View Full Version : Honda Civic Electrical, Wiring, and In Car Entertainment
Pages : 1 2 [3] 4
  1. Help its too loud!
  2. HID's problem
  3. Help
  4. new battery poppin fuses?
  5. Adding Subs to 07 Civic, oppinions would help
  6. Ok WTF is this.....
  7. l.e.d. under dash help
  8. Anyone 8th speaker swap how-to??
  9. DIY 8th Gen speaker swap
  10. Somethings Messed HELP!!
  11. oil pressure guage
  12. LED's for brake and rear signal lights *OEM lamps*
  13. Trunk Wiring Diagram Help
  14. Ignited Bi-Xeon HID kit obtained (Help)
  15. Front door panel.
  16. Static noise in rear speakers.
  17. Keyless remove entry messed up
  18. this is a little wierd
  19. Is there a sensor for the reverse lights?
  20. Spark Plug Tick
  21. LCD Flip Down Monitor ? Where to install
  22. EX Sound System
  23. New Head Unit...Opinions...
  24. Upgrading CD Deck
  25. 2003 civi aftermarket keyless install question
  26. drl
  27. Ecu
  28. oxygen sensor issue
  29. Relay ticking on fog lights
  30. 98 civic VTI-s Headunit
  31. need code for radio 04 civic
  32. srs light on........
  33. (!)(p)
  34. Sirius Connect HON-SC1 questions
  35. wiring diagram for honda civic 2003 si
  36. installation guide for stereo unit civic se 2005
  37. Rev Lite for ipod touch/iphone
  38. rsx seat heaters
  39. 06 stock stereo won't eject CD
  40. lights pulsing
  41. Replace stock speaker on a 96 civic
  42. Interior courtesy lights fuse
  43. Battery charger: reverse polarity damage?
  44. HELP: Cealing/Dome light
  45. amp
  46. ac/heater
  47. Frustrating Problem With Front Driver Marker/Turn Signal Light
  48. Electrical Problem, 92 Civic
  49. will HID's be that much better??
  50. Rear running lights want come on???
  51. Radio Goes Off After CAR Is Not On Parked
  52. 2003 instrument panel reseting when car turned off: [SOLVED]
  53. Dome Light Hook Up
  54. KK's audio system project, pictures.
  55. Power source???
  56. Cloning car alarm remote
  57. cd player problem
  58. 95 civic o2 sensor problem HELP
  59. headlight/radio problem
  60. Dimmer switch?
  61. radio problem
  62. Headlights dimming?
  63. Drl Amber Warning On Honda Civic 2002 LX 1.7l
  64. Stereo/Radio system problem..
  65. Power Locks
  66. How To Pop-Out Bezel Trim on 05 Civic?
  67. hybrid climate control fit?
  68. 2003 instrument panel on&off problem
  69. Buzzing sound when I dim the dash illumination...
  70. How do I replace this fuse?
  71. This buds for you Mr.Ricer
  72. Battery
  73. The Lights Not Working With Alarm
  74. Anyone successfully fitted an 8" woofer in the doors?
  75. Tail Lights Turn off when i turn on High Beams.
  76. Future Alpine set-up
  77. # it all started with a radio code1 or the nti-theft system cut off all the power
  78. Want to Install a New System... New to Hondas
  79. 2009 Civic Door Depth?
  80. *High Output Alternator Wiring*
  81. Help with door harness connector
  82. 2004 Civic Cigarette ligher fuse?
  83. HELP! I need to replace the tail light assembly on my 2006 civic...
  84. Wireing help! i F*cked up.
  85. help with code?
  86. Personal Message in Stero Display.
  87. changing 97/98 radio bezel to 99/2000??
  88. Electric Problem, Please Help
  89. need help installing anzo projector lights
  90. Ebay fog question
  91. horn location
  92. O2 Sensor Wiring
  93. Double din reccomendations
  94. Keyless Entry
  95. Odd speaker issue
  96. H3 HID conversion
  97. 09 sound system ?
  98. Need help Identifying this electronic component
  99. Homelink mirror install....
  100. Garmin StreetPilot question
  101. Rear Speaker Install for civic 2001-2006
  102. E-Bay Projector light Question???
  103. Adding subwofer (2008 civic lx)
  104. NO HEAT!!! Please Help
  105. Trying to wire a system
  106. 2002 Civic EX power window problem
  107. My tach has a mind of its own.....
  108. Door Water Leak...
  109. How can I program a stock honda keyless entry to a 99 civic ex?
  110. CD player drops?
  111. (HELP)no tail lights or dash light
  112. dome/ceiling light failed on 2005 civic
  113. 2003 civic remote trouble
  114. Possibility...
  115. Head Lights
  116. 2 Way Alarm Installation
  117. speedometer don't work
  118. new to civics please help! Installed pioner cd player now no interior courtesy lights
  119. Installing new Sony Xplod Head Unit/Receiver in Civic Si '02
  120. 2003 Civic DX instrument cluster questions
  121. help with a doubledin
  122. sub "pops" when changing tracks, inputs, etc
  123. 94 civic. overheats, idle revs and cuts
  124. I just finished my Retrofitting Headlights!!!!
  125. Civic 2002
  126. 96 honda civic 2dr dx radio problems
  127. need honest opinion
  128. speedometer, hand brake light/oil light problem
  129. Replacing Alternator
  130. 01 Civic Dash Lights Out
  131. ground wire kits
  132. Nav update
  133. Subwoofer Preout NOT WORKING, HELLPPP!!!!
  134. my back speakers dont work
  135. how to install water and oil temp gauge???
