View Full Version : 1st - 5th Gen Honda Civic
Pages : 1 2 [3]
  1. Need Help From You
  2. 1991 civic vehicle speed sensor code 17 problem
  3. advice for a good Carb engine
  4. 93 dx shaking while cornering
  5. 89 Taillights
  6. Fuel and Temp Gauges stopped working!
  7. Theres no way a D16z6 should be this slow
  8. gen4 civic si paint codes
  9. Canadian DX engine?
  10. 92 ex 4dr AC issue
  11. Interior swap?
  12. 1991 civic wagon automatic
  13. 91 DX Exhaust
  14. 95 DX modifications
  15. Fuel octane?
  16. 93 civic cx 4cyl manual hatchback....info pls
  17. Coupe to Hatch?
  18. 93 Honda Civic starting issues
  19. Does this look right?
  20. Help
  21. need some help chosing a motor
  22. Transmission change
  23. 95 EX A/C trouble
  24. Hard To Start When Its Hot Out
  25. 93 civic ex knocking sound
  26. Tranny Identification
  27. 1994 EX fixer
  28. D16z6 upgrade?
  29. car turns off in drive or reverse but not in parking or neutral!!
  30. are honda civic eh vti legitimate vtecs?
  31. 90 Civic power cable to amplifier broken
  32. 1994 Civic Wont start and overheats!
  33. b18c1 swap question
  34. Body Kit
  35. Vents and A/C compressors
  36. 92 Civic not starting
  37. 92 civic running rough
  38. d16y8 swap questions
  39. 90 sedan auto mounted brake light
  40. 90 sedan auto door jammed
  41. 90 sedan auto passenger mirror
  42. 94 DX Coupe Instrument Cluster/tach?
  43. need help to programme door unlock remote
  44. Interferance engine or non interferance?
  45. 93 honda civic B16 engine problems
  46. Tranny Swap
  47. 93 civic hatch missing bad past 3000 rpm
  48. 92 civic Lx showing its age due to heat
  49. Gas Mileage Too Good To Be True???
  50. 92 dx mileage
  51. 1995 Civic ex Master Cylinder Replacement
  52. 95 EX Running Rough need help
  53. d16z6 hp ?s
  54. Engine help!
  55. Head Gasket
  56. 89 civic fuel system question
  57. NEED HELP: replaced VSS and cluster, now TRANSMISSION shifting weird. 95 AUTO LX
  58. AC belt removal 91 Civic 4-door DX
  59. 82 Civic Puttering Out Problems
  60. Headlight Question?
  61. 1989 Civic Hatchback Tow Hooks
  62. hey
  63. 93 Del Sol S A/C trouble
  64. 92 Civic 1.5 Timing belt tools and supplies list
  65. Audio swap between 1990 DX and 1995 ???
  66. Low Idle on my 92 civic hatch
  67. 95 ex coupe distrib probz
  68. New To Forum and Hondas - Oil Leak mystery and tune up questions?
  69. 95 civic steering rack
  70. New to the forum
  71. 1993 Honda Civic DX HB - Reap Wiper not working
  72. WTB: 89 Honda Civic Gauge Cluster
  73. Intro
  74. Civic Hatchback 1988 rearview mirror replacement
  75. whats a first gen worth?
  76. Hi everyone
  77. new to the forum and honda's
  78. 94 Civic Engine Swap?
  79. B18C into a 95 coupe! HELP!
  80. car starts without clutch applied
  81. Engines/Transmission..HELP PLEASE!
  82. 90 DX died, won't start. Thanks for advice.
  83. Civic HeadCasket :(
  84. 93 LX - slowly growing problem...
  85. 95 d16a6-96 d16y8 swap ! Help !
  86. '94 Civic DX Takes Oil...HELP!
  87. B18A Or H22A Fit In '94 Civic DX??
  88. What's behind this cover?
  89. Gauges
  90. Engine question
  91. Test pipe vs. high flow cat
  92. Wire Harness question ?
  93. fast idle block off plate
  94. intake manifold
  95. Problem with b18b swap!!!! Need inputb
  96. Hey guys, brake lights out. Bulbs and fuse both good. Switch disengages... And what..
  97. gauge light wont work!
  98. Yet another gutless Civic
  99. 92 eg budget?
  100. '87 Civic 1500 carburetor problems
  101. 94 Civic VX...yes..VX..and i need help
  102. oil on my plugs
  103. Audio: Extreme roof rattling in my 91 wagon/shuttle...
  104. 93 civic with a d16y7
  105. K series into a 95 si coupe ?
  106. '90 EX 1.6L Hard start and crappy idle...help
  107. Car Overheating Need Help Fast!!!!!!!!!!
  108. '90 EX 1.6L strange overheating problem
  109. VECI label needed for timing
  110. check engine light and codes 8 and 16
  111. 95 d16z6 really bad miss
  112. 95 civic exhuast question
  113. 93 Civic Si Shift Boot Issue
  114. Head gasket or stuck/bent valve?
  115. Fuel pump issue
  116. New to Honda, possible owner of '95 EX coupe
  117. 93 Civic Dash Removal
  118. identify wheels?
  119. help with my D13B2 please
  120. Multiple problems
  121. need some help!!
  122. not getting gas...surging
  123. engine overheating? smoke from manifold area
  124. 95 dx idle problem when cold
  125. Steering on honda
  126. 94 Civic Dead after pulling spark plug wire!
  127. '90 civic hatchback coil problem?
  128. 92-95 or 96-00
  129. Fuel Pump Connections on 1980 Civic 1500 GL
  130. 7 symptoms, one problem?
  131. smells like gas inside my car
  132. 91 hatch with issues
  133. What head(s) will fit on a '95 Civic DX (D15B7) ?
  134. Issue with my 93 civic
  135. idle issue????
  136. 92-95 D15b vtec into a 91 civic
  137. d16 exhaust and intake work with a b18
  138. 90 Hatchback Standard
