- 6 disc CD player bracket mount in 5th gen 1995 DX coupe trunk
- Need Wiring Connector Help
- audio system setup
- 94 hatchback sub box questions
- No- Running Lights, Gauge Lights, Wipers
- Need a ’93 Civic power window motor wiring diagram
- 1990 1.6 Where's the Fan switch ?
- 2/92 d15b7 Honda civic (ex or lx can't tell because marking is gone) 4 door
- electrical gremlins
- Essential wires only
- check engine light in 1994 civic ex.
- Purple EJ2 swap
- '95 Si radiator fan problems
- wont turn over
- 95 civic problem, need advice.
- 95 civic ex
- fuse box replacement now wont crank over
- 95 Civic AC Troubleshooting Electrical
- what is this?
- Why won't my aftermarket Tac work? 92 Civic D16z6
- 94 civic hatch no brake lights but third upper works...
- 95 civic backup fuse
- 93 honda civic voltage issue
- 94 LX Civic no brake lights
- Turn signal wiring ripped out
- Fuel pump not getting power 1989 Honda Civic Hatchback DX
- ECU or short?
- What harness do I need?
- 93 civic dash & tail lights
- 97 civic hx brake light sensor
- New alternator is overcharging already?
- 95 EX Coupe passenger power window problem
- Grounding issue?
- Stupid Brake Lights
- Possible MCU and ECU problem
- Voltage Problems!
- Radio Wiring / In-Dash clock resets
- cluster pinouts
- radio wiring problem
- Garage door opener causing beep
- 94 hatch LED Tail Light Conversion Question
- Really confusing brake light problem. HELP!
- i have a problem
- 1993 Dome Light (Help Needed)
- SRS light on
- Shift Lock Malfunction?
- Head Light PROBLEMO
- starting problem
- Aftermarket Mess up
- Can't decide on my ef's corner lights!!
- 91 brakes power all electrical
- 1983 Honda Civic 1500 DX Headlight Doors
- Help ID the thermo switch connector
- Parking.dash lights stay on
- 93 Civic EX: ALL electrical dies--then returns by itself!
- 95 civic ex redlining at 6k help
- beasley
- Need help on ecu wiring
- beeper
- 91 civic head light removal
- Key in 2nd pos. nothing turns on..
- Shifter bushings, where can I find them (not the ones for the stabilizer bar)
- 95 civic headlight connector problem
- 1995 civic dx lighting problem
- Brake Light, 94 DX
- 1985 civic low beam headlights not working
- HELP FAST! 1993 Civic EX Back Up Light
- Wiper switch interchange?
- battery light will not come when key is on position
- Civic Cap bolts broke off (cap and rotor)
- Head lights
- HELP!!! Tail light questions
- Gauge cluster lights out
- Need some help
- Speaker sizes on my 94 civic?
- Wiper Switch changeout
- Brake lights out!!!! Please help
- Fuse keeps blowing...WHAT DO I DO!?
- ecu swap
- under exhaust manifold
- help my cluster doesnt work shorted i think
- Horn wiring diagram with relay location
- strange charging problem
- led light change on 95 honda civic si
- 93 civic check engine light help!!!
- Rear tail lights out
- Here's a new one
- Strange Alternator colors
- Quick Question
- Battery Cable mixup, no electrical power
- Drivers side door actuator disassembly
- please help
- 1985 S1500, flashing battery light
- 87 Civic rear speakers
- Need help quick. CX rear wiper
- Missing stock stereo mounting hardware
- Getting Codes From 95 EX
- 94 seatbelt fuse
- plug location
- 90 Civic DX CEL Code 1 on Decline
- Vtec hook up?
- installing a amp for 6.5'' speakers not subs
- !!! Blinker switch missing?....
- Dash lighting
- fog lights melted, anybody else?
- Lighting issues
- ECU Tune Question !
- Changing cluster
- '88 Civic DX starting problem.
- battery overcharge problem
- 1989 Civic hatch Main relay ?
- Help! Ignition & Starter wire colors?
- Done light problems
- ecu and wiring harness issue
- 92 civic dimmer switch and radio wiring
- Wiring problem- license plate lights won't work
- ECU issues. Again. Still. Whatever.
