- megan racing coilover problem
- luxury ride
- dropzone springs for 02. too long???
- how long do coilovers last
- *updated* Springs Ordered: Which Shocks/Struts *poll up*.
- Getton coilovers, but not sure what to get
- New Shocks And Springs Rubbing And Noise?
- Aftermarket RSX sway/strut bars - Which fit?
- my new suspention for rear!!!
- Looking for Tokico Blues
- Bottoming Out?
- CV Joint, constant vibrations when driving!
- Tokico DSPEC and Tokico High Performance Lowering Springs
- 99 Factory Setup or Possible Lift
- LCA Help! Quick!
- Help with Tein Flex?!?!
- 02-03 rsx skunk2 springs fit 05 civic?
- unknown noise
- Front end squeaking
- Purchasing GC Coilovers
- 2001 and 2002 springs the same?
- Shock/Strut Lifetime Warranties. .
- 02 civic sedan lifting
- Which Springs? Cant search!
- Shock/Strut Diameters
- 2000 Honda Civic
- Want to lower 2000 ex..
- full coilovers with most lift...
- bolt size
- strut bar
- suspension update query
- stock suspension seems a bit too stiff
- coil over question....
- Suspension Problem
- 01-03 tie rods different than 04-05???plz help
- question for new suspension
- Opinions
- Strut bearing?
- HELP skunk2 coilover / tokico d spec shock
- removing front sway bar? pros/cons
- Tokico D-Spec Serial Number
- Correlation Between Coil Tightness and Sag?
- alternate route to inversed tie rods on extreme drop to fix steering rack angle??
- Help
- Kontrol pro and Camber kit?
- Where to find Polyurathane sway bar bushings
- Air Ride Suspension for sale
- release bearing
- D2 coilover help!!!!!!
- 01 Civic suspension help.
- 91 Si trailing arm issue...
- sway bar advice
- Lowering on a bent LCA?
- 99 civic lowering help!
- Suspension Q on my 04
- Lca Bushing - Replaceable?
- Help put in new struts now a big problem
- Rear x-bar 92 civic
- Tein SS Damper settings
- strange sound >> ground control sleeves
- not so exciting morning at tires plus
- lowering the front more?
- representative from goldline?
- looking into lowering 02 coupe...
- Why are the OEM susupension parts all different costs per trim?
- I need some spring suggestions
- Blown struts on 1993 Civic Del Sol?
- car undrivable....
- eibach pro kit or sportline?
- To Everyone W/Full Coilovers READ PLEASE HELP
- Squeeking noise in rear strut
- Tokico installation
- For Sale!! Skunk2 Coilovers
- need HELP with SUPENSION/shocks
- Sway Bar Specs are updated for 2009 Models!
- 2.5" drop? pics pleasee
- Lifetime alignment- I need help
- 4 struts are leaking!? Help...
- New help with droping...
- 97LX Rear Stock Shock/Strut Replacement Help Needed!
- Delete Please:)
- will the 02-04 rsx typs springs fit our civics?
- bouncing down the road
- need lowering info.
- 01 Civic Knock Passenger Front
- Front passenger stabilizer install hard?
- new springs
- bad handling big rims
- 2 door Shocks/Struts and springs on a 4 door civic?
- will this work
- crx steering rack
- Need help choosing sway bars
- Shocks/Struts.. Dampers.. Springs.. wth?
- Koni/GC Banging
- struts for 02 civic lx sedan??
- need help with spring choices
- Tein S-tech
- TEIN s-tech rear springs in front?
- Fixing someone's hack job with new suspension
- queston about LCA's mounts/bushings.
- Strut Perches?
- Alignment ?
- suspension parts
- something loose??
- tearing off old suspension
- lowering springs or coilovers?
- Oversteer/understeer causes
- best ride for 98 civic
- Soft Suspension + Knocking On Driver Side
- Need info on strut bars, frame brace etc.
- Unknown Drop Kit
- Using '03 Civic struts for '02 Civic
- Need help with what drop kit to get. 2009 LX coupe
- Can suspension problems cause this?
- 03 Civic si hatchback + skunk2 pro s full c/o
- getting new springs
- Which coilover sleeves and is there a difference?
- Popping noise from struts when wheels turn
- DC Sports CS-2 Strut Bar (Front) **PROBLEM**
- Rear disc converstion PPV
- What is the camber kit to civic 2000 lx?
