- GETTING A TURBO!!! Need help
- What do you think about this turbo kit??????????????????
- Comptech SC
- Turbo Wear and Tear
- boosting my auto
- Wet or dry NOS kit?
- slicks??
- low boost bov?
- turbo rebuild question
- t4 to big for four banger?
- imma turbo mah SOHC
- intercooler piping
- crowler stage 2 cam
- Which Turbo??????
- Apple goes into the Forced Induction business!
- d17a1 turbo
- srt-4 motor swap?
- emanage settings/jumper for 04 ex coupe
- need help for my turbo ....
- Honda Superchargers??
- n22?
- Oil Lines
- transmission
- cardboard turbo...
- HELP !!! I need to know what to add for HP!!
- Port-n-polished dezod*updated*
- brake boosting....???
- FPR - Is this how a fuel pressure regulator works?
- Help!! Everything Has Been Double Checked!!! Car Not Going Into Boost!!!
- Pondering a T3/T4? Look here........
- cold air..
- NOS on an 01 civic?
- ems basemap for 04 ex coupe??
- cant believe im asking this.. but i dont know
- some possible experiments!
- turbonetics "deltagate" question. a quicky
- reputable 35mm wg....
- WTS Turbo
- question
- Stock Internal Specs, S/C Q, & Info Needed
- cold air turbo intake?
- turbo reliability
- S/C for 2006/2007
- i need some help wiring a safc
- Problem with injectors Info needed???
- PCS XFC Install
- Need Help!!!
- Does anyone know anything about this company?
- Help with identifying RSX Injectors!!!!
- E-mange Help!!!
- Short Ram & CAI
- 11 sec D-series
- Turbo Question
- What is the truth about tuning?
- overboosted. car lags now. wtf. UPDATE!!!! :D
- Building but not boosting?
- Question on turbo and manifold combo?
- Boosting opinion
- burning oil
- whats up with the kit?
- cat+downpipe=?
- so...it FINALLY begins.
- Oil in coolant overflow
- d17 kpro?????
- 2001 Honda Civic EX, parts?
- HELP!! civic Ex turbo ...Emange question
- Fuel Pressure Regualtor
- Emanage Voltage clamp feature
- emanage code 14 (i already searched)
- My Turbo Build.
- need some input on a product
- If you boost a automatic will the tranny hold?
- spool up
- Any Civics with K20A2 and FR turbo kit?
- Supercharger troubles...
- garret t3 a/r42 ?
- Noob questions.
- missfires like crazy over 4k RPM
- Wrapped! - Dezod turbo mani - to wrap or not to wrap?
- Next question. Turbo water lines...Why not tap the radiator directly?
- Mmmm mmm good! Hot-crossed turbo from the oven!
- Turboing Help Needed.
- Durability Issue with Auto's Plz Answer.
- maxbore throttle body size?
- Emanage Anti-Engine Stall Feature
- emanage ultimate tuning help
- anti engine stall/ idle adjustment setting help. (greddy ultimate)
- Keep my D16 and Turbo, or go B16 and turbo?
- done some research and has brought up more questions
- obx icav problem...help.
- B16 Turbo?
- PCV valve question
- emanage setting???
- More Coolant Issues: Overheating when heat on?
- turbo d17
- need help ASAP
- Too many miles to turbo?
- NitrousOxideSystems jet size
- lookin for 400whp on b16a
- Turbo manifold???
- srt-4 injectors
- what oil since im turbo?????
- Exhaust Temperature
- Synapse BOV adapter flange
- Air fuel ratio
- odd wet nitrous kit
- Need turbo help!
- P1106 and misfires? Crap, not again...
- new to turbo...
- best place to get turbo?
- what caused overheating?
- Is there anyone who can answer this question..Anyone at all
- Help! TSI turbo kit actin up!
- oil in cyniders & intake mani
- 'Boost' coming to a beater near you.
- Life As Boost
- GSR swap, TURBO?
- Turbo on a D17a1
- Clocking hot side of t3
- EXHAUST QUESTION? LX to Ex
- Emissions
- YCP Pistons - Vitara
- Quaife LSD in an automatic?
- Whom here can point me in the right direction?
- what turbo kit for my gsr civic
- MLS thickness for 8.8-9.0:1 CR?
- What managment to run on my turbo si
- vortech high output or JR supercharger
- S/C that may actually work for the D17...
