View Full Version : 1st - 5th Gen Honda Civic
Pages : [1] 2 3
  1. 1st thread
  2. 2nd thread
  3. spedometer not working 93 DX
  4. VIN Numbers: You should know where your civic was quality built!
  5. Help, 89 civic not starting
  6. Passenger side lateral mirror wanted for 93 LX
  7. 91 Civic, Ignition and Auto shift lock problem.
  8. vtec
  9. 86 w/ a B16?
  10. HELP HELP PLEASE 83' Civic Carb...
  11. need some stock parts
  12. 1995 Civic DX rough idle what causes it and how to fix
  13. F22
  14. motorswap
  15. starter problems 1994 dx
  16. 92 Civic Shaky Steering
  17. 11:5 LS/VTEC issues
  18. engine swap for a 94 civic dx
  19. My Honda Civic 1,6 VTEC 16V Tuning '93
  20. 87 engine swap. help please!
  21. 95 Ex Coupe
  22. Bit more poop
  23. Clock remains dim and resets to 1:00 every time the car is off...
  24. exhaust help needed
  25. Parts
  26. B18c with B18c1 internals will it work?
  27. 1995 dx coupe..WINDOW Replacement!!
  28. Need Help
  29. Engine smoking like hell?
  30. Engine smoking
  31. 1993 civic open cable reel
  32. Oil Leaking and Idling Problem
  33. A little insight please!
  34. 89 civic jumpstart
  35. Fuse problem!!, lights...Help
  36. doors won't open
  37. Is my alternator bad??
  38. pwr windows roll down, not up
  39. my "new" car
  40. Advice on where to sell a '92 Si?
  41. Upper/inner steering arm/ball joint replacement
  42. 87 Civic Si HELP distributor timing
  43. 1991 civic dx push button start
  44. Question from a Noob
  45. 1991 crx
  46. Wheels
  47. Quick question
  48. sway problems with 1991 honda civi LX
  49. cheap beef up
  50. 1.5 Multiport Swap
  51. newbie needs some help with 92 DX Hatch
  52. What Engine doesn't fit in a Honda?
  53. leather in my 94 coupe
  54. civic 88
  55. 2nd Gen Civic Roll Cage $200, distrib... more
  56. Stock 92 Civic Hatch
  57. 1988 Civic Alternator Removal - Help!
  58. whats the diff in generations?
  59. Problem starting - 1988
  60. Help with 92 Civic
  61. mini-me question
  62. 91 Civic EX -- should I buy it?
  63. My Sushi Roll Help with first mods
  64. My 95 Honda Civic EX Coupe
  65. 89 Civic mirrors
  66. gas tank straps
  67. O...M...G! Help...this is so annoying. (cd unit)
  68. speedo gear change
  69. Busted Engine on 95 Civic LX.... Options?
  70. Parting out
  71. Honda civic 93 Ex sedan Air condition issue?
  72. 93 Honda civic fog lights
  73. Fuel line help
  74. Squeeking noise honda civic 93
  75. 18 inch Motegi rims
  76. 95 Civic Dx center console and door panels
  77. eg parts 4 sale
  78. wts 17"rims
  79. JDM Switches For EG 92-95 Civic
  80. Newbie here with '89 DX Hatch questions
  81. honda civic 1992 - 1.5 si
  82. need badly a multipoint intake manifold for d15, or d16
  83. '91 Civic randomly fails to start - Fuel pump problem?
  84. Crank shaft pulley
  85. Side Mounth Intercooler
  86. 17 inch rims for sale with tires.
  87. what is a good exhaust for an 88 dx 4dr
  88. Engine swap
  89. 1986 Civic Coupe 5 speed - Idle bounces, any ideas?
  90. Convert to Manual or Not to Convert?
  91. 90 civic timing belt failed tonight
  92. 95% done with my swap. VID
  93. 95 civic si coupe gauge problem
  94. Newbie here with a timing or head question
  95. Clutch
  96. 94 LX Sedan Swap Options?
  97. Questions on air/fuel gauge
  98. Smoother suspension
  99. 93 civic swap
  100. 94 lx sedan climate control
  101. 95 Civic having problems PLEASE help
  102. need help: 94 coupe revs up 4 no reason!!
  103. Projectors
  104. 1986 Wagon - Interchangable parts?
  105. choke!
  106. 91 Civic EX need advice HELP
  107. 1985 1.3L overheating Need help!
  108. specs/info for the 1983 Civic 1500 S
  109. cuting coilovers
  110. how to build a motor????
  111. i need a multipoint
  112. old 1980 cvcc b16 swap build-video
  113. turbo and ac
  114. engine light comes on, help
  115. d15 what it worth
  116. intake manifold question
  117. '93 LX soundproofing question
  118. NEED HELP!!!!! rough idle then ok CEL
  119. 81 Honda Civic
  120. civic died and will not start
  121. Ac and Heating issue.
  122. D15B Mini Me Swap Options
  123. 92 4 door Civic no dash lights
  124. Engine Swap for '88 Civic DX 4 Door Sedan
  125. driveability issues
  126. 90 crx/b16
  127. 89 civic SENSOR PROBLEM w/ check engine light. HELP!!!!!!!!!!!!!