- Front ball joints
- D2 front coilover damanged?
- suspension help request
- Monroe Struts Good or Bad ?
- what kinda suspension
- ES Bushing part number variation
- Neuspeed springs wear on my tires
- what shocks work best with skunk2 lowering springs
- 02 civic drop springs
- Did an accident throw my alignment?
- 01 civic ex coupe struts
- ksport full coilovers any good... read this
- After lowering are the stock shocks...
- Different Struts/Springs on the civic
- weird noises on turns
- Suspension drop pics suggestion
- Do All springs settle?
- Opinions need on suspension/ rims please!!
- 2008 Honda Accord Suspension on EM2
- wich supension i should put?
- Need Help Diagnosing Problem
- Civic 00 Stock to Mod suspension ?
- Need new shocks. Want some suggestions
- can over tightening upper shock bolt give issues?
- 14MM or 16MM? How to know?
- Lowering Question..
- Different struts on front..
- Want to drop my 01' civic sedan. Need help
- Raising Lowered Suspension
- New springs knicked(unistalled)...is this bad?
- Civic in the mountains. Drop height?
- Tein s-tech springs on OEM shocks
- ES bushings worth it?
- 2003 civic with Eibach sportline springs question
- What's consider a "very low drop"
- Most Basic Parts Required for a Lowering?
- new to hondas
- 17 on Tein SS coilovers
- GSR Strut Bar on Civic
- Are used camber kits okay to buy?
- suspension help
- Energy Suspension (or equiv) bushings for 7th Gen Civic
- Rear Suspension
- 80% street, 20% autoX and eventual tracks - what alignment?
- 03 civic drop
- Help please Help....... please help this noobs
- Advice please
- Help Help Help...
- 97 coupe need lowering advice
- cheap lowering
- Need info on Progress Springs for '00 Si
- Bushing problem or something more serious??
- clanking sound
- "Vibrant Strut Bar"?
- Towing with a Civic.....what suspension?
- 97 Civic Suspension any suggestions?
- what is a good lowering spring?
- Did I get ripped off?
- 2003 lowering problems, bad noises
- buying new rims what do i need
- Any1 Canned a 2006-2009 civic?
- Coilover Rebuild Cycle
- Rear arm pivot nut came loose - suggestions to take it out
- Good Deal? (Tein Strut Bar Front)
- 2000 Civic Front Ball Joint Replacement!
- 2004 Civic SiR lowering question
- 2001 Honda Civic Ex: Camber Kit, Struts, & Springs Suggestions? Help Appreciated
- Buying Camber Kit, Springs, and Struts for a 2001 Honda Civic. Do I Have A Good Deal?
- 06 si tracking
- Rear discs
- Looking for stock springs for 2002 EX
- Suspension package advice
- New Springs/Shocks. Loud Thumping. HELP
- 95 lx shocks Q?
- Wheel Spacers??
- Replacing Rack & pinion in 95 civic ?
- KSport Pillowball mounts..
- major problem please help me
- Axel for 97 civic with swapped engine
- RSX TEIN basics EM2 ??
- Suspension options for 02 civic ex
- drop on 02 civic?
- Civic Sport 54 Plate
- 2002 Honda Civic LX
- 94 civic Tein Coil-over on a 96?
- Whats the difference between Tanabe Pro SS and S-0C
- 05 civic lowering
- Tokico +progress
- 96 civic suspension
- 2001 civic ex clunking upfront
- '93 Civic abnormal tire wear
- em2 drop, springs
- 01 civic lx squeaking
- 98 civic lowering
- 01 EX front suspension overhaul
- 2001 Lx coupe lowering
- coilover installation?
- Question:honda civic pro kit suspencion
- 2001 front tie rod end replacement?
- Shocks Bottoming Out w/Coil Spring Spacer
- Need help cant compress old springs
- Civic SI springs for Civic EX ?
- 06+ Lowered Civic?
- NEED help! lower ball joint removal
- Neuspeed spring issue - rear suspension differences USDM to JDM?
- 93 civic rear suspension squeak
- 03 civic si hatch
- EP3 suspension upgrade opinions
- Honda Civic Lx 03 suspension and all around issues
- Noob question about lowering
- Soon to lower the SI
- Chassis Compatibility Question
- 99 hatch suspension questions
- rubber strut "rings" are torn
- 95 Civic DX Coupe Suspension Help!!
- What are the cheapest dependale struts?
