View Full Version : 6th Gen Honda Civic
Pages : 1 2 3 [4] 5
  1. Temp gauge issue?
  2. WHY won't my wheels come off!?
  3. Integ seats
  4. Engine noise due to timing belt tensioner ?
  5. 98 civic HX
  6. suggestions?
  7. enigine burning oil
  8. 99 civic hx exterior project
  9. 1996 honda civic ex with 5spd swap
  10. 2000 civic si motor?
  11. 1998 LX Exhaust
  12. Engine/Acceleration related noises. Mechanic couldn't duplicate, help!
  13. Harsh Shifts
  14. Clutch Adjustment
  15. Low on power and dead spots????
  16. D16Y8 N/A Build Help
  17. 99 civic grill swap
  18. Urgent. Car not starting! Need Help
  19. would a catalytic converter from a 1998 ex work for a 1997 hx
  20. Installing headers
  21. '99 Civic EX 5spd lacking torque
  22. 1997 Honda Civic Help Needed (Bumper, windows)
  23. D16Y8 engine swap ??
  24. 2000 Civic Sedan OEM Clear fog lights
  25. Honda Civic AT trans shifting problem...holding 2nd gear for no reason
  26. Evap Canister Location?
  27. 97 civic auto tranny problem
  28. 1996 EX Engine Help
  29. e-brake help!
  30. 98 civic won't start after sitting 12hrs or more
  31. remote starter troubleshoot
  32. I need a D16Y8
  33. Debris blowing through air vent.
  34. $1500 to replace brake lines -too high ?
  35. fuel injector? 98 civic ex how to replace?
  36. How do you bleed coolant system on 2000 si?
  37. BBP clutch kit, questions?
  38. tough decision pt 2 lol
  39. 2000 Civic DX rear disc swap help?
  40. VTec Questions
  41. auto or stick?
  42. Cold starting problem
  43. driver's side power window
  44. 98 honda dx tail light lens replacement
  45. P1457 - Manufacturer Control Auxilary Emission Control
  46. Was This a Waste??
  47. 1997 dx d16y7 NOT GETTING SPARK
  48. overheat issue
  49. Most bada$$ engine
  50. 98 ex want to upgrade cam
  51. how do you put the door panel on?????
  52. Clicking/Rattling noise front of car, not speed/rpm dependent
  53. Removing Front bumper
  54. d16y8 build?
  55. Drag Racing
  56. OBX PULLEY 98 civic LX
  57. Need headlight help
  58. 98 civic exhaust choice...
  59. Looking to boost my d15b
  60. decat pipe
  61. bumper replacement
  62. civic 2000 ex noisy using s2000 cluster mod
  63. Speedometer not working post swap
  64. 97 HX with strange electrical gremlin
  65. Is it a wise to add performance mods to automatic HX?
  66. just picked up a 98 coupe
  67. cant get past 4k :/
  68. 99 ex clutch swap problem
  69. Just bought a 1997 civic coupe and got some questions
  70. wut kind of exhaust should i get on my 99 dx
  71. check out my ride and tell me what you think
  72. quick question
  73. 98 Civic Ex Gas Guage Nd Brakes
  74. Springs for '00 Si
  75. 1998 Civic EX 1.6 - I have a number of Codes. Need Help.
  76. Would the K24's weight trough off the handling dynamics
  77. Injen, Skunk, K&N, or AEM Cold Air Intake
  78. 98 civic ex cold air bypass valve
  79. Suspension advice
  80. DTY removal of rear spoiler
  81. help w/ wiring m3 mirrors
  82. 98 ex turbo.. t25? any?
  83. most effective SOHC Vtec bolt ons
  84. How to spot a cracked head...
  85. 97 Civic LX, Need advice on CV Boot repair / replacement
  86. Axis Oldskool Rims
  87. 96 VTI ECU seems has Problem
  88. which ECU?
  89. Where can I find this piece of trim?
  90. Fan problem
  91. Suspension
  92. drivers side seat not reclining
  93. transmission suggestions
  94. New User 2000 Honda Civic Si
  95. Turn on ac at idle speed, engine shuts off
  96. Magnetic drain plugs
  97. I was wondering...
  98. Just got a 2000 Civic Si
  99. suspension help
  100. VTEC Question
  101. help- clunking noise
  102. NooB Question.
  103. climate controls messed up
  104. 95 Civic antenna replacement
  105. Spark Plugs for HX..
  106. As far as headers and exhaust go...
  107. Sticky accelerator
  108. engine swap for beginners
  109. 99-00 Civic Si Rims
  110. Frustating!? Help Me Someone!
  111. front clip swap
  112. Air/Fuel Gauge Install
  113. Resetting Check engine light?
  114. Pegged temperature gauge (2000 DX)
  115. E-brake handle
  116. what year/model to buy (6gen HB)
  117. 97 civic hx tranny shot
  118. 2000 honda civic HX, Flasher problem.....