- D17 on boost OVER HEATING AGAIN, PLEASE HELP !!!!!
- Question from a noob to turbo experts
- Whats the best air intake kit to get or are they a much of a muchness?
- Safe amount of boost.
- Edelbrock Turbo Kit for D16Y8?
- Synchronic BOV: Try it before you buy it!
- Who wants a JDMFabtech Intake Mani? Steve and I do! - Serious Interest Only
- RDX injectors installed. mini write up and pics inside.
- B16a2 Boosted
- ITBs with a turbo setup???
- D17 misfiring with AEM FIC
- My Manual Boost Controller Isn't. WTF?!
- dowpipe help
- d16w9 head on a d17?
- 2004 Accord k24 injectors QUESTION?
- Help with this D17 (yes I searched)
- d16/t25 downpipe
- Looking for custom top mount manifold k series and downpipe
- Which is better? 3" or 2.5" exhaust for boost?
- How reliable is this setup?
- Header Wrap
- Methanol Injection
- Replacing internals
- help turbo civic stalls after 20 mins
- Does your transmission affect spool time?
- Turbo ECU Upgrade
- Trying to boost my D17A1 Civic
- exhaust
- Dry to Wet Conversion
- Rotrex Supercharger?
- dezod intercooler piping help
- valve size???
- age old question: what turbo kit?
- clocking a t25?
- need help!!!
- anyone have experience with JE srp pistons in a 91 civic EF?
- Prepping the block
- walbro fuel pump alternative?
- daily driver, turbo or no?
- What turbo
- What kind of exhaust?
- Oily Turbo
- Oil Weight
- 4spd. Transmission
- Fuel Management problems
- Need help!
- K20A2 + Full Race turbo kit??
- greddy g18 turbo sucking oil in through intake
- turbo oil inlet and drain help
- Injectors wont fit
- Ebay turbo's, yes or no?
- Turbo questions need answers asap
- aem fic
- Turbo Kit
- 2000 Sir Turbo Daily Driver ?
- which turbo?
- tial 38mm wg
- Overheating/Turbo/Slim Fans
- going for big power - can't do it without u guys
- Need Turbo Help!!!!!!
- oil pan weld atitch too far left
- t25 housing options
- oil cooler?
- Help- Built engine makes less power than before (dyno graph)
- Andy was right! It was my headgasket!
- What's the deal with blow off valves?
- Question about removing turbo pipes from turbo...
- Has anyone here built a turbo kit from scratch?
- ~ Boost Terms ~
- Highest PSI for internals?
- Oil feed line where to tap into!? NEED HELP NOW
- Turbo gurus's I got a few questions
- internal list (updated)
- Emanage maps I have?
- OIL Sandwich oil lines wtf helppppp
- 450+ Hp Goal
- Turbo vs. Super
- Radiator fan not kicking on? coolant leaking?
- Help me with turbo!
- Emanage Injector Wiring *asap help*
- What are the first mods you did or will do?
- 06 civic si 300hp goal
- emanage not working with new laptop. greddy says it wont work with vista but...
- Fujita F5 SRI
- hp
- hp and torque question
- Want to be an E-celeb? (look inside)
- best Turbo for 03 EX
- 1999 Civic SI Clutch Noise
- bigger exhaust housing
- Loping hardcore
- Garrett K26 turbo for D-series?
- Aem Fic Needed
- Car runs lean now after being boosted w/ emanage
- So Im thinking about doing a turbo honda..
- Best head gasket? Please answer ASAP. Thanks!
- need some ideas
- New in the imports need help:help:!!!!!!
- Anyone seen this turbo black box before?
- My 9.992 run at California
- SF kit worth it? (since the went under..)
- Am I the smartest guy in the world?
- Turbo help
- Supercharging a B-18c
- trying to sell my turbo
- d16z6 swap or no swap
- my boosted 00 civic SiR
- Turboing d17a1
- I need an affordable quailty turbo kit
- BlackBerry 8830 World Edition$200
- Civic Si Turbo Info
- Direct bolt-on upgrade for a T25 turbo?
- Greddy Emanage Cd*needed
- edelbrock turbo kit d16y8
- just got a 97 ex need help on getting started
- someone with emanage PLEASE HELP ME
- What are my pluggs telling me?
- Turbos for my D16 Civic DX stock. 1-2-3abc
- 1.4 turbo?
- help with Jackson Racing
- Need Some Opinions
