changing gears
  23. P0122
  24. Importing a car from canada.
  25. general question about buying engines
  26. '79 Spex Kit Car For Sale!
  27. Need Buying Advice--Civic, Corolla, or Their Equivalents; Budget: $1k to 3.5K
  28. 2011 Honda 2.4 liter CRV Idle Issues
  29. Integra return
  30. weird and difficult to find the cause problems - post your case!
  31. Fuel system check valve?
  32. Instrument back light fuse blowning [solved]
  33. "headlights on" indicator is not beeping
  34. Car just dies
  35. 1977 CanOx Welder Restoration
  36. Modding my first car - Which Civic should I get?
  37. Strange idea
  38. Good shocks/coilovers for cornering and height
  39. Please help. stripped tensioner belt "Adjusting Lock Bolt [Solved]
  40. Heavy Grease
  41. Convincing parents to let me buy a certain car
  42. 8th gen accord 3.5l v6 coupe
  43. Is Honda making Accord 2 door coupe in the future?
  44. Advice for buying used Type R or SI (UK)
  45. ABS Light Stays On
  46. Ran an engine on little oil
  47. Power steering fluid
  48. Can Worn Strut Mounts Cause Front End Vibrations?
  49. Looking for intake help
  50. Build Ideas - 94 Accord ex 2.2 L f22b2 current engine
  51. New sump has no oil level sensor. Can I get round this?
  52. Best method to learn about cars and modifying them?
  53. Honda Fit Discontinued
  54. DIY: How to Rebuild Brake Calipers (VIDEO)
  55. Removing old turbo, Installing new turbo
  56. 2 weeks to get a turbo rebuilt, would i be a "douche" asking for a discount?
  57. Super Specific Question
  58. Damaged Steering Rack?
  59. Can anyone identify which car this emblem belongs to?
  60. What would be the best car pick for me?
  61. Piston rings bad?
  62. Buying a used Honda Civic
  63. Looking for Civic Manual...
  64. civic trade?
  65. Looking to start modifying but basically know nothing
  66. Driver rear window won’t go up or down
  67. External Transmission Fluid Cooler Install Questions
  68. Rear Drum Brakes Question
  69. Officially An Old Man Now
  70. New to Civics
  71. Leather Heated Seats
  72. Best battery for 2007 2.2 Diesel
  73. GMC Acadia O2 Sensor Bypass
  74. Does anyone know what this is?
  75. Need help
  76. What did you get your car for [insert winter gift-giving holiday here]?
  77. Engine oil flow rate?
  78. De-stroking engines
  79. Cheap Wheels & Tires vs Expensive (video)
  80. Legit Electric Turbo
  81. Cheap Coilovers vs Expensive Coilovers Video
  82. Minimum safe oil temp?
  83. Car with odometer replaced
  84. buying a car with recalls?
  85. General question.
  86. Car Will Not Start Very Serious Problem Help
  87. Do I have an interference engine?
  88. Rsx clutch replacement
  89. K20 clutch issue
  90. K24 chugging after warming up **Fixed**
  91. Throttlebody change
  92. K20a2 rev limiter at 5500k rpm?
  93. How is ignition timing controlled?
  94. higher revs
  95. Fiberglass fabrication
  96. Are truck engines built stronger?
  97. If they get hurt in my property while working on the car
  98. .
  99. Spoilers
  100. Need help with a part
  101. What is the purpose of "limp mode"?
  102. Installed torque converter dry
  103. Low temp thermostats?
  104. Oil Analysis Results-Honda Semi Synthetic 5w-20
  105. 1992 Honda prelude si
  106. Malaysia looking at the Civic Type R as a Police Pursuit Vehicle.
  107. Year Honda discontinues 2 level dashboard design
  108. P2240 -> p2631
  109. The Last Car Repair Tool You Will EVER NEED
  110. Permatex The Right Stuff fail
  111. New Civic TYPE R up against Lexus LC500.!!
  112. For you kids that keep asking about manual swapping your car
  113. A/C Not Blowing Cold After Fender Bender
  114. Honda civic ex 1.7
  115. 97 civic ex adding power
  116. CRV overnight battery drain
  117. Honda civic ex 1.7
  118. Portable Air Compressor - Is this a good one? Definitely is cheap on Lightning Deal
  119. GolNat's 2013 VW K04 GTI 6MT & 5th Gen Prelude
  120. 2008 CRV rear vibration only with driveshaft installed
  121. Why Timing Belts are Recommended After 7 Years OR 100K Miles
  122. Honda Civic D17a2 ticking noise Please help
  123. Honda Brake bleeding sequence.
  124. Has trouble starting
  125. Pics of our New Vehicle
  126. Exhaust Pics.
  127. extended factory warranty
  128. Upcoming Work On Sister's Car
  129. Surging idel
  130. Walk away auto lock?
  131. Timing Belt or Chain
  132. Which years or models have mpg guage?
  133. K Series Swap.
  134. I cant stand my 2015 Civic
  135. 1998 Civic, No Power to anything after stolen.
  136. 2018 4th of July Sales/Coupons Thread!
  137. Too Many Clowns And Not Enough Ezone's
  138. Is my 2010 civic totaled?
  139. 2001 acura integra ?
