- 99 Ex Engine swap questions
- Civic '97 hatchback, D16b6 with turbo.
- Engine swap
- 99 civic hatch with a d16y7
- Upcoming B16a2 rebuild and upgrade plans
- mini me swap
- 98 AWD civic coupe (automatic)
- Jdm B18c Builders
- Brian crower vs skunk2
- Cold Air intake
- PG6B pistons in the d16y8?
- D17 cam in a D16Y8
- Tuning 96 lx 5 speed manual
- First Honda, Just bought someone's Project Car | Looking for Insight
- D16 shape
- b20b clutch
- D16Y7 with a different head?
- D16Y7 compression problem?
- Stage 2 sixth gen civic
- Realistic or not really?
- D16Y8 vs D16Z6
- How can i make more torque?
- 97 civic ex exhaust system
- Circle track stock honda racing
- LSD for a 98 civic
- D16Y8 after market rods hitting block
- 1998 honda civic d16y8 head on d16y7 block
- Can I swap
- Best ECU to tune for a 96 Civic Non-vtec
- Cheapest place to pickup Hondata S300 installed on my P28
- Honda Civic ECU swap
- D16y7 build help
- 99 non vetch to 00 vtec swap
- Power gains with stock engine?
- b16 swap small detail questions
- 98 Civic sedan exhaust troubleshooting
- Brake proportioning valve/Fuel filter clearance
- question about hondata
- Help with starting a civic build
- Performance d16y8 build
- D series exhaust question! need help!
- 1998 Honda Civic with D15B engine help
- Need help on 02 honda civic lx manual
- Need engine swap help!
- Help deciphering BAR'd List California
- Need help finding VIN Number on 99 civic ex motor
- Vtec install questions
- Honda civic 98 dx mini me
- Input on a d16y4 swap. Manual to auto.
- mini me swap help
- Looking for 3 stage vtec schematic
- I have a 2000 honda civic lx auto trans
- Motor swap and parts swap from 96 si to 98 cx
- 1.6 NON-VTEC Head - VTEC head swap?
- Can someone help D16y7 engine swap out
- D16Y8 to B20Z2
- Need help regarding a turbo
- D16y7 to D16y8
- B20 Swap
- Turbocharging Questions
- 96 Lx questions
- How to build for best low-RPM torque?
- Motor swapped and idle issue
- D15B7 Valves on a D16Y7?
- B20B Issues
- 1999 accord engins swap
- GSR transmission
- Engine swap question
- i want boost, do i need a tune on this p28 ecu?
- 97 hx with 00 d16y8 swap
- First project '96 civic
- D16Y8 How do I make it faster?
- Any good Honda tuners near CT?
- 3 wire IACV to 2 wire IACV harness
- D series vtec swap
- B18c1 specs
- Will y7 pistons up compression?
- Reliable Brands?
- 1996 d16y8 swap
- Turbocharging a 1996 1.4l 90bhp Civic Sedan
- last 3 big concerns before start up (mini me)
- 99 B16A2 Swap Issues
- engine advice
- B20 turbo help. New here
- b18c turbo parts list??
- hi im new need your opinion ..ASAP PLEASE!!
- Honda Mini me. d16y7 to d16w5
- More POWA!!!!
- b18b1 swap ecu question
- Help with k swap info
- Engine blew; replacement?
- EJ8 Coupe questions
- H22a swapped Eg civic issues
- Anyone bought an engine from Japan Auto Parts?
- Help with more power
- 350hp Budget Build
- 6th gen cab swap
- Need Help Please
- D15b turbo build
- D17a2 CRX swap, should I do it? Read the entire post
- D16z6 build/swap
- 98 lx f22a1 swap details
- intake question
- Putting Vtec* Motor into a NON Vtec* DX
- Honda Civic Turbo high idle and running rich
- Communication Error
- B18C4 Q: which is better? b18c4 129,000miles owned by an OAP or 98,000miles boyraced?
- Engine swap???
- 96 honda civic trans and motor question
- Help Fuel pressure b20 turbo
- Want to turbo my 2000 Si any suggestions
- 98 Honda Civic DX
- best clucth to run in my b20 turbo?
- Need advice new to hondas
- Just bought a 99 ex want to turbo it...
- 96 CX engine swap for 92-95 VX engine & manual trans?
- Noob engine swap/replacement
- 02 civic lx & 00 civic dx
- 300 whp Civic build- Help
- 98 Civic Ex Engine Swap
- Old D-series turbo?
- B20 swap???
- 97 civic hx what swap
- Engine Swap Help
- Engine Swap???
- Need Help! Obd2b engine/harness/ecu in Obd2a Car
- Valve rocker problem?