- P28 Auto into Dx Manual (1995)
- SI Gauge face into DX
- Full Aftermarket Sound Overhaul
- si cluster
- 97 Cigarette Lighter Socket Help
- Mixed-up jumper cable connection, car runs (with issues) (94 Civic DX)
- 94 civic ex coup problems
- removing remote start.. now windows wont work.
- Help! Rear Window Stuck Down!!!
- dashlights, heater lights,tail lights,parking lights dont work but headlights do??
- Electrical system shuts down - why?
- 94 honda civic 4 door power window problem
- Need help bad Code 20 on 89 EF
- Help needed!!
- 92 lx 4-dr Driver Side Door Issue
- 1994 tail lights stuck on
- OBD1-USB or OBD1-OBD2-USB
- '88 CRX, fuse 12 blows & radio not working
- need full wiring diagram plz help
- Simple job, not so simple?
- no instrumentation light
- I'm such a noob! Can't get the rear speaker covers off
- I really need some help -No power-
- Alternator up grade
- ek stereo in ef
- 94 civic ex cruise and horn not working
- 94 civic lx turn signals
- 1998 Civic DX stops when running, then will start but won't stay running
- buying new speakers & installing on 95 civic? help.
- Where do the Hot wires and groud wire from the radio come from?
- Radio hot wire quit being hot?
- 94 Civic Tail Light Problem
- Head start
- installation of bezel in 95 civic dx ?
- New Deck wont get power
- 80W 9006 HID Low Beam Light Bulbs.
- dash lights, speedomitor, gas and temp gauge, and turn signals do not work
- Brake lights stay on, Head lights don't work.
- serious taillight problem, i'm out of ideas
- fog light problems on my 92 civic!
- Maybe buying a Civic Inspire S 1.4 on Monday
- Best spark plugs
- What size? whats good for my budjet???
- Poor radio reception in 6th gen Civic
- HELP!!!! please
- 1986 Honda Civic headlight bucket question?
- Wipers won't stop. WTF.
- Question about 1986 Honda Civic Si headlight buckets
- 95 CX Higher speed wiper motors?
- 94 Civic ex - wiring trouble
- Help please Deck problem
- need help with 95 civic headlights...
- does anyone know how to install fog lights
- 1993 Master Power window control switch
- car wont start (battery/electrical problems)
- radio tuner reception bad 1993 civic
- Civic speakers
- Alternator Problems?
- Car Wont Start :(
- 94 Civic Hatchback SI
- NEED Help 94 Civic hatch radio wiring
- headlight switch
- 95 Civic coupe ex with b18 swap - harness problems
- Check engine light, indicator light
- installing tach on 91 civic need help!
- best place to run the hot wire for a subwoofer
- High beams burned out
- electrical problem on 91 si
- Audio swap 1990 & 1995 ???
- 94 DX Hatchback Rear Speakers
- Horn wiring and what are these?
- Need some help
- 95 civic ex, passenger side power window problems
- Indiglos Install 95 Civic Ex
- 94 hatch door speaker install
- No radio harness plug, just loose wires coming from the dash...pls help
- Tail light craziness
- Batter wire giving low voltage :(
- wiring harness adapters
- Radio and Clock Settings Won't Save
- 95 Civic Back-up Lights
- My First Post Dash lighting help, bad ground?
- 1993 No Sound From Speakers
- Questions Wiring 1st amplifier
- Corner Lights - 1995 Civic EX Question
- replaced speed cluster and now no head/tail light on left side
- speedometer, hand brake light/oil light problem
- 94 civic. overheats, idle revs and cuts
- sub "pops" when changing tracks, inputs, etc
- Trying to wire a system
- Tail Lights Turn off when i turn on High Beams.
- Headlights dimming?
- Dimmer switch?
- 95 civic o2 sensor problem HELP
- Headlight harness help
- Horn Help????
- Water dropllets in the corners
- 95 Civic LX not charging??HELP!!
- 94 DX No dash lights w/lights on.
- Constant 12V not work, clock keep reseting
- Hid
- Shift lock solenoid
- gas gauge does not work, I need the mechanical and electrical diagram for civic 95
- 94 Si 3dr hatch Compact sub solution?
- Honda Civic 95 speedo problem
- 94 civic hatchback no blinkers?
