View Full Version : Honda Civic Electrical, Wiring, and In Car Entertainment
Pages : 1 2 3 [4]
  1. power cable through firewall - '05 civic
  2. speedometer DIES OUT..need help.
  3. honda 97 vtec rpm going down
  4. Are Capacitors Outdated?
  5. no headlights/highbeams or dashlight for highbeam
  6. wiring harness adapters
  7. Si Spedo
  8. No power to stereo, please help!
  9. 1999 Civic brake lights not working
  10. Instrument Cluster: PROBLEM!
  11. 2000 honda civic HX, Flasher problem.....
  12. speedometer troubles (07 civic)
  13. No sound from 3 out of 4 speakers on 2005 Civic VP
  14. Batter wire giving low voltage :(
  15. 2004 Cluster not working, what size fuse?
  16. need advice from audio philes
  17. Can I add an AUX in to my Pioneer head unit
  18. 2003 Civic LX Lock Problem
  19. Honda civic 2006 coupe..bypass lighter to stay on
  20. electrical glitches
  21. 1991 Civic replacing stock deck
  22. Headlights
  23. Dash lights orange, want them green!
  24. hookin up a tachometer to my 04 civic si
  25. Subwoofer Installation
  26. 2000 Civic firewall
  27. Amp issue
  28. Sub cut out indefinitely, amp still runs.
  29. interior
  30. Need in-dash wiring harness help...
  31. SUB location
  32. New stereo - where to run yellow wire?
  33. Will it work?
  34. Head unit options for exact lighting match?
  35. Replacing headlights??
  36. Climate Controls
  37. Help. Blinkers on my 91 hatch not working...
  38. HELP!!! So many problems!!
  39. Yellow Airbag/SRS connector/wire under seats - how to disconnect?
  40. Where is your shaved door handle solenoid?
  41. 2000 Civic No power to A/C Compressor and Condenser fan
  42. Blower works but no heat?!? - Civic Sport 05
  43. Door lock does not FUNCTION.
  44. 2002 civic factory tape deck/alarm indicator
  45. Tail light craziness
  46. Factory radio problems
  47. [05 Civic]Dead head unit/back-up fuse.
  48. Parking lights
  49. 8th Gen Cluster Pinout
  50. Aftermarket Radio / Keyless Entry Question
  51. Slow drain on battery
  52. 1992 Civic DX ECM Problems
  53. 98 EX Power wire for amp
  54. Bride seats in new civic?
  55. Shorted out Radio!
  56. Wiring Problems?
  57. Maintenance Required light on dash
  58. light delay?
  59. Project Black Dragon
  60. 125w RMS amp into 100w RMS speakers
  61. 2001 civic ex sub instalation
  62. Angel problem
  63. 2005 civic ex se HELP
  64. 01 civic ex coupe speakers
  65. What to look for in a car deck?
  66. broken speedo?
  67. No radio harness plug, just loose wires coming from the dash...pls help
  68. aftermarket head unit, wire harness question
  69. Radar Detector, Ultimate Hardwire idea...
  70. Problem with driver door harness plug
  71. 94 hatch door speaker install
  72. Trunk Rattle help
  73. Fuel and Temp Gauges Stopped Working!
  74. 97 civic alternator?
  75. Unlucky day, signals and stereo
  76. Help, Gauge cluster pinout for a coupe 2004-2005
  77. Installed Dual Radio & it works but the cruise control does not work now!
  78. 2001 Honda Civic Power Locks not working but get click in dash!
  79. '02 Coupe Alternator whine troubles
  80. RCA cable length for 7th gen civic
  81. EK Civic Keyless entry/dome light
  82. 2000 Civic 4dr rear power window problem
  83. Civic Reverb - Does the factory deck have RCA outputs?
  84. dash help
  85. 99 cx engine wiring
  86. Sub orientation
  87. Sheared wires Alternator harness 97 Civic DX
  88. Indiglos Install 95 Civic Ex
  89. Aftermarket Tachometer
  90. Need help with wire harness for stereo CIVIC
  91. Best solution to keep a thief from taking my car?
  92. driver side window wires
  93. 97 Civic LX Custom Door Speakers
  94. Problem with drivers heated mirror and speaker in the door
  95. rear 6x9's
  96. Data Link Connector
  97. Doors Locking Automatically
  98. Civic DX 2009 ; No AUX-IN ??
  99. Remote alarm key 7th gen
  100. subs in an 09 LX?