  140. E-Manage Blue Update 2018 (EM2/RSX)
  141. Ls/vtec
  142. Can someone please help me figure out what is going on with my car
  143. Honda is Teaching the Next Generation How to Drive Stick
  144. Which honda civic would you buy? 00-2012
  145. Newer Hondas Civics more reliable? Better?
  146. Cars similar to Honda Civic?
  147. Increase mpg fuel efficiency, tricks or mods?
  148. Battery fuse?
  149. Locking Brakes, Red Hot Rotors
  150. Learn automotive mechanics and design?
  151. Custom engines, vtech hemi?
  152. Civic vs Mazda Re: Easy repair, cheap, reliable
  153. Flat RATE or RAPE? for all the techs
  154. 2009 Ford E250 Bank 1 Sensor 1 O2 Sensor
  155. Best brake pads, rotors, stop rust, paint rotors
  156. Suzuki swift - b or h serie swap - possible??
  157. Are all Hondas interference engines? Any non-interference?
  158. Which year / generation easiest to repair, tune, most parts/kits
  159. Bodykit or way to make Civic look like the new 16-18 Sport?
  160. EVIC overhead console display fuel mpg
  161. Totaled civic?
  162. 99 civic si fluctuating cold idle
  163. new advice on 2003 Civic SI hatchback . Looking to buy
  164. 9th vs 10th gen civic gas mileage difference??? *non si
  165. Welding car body shape and frankenstein cars, & metal bumpers
  166. Civic Mods that can be done? Welding? Bodykits?
  167. Re: Difference between dx lx dxg lxi ex si etc Civics Honda
  168. Difference between dx lx dxg lxi ex si etc Civics Honda
  169. please need help with brakes!!!!!?
  170. Help? Buy car cheap parts easy fix? First honda civic?
  171. The auto-industry conspiracy is real. (Don't be naive)
  172. 2010 honda civic no start
  173. Studebaker Truck
  174. List of Repairs Since Honda Ownership
  175. 08 civic lx knock sensor
  176. 01 accord trans and cv shaft issues. Where to from here?
  177. Cod of radio
  178. Solicito Codigo de radio
  179. How to Find a Parasitic Battery Drain
  180. Differential fluid change question
  181. How does car start?
  182. 1995 2.2 non vtech 5 speed honda accord over heating
  183. Problem joining owners.honda.com/login
  184. Phone Mount Suggestion
  185. 1997 CR-V sticks in park
  186. I got to drive a new 2016 coupe today!
  187. Reading Fuel Trims For Dummies (like me)
  188. System to buy a new car
  189. How to Easily Deodorize a Vehicle's Interior
  190. Sunday driven ej8
  191. Need help with deciding what engine to put in
  192. New to me 2012 Civic LX issues
  193. 99 civic ex cranks but won't start
  194. Past 2003, what is the best year Civic to buy?
  195. Off-Topic: Help with Nissan acceleration
  196. Honda CRV 1999 check engine for transmission keeps coming on! Please help!
  197. k20a2 stock or k20a6 turbo?
  198. put ep3'sk20a2 in accord cl7
  199. 2007 Honda Accord idle fluctuates high and low high then low
  200. How well can you do on this knowledge quiz??? (round 2)
  201. How well Can You do on this knowledge Quize...?
  202. 2002 accord supercharged p1259 code
  203. How to Unclog a Sunroof Drain (VIDEO)
  204. "Sealed" Transmission on my 2014 Tucson
  205. Source for cheap 25-30mm Exhaust valves
  206. oh boy am i gonna get flamed on in here
  207. Buying advice for used Civic
  208. This car used to be a Civic
  209. Emission Test question (engine light turns on and off)
  210. HVAC Questions
  211. Accord question, hear me out
  212. Compression Testing Methods
  213. First Mods! 😎
  214. How Much Oil To Use For Wet Compression Test
  215. planning on using these guys for the car inspection
  216. Seat Cushion recommendation
  217. Petition - bring back the 1988-1991 civics+
  218. Suggestions on where to purchase online auto parts?
  219. Air Supply and TB Flap on Startup
  220. What do you think of this bodywork?
  221. Civic, maybe, Engine Help
  222. How to store & clean funnels, tubes, pans and rags etc?
  223. What would you do to a stock 2009 Civic Coupe?
  224. Should I get a 2013 Civic?
  225. sun shade for back windows of civic coupe 2013
  226. When to use low gear on automatic.
  227. DIY: How to Troubleshoot a Starter (VIDEO)
  228. Honda Just Patented an 11-Speed Triple-Clutch Transmission
  229. Top 10 Honda Civics of All Time
  230. The 2017 Honda Civic Hatchback Is A Civic That's A Hatchback
  231. Top 10 Honda Civic Generations
  232. Considering selling my Ford for a Civic
  233. Fumes inside car
  234. BFGoodrich Wants You To Experience Red Bull Global Rallycross Los Angeles
  235. Civic Hybrid?
  236. What socket sizes do I need for working on a Civic?
  237. Iconic Honda Civic Models - Video
  238. Rear Leathers in 02 coupe
  239. New Guy, Looking For A Daily
  240. Honda toy garage at the Goodwood Festival of Speed - Video
  241. DIY: How to Rebuild a Starter Motor (VIDEO)
  242. New Mod... Might be a bit too big...
  243. 2014 Honda Civic
  244. Help please!!!!!!
  245. Historic Hondas
  246. Hot no start issue with 2002 Honda Civic
  247. Tests To Perform On Salvage Yard Engines?
  248. Car wont start.....what to do.
  249. DIY: Leather Repair and Kit Review
  250. Disassemble rear caliper??