- need help with basic d swap
- Buying a new turbo questions help
- K series swap help
- 99 Civic Si Turbo Rev Limiter
- Best swap?
- 1991 b18a1 into 2000 civic seadan
- Low idle and cut off Honda CIVIC B20 turbo with diktator
- 97 DX Non Vtec
- Motor Swap
- d16y7 NA power questions
- turbo b18b1 question
- 4WD civic
- Upgrading my clutch to competition stage 4 what type of flywheel should i get?
- I want to swap...civic eg dx
- Turbo b18b help!
- D16y5 with cvt auto in 98 lx
- Need Info on H2b
- need old b18 connecting rods!!
- Looking for best place to purchase a new engine
- b15d mini me transmission question
- 0bd2a b18c5 swap in 00 si NO SPARK
- engine swap
- how can i convert vtec-e
- What Compression Ratio?
- Help please
- Timing belt position/Timing marks 89 1500
- HELP ME w/ 99 civic dx
- D16y7 to y8
- Help me identify this B transmission!
- d16-b18 swap questions
- To swap or not to swap, that, is the question.
- stock 2000 civic lx can I swap a 96 b18c motor and trans? my first swap ever..
- Engine swap d16y7 to b20b
- Need help with engine sizing.
- clutch fork/ throw out beating troubles
- Help! D16Y7 Engine Swap
- "Type R" worth
- Mini me, Tuning, and Emissions
- LSD vs. open dif. HELP
- i need help asap,97 ek with LS swap
- 2000 ex engine rebuild ?
- future build ideas
- 99 Civic DX auto, ECU mod to increase RPM before shifting in 1st gear
- 1999 civic ex swap?
- Awd
- k-series swap into 00 civic questions
- Automatic to manual conversion
- Swapping heads
- 1.5L swap
- 97 civic build newbie questions
- 94 civic d15b7 swap
- changing my cheapo ebay t3/t4 to a garett t3
- Opinions and Ideas for an Engine Swap
- 3 stage vtec wiring problem
- Looking for some help!
- Used Civic Gold Mine
- d16 vtec swapped with a gsr.
- pulling out my blown d16y5 for prep of intalling b18b1
- Hello
- R18 Turbo Kit 2007 Civic EX
- question
- D16Y8 swap or mini-me?
- Map Sensor
- Where to start?
- d16 Turbo kit, need shop for install/tune
- del sol with a b20b t4 turbo - advice/help?
- d16y8 auto swap d16y8 manual tranny
- B16b build (swap into 98 civic dx)
- 6th gen civic gsr swapped no A/C no P/S
- Where to look?
- need opinions on swapping in a 2.0 i-vtec rsx engine into my 00 civic
- engine swap wireharness question
- Help, I know nothing about civics...
- Auto trans For B16A ?
- B18 swap in my 96 cx
- D16Y8 N/A build.
- EJ8 Project Begins
- Which to pick? for engine
- Building a b16
- Motor replacement question
- Where to Get a Engine for a swap
- d16y7 to d16y8?
- D16y7 build questions.
- Swapping a Civic SI-R B16A 92-95 1.6L into my current 98 civic ex?
- 96 Dx mini me swap questions
- B16A2 Head advice
- 2000 honda civic si
- Wanting to do a swap on my 96 ex coupe
- b18 into my 1997 EX coupe?
- D16y7 '96 hatch .30 over build???? "I know RiGHT"!!
- D16y7 .30 over build???? "I know RiGHT"!!
- b20 Hondata base map
- just a question, what all goes into a b16 swap
- Usual prices for a K20/H22?
- turbo d16y8
- Blew up my d16y8....
- D16y8/y7 build
- D16 Performance help
- D16Y8 Rebuild Cost? DIY
- turbo 99 civic si. what do i need?
- B18C1 Ls Crank question
- !!Just did a swap need help troubleshooting! ASAP!
- what to do what to do?
- 96 engine swap
- 1998 Honda Civic EX Transmission Shift Kit and Valve Body Converter
- td05h Mitsubishi turbo on a d16y8? has any1 done this?
- Bolt name frustration
- New Car (Swapped B16A2) No Power/Spark knock
- (Re)Building my B20vtec..all motor some advice?
- engine swap for 99 civic si vtec
- b18a1 motor build. please help!
- D16y8 vtec problem finding parts
- first attempt at mini me d series
- fuel pressure regulator hits intake manifold
- I Need Help ASAP
- new to hondas
- 93 to 98 exhaust manifold
- Wondering how easy a d15b vtec swap will be on 98 hb
- advice on a mini me swap
- activating the vtech on a mini swap
- mini me swap,questions
- D16Y8 to D15B 3 Stage
- Help! Jerking forward!