  119. TSX Retrofit w/ H1 Hi-beams, Wiring help needed
  120. hello
  121. wheel fitment on a 97 civic
  122. p-73 Ecu
  123. '97 EX: AC Problem
  124. need help to identify which transmission I have
  125. good chip
  126. '97 3dr DX Stalling
  127. 17" rims
  128. moisture in headlights
  129. Hi folks! I'm new here
  130. Ek guages need help
  131. Looking to be a little rediculas...
  132. Newbie needs help please, car won't start
  133. Help,help,help!!!!!
  134. Engine Trouble, need intervention
  135. Learn from my mistakes - Civic HX
  136. Looking to get projector headlights?? who has them do ya like them??
  137. 08 Civic Si seats.
  138. Wiring for new speakers
  139. Running a code...
  140. Goin Faster....Tips Plz
  141. My car stops like shit
  142. Steering whel
  143. Changing dash lights
  144. Dim Brake Warning light
  145. Check out my ride! New paint job among other things!
  146. motor problam
  147. 97 Civic ECU code 5 or 41
  148. Need help naming this hose on d16 (pic)
  149. Lacking Low End
  150. Need help with multiple problems
  151. Header buzz/rattle on 97 LX
  152. losing power steering fluid
  153. interior
  154. 18x8 rubbing issues on 99 civic ex
  155. 98 CIVIC hatchback
  156. 96-98 ex auto to manual swap
  157. 98 Civic HX Turn signals quit working
  158. trans question
  159. 96 civic cx performance chip
  160. getting frustrated....
  161. Feedback.
  162. dropping new engine into 97 DX coupe
  163. 2000 lx running hot
  164. advice
  165. crappy 97 civic wont pass inspection
  166. seats
  167. ? before buying
  168. Stock 99 ex Civic Cluth Torque Limit?
  169. Tach?
  170. intake and exhaust...
  171. just bought 2000 civic ex help with mods!
  172. Need Help PLZ!!! FrankenCivic needs a tranny...
  173. VTEC Cuts out for some apparent reason...
  174. a plug is a plug is a....
  175. what is the difference???
  176. Tranmission dilemma
  177. obd 1 engine into obd2 car
  178. h22 swap ?
  179. Taillights
  180. Urgent! Will stock 04 Civic Rims and tires fit a 96 Civic?
  181. 98 Civic with D16y8- response to bolt ons?
  182. Window trim
  183. honda with acura parts
  184. Integra GSR seats --> Civic???
  185. EG8 vs EK3 vs ES
  186. purchasing 1999 civic lx
  187. gauges
  188. starter button
  189. lowering sprins
  190. Wanna do full service
  191. 97 civic idling like crap
  192. Oil light flicker at cold startup etc...
  193. dash lights dont work
  194. Tire Rubbing - 225/45/17 Tires/17" Rims - Please Help...
  195. leaks leaks leaks
  196. I am wondering if anybody else has this?
  197. Flood in Trunk
  198. vtec: noob questions part 1
  199. suspension: noob questions part 2
  200. Sway Bars
  201. Im New here, need opinions
  202. My 2000 Si GSR Swap
  203. 97 Honda Civic CEL blinking
  204. 98 civic barely runs
  205. Swap Question
  206. blacked out
  207. Short throw shifter
  208. Does this fender need to be replaced? (~total 129kb images)
  209. Differenc ek6 ej6
  210. New to the boards .. and civic.
  211. Car doesn't start...
  212. 96 DX no charge-check engine light
  213. Weird electrical 00coupe
  214. Need help on exhaust for 1996, 3dr 1.4i Civic - Urgent please
  215. New 1998 dx coupe 5 spd
  216. 98 Civic 5 door 1.8VTI, abs warning light..
  217. Question about stock intake...
  218. Common engine years?
  219. 98 Civic EX idling difficulty !!Help!!
  220. Replacement/rebuilt Civic Engines?
  221. new to everything
  222. Hissing sound between 3.5-5K RPMs...
  223. New Member-->2000 Civic Question
  224. Leaky valves?
  225. 1st post, cd dash question
  226. 98 civic ex engine questions
  227. Looking to buy some exhaust parts...
  228. check engine light on
  229. 2000 ex swap - Help
  230. 1.6 vtec wiring guide
  231. Cheap Way to go fast ?
  232. honda civic for trade
  233. 96 Civic Electric Problem
  234. 1999 honda civic for sale
  235. Good/Cheap Lowering kit for 98 civic dx ?
  236. Passenger Side Seat adjustment trouble...
  237. Lil help?
  238. new alternator for a 97 civic?
  239. 98 Civic cx idle rpm problem
  240. Valve Cover Gasket
  241. Fastest Engine For 98 Civic Dx
  242. Next Modifcation ?
  243. Introduction
  244. need help upgrading
  245. climate control lights
  246. 98 Civic LX Owner needs some help!
  247. CVT Transmission Fluid?
  248. Taillight Compatibility
  249. Wobbly stick shift
  250. 97 LX fuel relay?