  101. front indicator bulb
  102. fog lights in a 1998 civic
  103. Wiring... little help... please
  104. 2009 Civic Si Project Custom ICE
  105. How to remove / access A pillar trim - '96 coupe?
  106. rear 6x9
  107. 95 civic ex, passenger side power window problems
  108. Suggested amp wattage for stock wiring/speakers 09 civic LX
  109. DONE With Pioneer
  110. EM1 Horn Keeps Frying Fuses
  111. First Sound System (Alpine Type R's)
  112. Connecting iPod/iPhone to Radio Power Cord
  113. civic 2009, day/night running light
  114. 1997 Civic LX Sedan Speakers replacement
  115. Speaker Sizes in 09 Civic LX
  116. How do I hook up 6x9 in my car?
  117. car audio wiring problems
  118. 90 sedan auto mounted brake light
  119. Power Mirrors
  120. 2 Issues
  121. 2000 civic car audio
  122. CD player trouble (BAD DISK)
  123. Reset meter won't reset
  124. 92 civic ex key & shift solenoids
  125. Power Door and Head Light Warning Does not work
  126. A few pics of my i.c.e.
  127. My 96 honda civic won't start...
  128. lock actuator
  129. hard wire a radar detector
  130. Trouble pairing bluetooth to 2009
  131. How to Install new 6x9's in 2000 civic coupe
  132. Car stereo
  133. Ancient... No Power anything!!
  134. Need some help
  135. 04civicLX sedan. DIY aftermarket speakers.
  136. Door locks not unlocking with aftermarket alarm
  137. Kicker L5 or L7
  138. car audio and video
  139. Wiring for o2 sensor on cat - help needed!
  140. few things
  141. Trunk-mounted MP3 CarPuter in 2004 Civic SE
  142. Horn wiring and what are these?
  143. still having problems
  144. 2001 LX to EX, Vtec wiring?
  145. 06- 09 coupe 6 1/2 that will fit in back deck
  146. 94 DX Hatchback Rear Speakers
  147. Audio swap 1990 & 1995 ???
  148. Honda civic DX-VP 2009 standard questions
  149. Anyone know the supported PIDs for a 7th gen civic?
  150. Help: 54 plate Civic Sport - want to make compatible with iPod
  151. 02 civic a/c comp,door locks,dome light,hdlt warning stopped working
  152. speaker set up
  153. ignition switch change causes alarm issues..
  154. ek9 civic cx oem speaker size??
  155. What are speakers specs for 2001 Civic LX Coupe?
  156. How Many Batteries do I need ?
  157. How to fuse your car audio system
  158. Alternator vs Battery vs Capacitor
  159. Maximum power from car amp?
  160. Deep Cycle vs Starter Batterie in Car Audio
  161. 2005 air conditioning and blower motor
  162. 88 Civic no taillights
  163. Need Help installing rear 6x9's (wiring)
  164. 96 Civic HX clutch switch wiring
  165. 12 Volts but bulb doesnt light
  166. turbo map sensor help
  167. Need Help
  168. Headlight Upgrade
  169. new to the forum got up some pics
  170. Subwoofer power question
  171. change out battery in 2005 EX
  172. Headlight projector problem need help!
  173. new battery but voltage unstable. (amp cycles)
  174. Car Audio for moi...
  175. How much voltage@idle loaded?
  176. Never seen this before...
  177. fog lights
  178. 97 Clifford alarm shock sensor wiring
  179. Help needed !!
  180. 21 Pictures Tell You How to Install a Car GPS Device
  181. New Civic, Need Quick Help! (Cigarette Plug)
  182. cluster ideas
  183. Headlight Issue, not sure what to check next
  184. 2004 Honda Civic EX, Need electrical help
  185. I'm a believer in suppression diodes now.....
  186. Sub Connection Help
  187. Gauge Cluster Bulbs
  188. subwoofer blown? or just a piece?
  189. Fan System Not Working
  190. Premium Speaker Replacements...
  191. Diodes and Relays on a Viper 5002???
  192. Turn Signal Ripped Out
  193. Noob question regarding 99 Civic Factory Radio & Keyless Entry
  194. AC Power to device in trunk
  195. 06 Civic Fog Light Issue
  196. Poor idle and engine light coming on
  197. Double Din, Touch Screen DVD player - CHECK IT OUT
  198. Headlight Blow - 2007 Civic Passenger Side
  199. Aftermarket stereo & Keyless entry fiasco - help needed!
  200. speaker help
  201. Poor Idle and Acceleration with CEL
  202. New Car deck?
  203. Viper 5002 … H1 Primary Harness help?
  204. Removing 86 radio, help please
  205. Amp/speaker questions.
  206. electrical problem on 91 si
  207. 12 Volt signal wire
  208. 1998 honda civic ferio 37820-p2c ecm pinouts
  209. Lites on radio controls and a/c not working
  210. Wiring check | Viper 5002
  211. blinking odometer, key light and low fuel indication
  212. 12v power supply in console always on
  213. 6x9 deck help
  214. Electrical problem, HELP!!
  215. disconnecting battery - special procedure?
  216. subwoofer system installing
  217. need help with woofer choice and installment
  218. Green & Blue Gauge lights not working
  219. Radio code end all post
  220. brakes and blinker lights
  221. Bass knob in 7th gen
  222. HU Replacement location
  223. Weird auto lock issue
  224. suggestions plz
  225. Stock Radio Replacement Suggests
  226. replace my stock cd player with JVC KD-R800, and got stucked
  227. My cigarette lighter is stuck
  228. 520T Battery Backup Module HELP?
  229. 998T Bitwriter ERROR help please?
  230. Post-Installation ... Missing Clips