  136. how to remove factory head unit from my 2005 civic
  137. metra wiring harness for a Honda Civic Si 2001
  138. 2000 Honda Cvc Hx/flasher Problem
  139. Stereo Wiring Diagram 4 2000 Cvc Hx...
  140. Need A Owner's Manual 4 2000 Honda Cvc Hx
  141. Half of rear defroster not working?
  142. AC problem?
  143. Instrument Lights Issue
  144. Civic 01 Projector Headlight Bulb question.
  145. Facia switch bulbs
  146. 2006 Civic EX CD Player Clicking/AC Fan Squeaking
  147. Check battery, check engine, no speedometer
  148. Dash lights and Audio system
  149. audio intall help
  150. Power lock fuse problem
  151. Dome Light
  152. how to convert dx harness to my b16a
  153. Puddle Light Install
  154. 2003 Civic LX Speakers
  155. Does the Pioneer F90bt double-din fit 03 coupe?
  156. amp to a 2008 civic
  157. speedometer wont work at all
  158. replaced speed cluster and now no head/tail light on left side
  159. Help
  160. subs
  161. Any suggestion on how to access 2003 Civic Computer
  162. Stock Stereo Antenna
  163. bypass help
  164. ep3 a/c problem
  165. 01 cd player install
  166. Switching out 2008 head unit for 2006 XM ready head unit...
  167. Greddy Emanange install??
  168. radio not working
  169. Removing Factory CD Player - 1998 Civic
  170. Right Blinker kills car
  171. electrical issue, car dies overnight
  172. help, cold start, ticking, dimming on off dash, keeps going after shut off!
  173. can i fit a pair of 13w6v2's in the hatch of an 02 civic without modification?
  174. 02 ex cluster to 03-05 cluster question
  175. After market Cd play install
  176. 03 si speaker help
  177. 04 Civic doesn't recognize changer/aux
  178. 1998 Civic EX radio not working! Security alarm/keyless entry related??
  179. Corner Lights - 1995 Civic EX Question
  180. Questions Wiring 1st amplifier
  181. 2001 LX Problems with radio, locks, and lights
  182. 2001 Honda Civic EX electrical issues
  183. 97 civic dx headlight wiring problems
  184. 1993 No Sound From Speakers
  185. amp fuse keeps blowing out
  186. Need more power?
  187. All lights dead..
  188. Civic DX 97 PCM problens
  189. When wiring a shaved door kit solenoid...
  190. button inside the foot rest
  191. Need help,car wont start!
  192. Audio Control Problem
  193. Need help accessing cigarette lighter socket
  194. what amp for foglight
  195. speakers and amp
  196. What kind of In-deck Cd Player is good for a 02 Honda Civic Coupe
  197. My First Post Dash lighting help, bad ground?
  198. Attempt on removing the cluster circuit board on Civic 2003
  199. 2005 Honda Gauge Cluster w/MT
  200. Immobiliser question
  201. Car Stereo Diagrahm
  202. Electrical overhaul needed??.. im F****d
  203. Cassette Player Deck Problem
  204. Horn / Stop Fuse...
  205. Review my new system
  206. 95 Civic Back-up Lights
  207. PLEASE HELP!!! 05 Honda Civic EX Sedan Head Unit Removal
  208. 1999 Honda Civic SI deck wiring.
  209. 2004 Keyless Entry
  210. civic tweets
  211. after market radio wiring help
  212. In Car Entertainment Help!
  213. si 99 need to find where this goes!!!!
  214. What did i do?
  215. Hooking up screen..need wire help
  216. What bulbs do I need?
  217. 99-00 Depo Fog light help! Blowing Fuses!!!!
  218. What are these wires??
  219. 96 EX Keyless Entry Issues
  220. 01 Civic EX electrical problem please help
  221. Need help with gas light
  222. 2006 civic radio code
  223. help! wiring halo angel eyes!!
  224. Gauge cluster not working after swap.
  225. splitting the power of an AMP to two speakers
  226. Weird Static Problem
  227. '90 civic RUNNING LIGHT gremlins
  228. 99 civic sir wont start cause of immobilizer
  229. I want subs...need help!
  230. Installing Navigation System:Looking for Reverse and Speed Pulse Wire
  231. Power Passenger Lock not working
  232. Radio and Clock Settings Won't Save
  233. 2000 honda civic ex power door locks not working
  234. Muffled sound from one speaker
  235. '92 Civic to Push Start
  236. Wiring Aftermarket radio Dual XDM6400BT for Honda civic 04 lx
  237. Power Window Connection in Door
  238. Time of Two Din Car DVD Player
  239. Double Din Fascia for 01 civic
  240. Cable through the firewall 2009 Civic coupe
  241. gen2 m3 mirror wiring
  242. COOL idea: auto shift lites for stick position!
  243. instrument cluster
  244. Need Help? Let Me Know
  245. Could it be my spark plugs?
  246. 02 Civic Si : Alpine deck dims when headlights on.
  247. No power to stereo. Please advice!
  248. Dynamat Question for 2000 Si
  249. Power Outlet & Passenger Lights Not Working
  250. Aftermarket seats and no SRS light. How do i do this?