  128. new to the forum....well new to the civic as well I suppose
  129. 91 accord with idle problem?
  130. It Wont Start
  131. VX shuts off while driving, lunges horribly on acceleration and tach needle jumps!
  132. Four door front clip??
  133. 2000 Civic Transmission Problems. Help!
  134. Will 13s fit on 1992 Civic SI?
  135. cruise control
  136. Finally!
  137. 1995 Coupe Ex
  138. 1997 civic headers
  139. Tail Light Swap
  140. Harness issue
  141. any clubs in yorkshie
  142. Conversion From automatic to manual??
  143. Interchangeable Parts
  144. oil leak, need help
  145. quetion
  146. Need car advice
  147. Don't turbo unless you know what you're doing..
  148. B18c5 or H22a4???
  149. a good shop in san diego for my CRX???
  150. In Need Of Advice!!!
  151. parts for 89 lx
  152. Engine Swap Questions!!!
  153. 1992 Civic EX-V tuning
  154. 1992 D15Z1 VX engine build - compression ratios??
  155. Replacement heat shield?
  156. stuck between b18c1 and b18c5
  157. can i have some advice??
  158. Clock and Radio not saving.
  159. Clutch Master Cylinder
  160. radio code help
  161. just got a civic,,,got a few questions
  162. please help me (drum to disc conversion)
  163. advice for keyless entry?
  164. Illuminating question ???
  165. adjustable cam gear on a 93ex
  166. Stuck Brake Light Switch
  167. Best Shop Manual?
  168. Engine OIL
  169. Engine OIL
  170. Regular or plus for my '91?
  171. d17a2 d16 transmission
  172. steering wheel install
  173. 81-82 civic ???
  174. Got 91 Civic Need ideas
  175. New, from Indy
  176. Newwwwbie (many pics)
  177. compression test help
  178. Manual Transmission Installtion 93 civic
  179. 93 Civic hatchback spoiler repair
  180. ED6 D15B Engine Questions
  181. Unleaded/Premium gasoline
  182. 92-95 Hatch Skirts
  183. automatic to stick
  184. New here 89 sedan dx
  185. question of compatability
  186. Pacesetter Exhaust?
  187. 94 4 dr bumper swap
  188. ECM (6) code problem
  189. 95 civic ex...question about smoke coming from muffler
  190. 93 EX, Door wont close right :(
  191. 94 LX sedan
  192. '00 SI fog lights
  193. 95 Civic DX
  194. 87 doesnt start
  195. Installing cruise control on '90 CRX auto trans
  196. 90 civic si pics
  197. 90 civic hatch ideas
  198. need some help
  199. Honda Civic 95 fusebox
  200. Engine ground wires
  201. 1982 honda civic swap
  202. 1990 Civic runs only at high rpm???
  203. new to forums. need help with 87 oil use!
  204. Help!!93'dx keeps klunking only when not punching it
  205. Need advice on engine swap??
  206. 94 civic dx auto-feels like it wants to stall --
  207. Spark plug recommendation
  208. my 91 hatch swap/build ( alot of pics)
  209. mpg of 89 lx with d15b2 automatic
  210. 95DX Dash-light replacement
  211. B18C1 with Pm6 zdyne flashed ECU 02 oxygen sensor problems
  212. d15z1 performance help
  213. my 1990 civic sounds like a lawnmower
  214. Post pics of well customized '90 civics!
  215. help please...what would i need besides motor to go from d15b2 to a d16z6
  216. New Here!
  217. Help?!
  218. Engine Swap?
  219. 93 Civic Si Coupe 5 Speed
  220. engine swap
  221. 81-83 ? Civic Wagon / hatchback body Parts 4sale
  222. Will it fit?
  223. `80 1500 keeps running when shut off
  224. 94 civic cold start
  225. Rear Bumper 95 Civic Coupe
  226. 89 budjet hatch back questions
  227. 89 bud-jet hatch back pictures
  228. 81 Hatch Engine Swap??
  229. Stolen 92 Civic Hatch, Long Beach, CA area
  230. CEL light and 4k rev limiter
  231. HELP!! 1990 Civic isn't working right
  232. heater stays on when cars off/keys out
  233. Car Just Died on Me...
  234. i just got a 93 civic
  235. 89 civic sedan brake help.
  236. my first lil car!
  237. best gas milage setup
  238. '92 sedan brake issues
  239. something wrong with suspension
  240. New here
  241. 91 Civic SI hatch- exhaust question
  242. Suspension and Wheels questions from newbie
  243. Prolect 1994 hatchabck
  244. 1995 Civic Glacier
  245. Car Dies After Starting
  246. NEW OLD CAR PROBLEM - long
  247. Engine Swap for a 94 civic ex
  248. 93 civic mess...
  249. Need Underhood Fuse Box Diagram
  250. Faulty Igniter? With Spark?
