- When and how to check my liquids?
- 404 Miles on one tank to vegas
- I put in Chevron Techron, what now?
- Greasing Clutch
- OW40 oil at honda ???
- I shouldn't use 5w20 on my MOTOR???
- ATF fluid
- MPG indicator in cars
- Formula H, Middletown NY
- Oil Change and Transmission Drain & Refill
- Fp60
- AMSOIL mtf *review
- 100K Maintenance
- engine oil vis...
- Tranny Fluid...Read before you flame
- 2.94 u can change ur oil with synthetic and a filter.. link..
- Is Honda ATF, synthetic?
- LC20 in auto tranny?
- First oil change.
- A difference with mobil 1?
- Cleaning the Filter of Intake
- Oil gurus! enter!
- Need an ALTERNATIVE to Honda Power Steering Fluid
- when to change tranny fluid
- Is 10w30 ok to use in our motors?
- using an older civic fuel rail?
- fuel injector o-rings...
- Oil & filter change @ the dealer - what to expect?
- How do I quickly prep my car for a long Drive?
- Mobil1 Extended Performance (and its additives) in a Honda MT
- 100K Oil Change
- Does unused coolant go bad
- 89 0ctane vs 87 octane...
- where is the atf drain plug located?
- Honda ATF Sux!
- brake/abs fluid?!??
- Hey do you really need that 30k mile tuneup?
- belts and hoses hopefully I'll save 500 bux
- Spark plug question...
- Fuel Fliter...
- PureOne vs. ToughGuard Fram Oil Filter
- poll: what oil filter do you use?
- Can i only use honda ps fluid
- Auto trans fluid in oil
- question about the fp60
- dry clutch
- K&N air filter
- Royal Purple ATF
- Honda Car Care Days, April 1 - April 30, 2006
- Good way to get an oil filter off w/o the mess?
- Fuel Light
- driving on rain conditions results in fewer mileage?
- AGING CIVIC help
- at what intervals should the engine air filter be changed?
- Maintenance your own civic 30 60 90k service
- I need advise !
- running a test pipe, better mpg?
- Fuel filters, or lack of...
- valvoline max life
- How many quarts?
- Redline Atf, What Kind?
- About to change my ATF and have one question.
- different oil filters
- greddy oil
- Lucas Oil Stabilizer and Transmission Additive
- 30,000 mile service
- question about checking auto tranny fluid lvl
- Lubecontrol initial shock treatment
- Maintaince Required light is flashing but not staying on...
- Gentleman i need your knowledge.
- Short Ram Filter
- oil filter relocation kit
- Pennzoil Full Synthetic oil
- Priming oil filter?
- Does armor all harm your intentior?
- Best price for Honda AT Fluid
- still using lube control
- Alternator lifetime
- Lubecontrol group buy....
- AEM fuel rail, is it worth it?
- cleaning AEM filter......
- wrong oil....
- Mind boggling quotes from two honda dealers for 60k service...
- Re: Honda Plus warranty, synthetic oil and K&N Air Filter
- Not good to top off brake and power steering fluids????
- oil change intervals...
- I think I just got ripped
- will an SAFC help me tune?
- How to change air filter?
- Honda 5w20 oil color?
- fuel cleaners
- Fuel Gauge
- how far
- Bought filter for V2 but doesnt fit.. why
- oil wieght? Regular or Synth?
- German Castrol
- Oil filter relocation kit
- Need some help w/ oil pan.
- Honda MTF or Mobil1 Synthetic
- 5w30+5w40=5w35?
- Blitz Filters?
- Replace Power steering fluid?
- Please provide input and THANKS in advance for looking!!!
- FRAM or Honda oil filter?
- Brake Fluid - How often to Flush Motul RBF 600?
- full synthetic bad?
- Timing Belt
- drain 1st quart = cleaner??
- i think i should have done the 30k service
- when to replace spark plug?
- oil pan drain bolt won't budge!!
- Where is all my gas going!?!?
- quick ?
- Which Redline MTF to order and how many?
- Oil
- GC (aka German Castrol) - Good for Hondas?
- fuel filter
- Free and on sale oil and oil filters!
- Napa Gold filters
- coolant tubes kits
- Any Experience with Super Tech Synthetic
- So i was just messin around the engine...
- Dexron Ii
- Timing Belt Q....
- Dry-Flow Air Filter Maintenance
- Cleaning CAI Filter
- Oil Changing Question
- 60,000 mile service
- need help!!
- where to buy valvoline maxlife 5w20???
- Spark plug gapping
- Accessory belts
- Question regarding Oil/Oil filters
- M1 0w-20
- Fuel Line
- Windshield wipers
- just scheduled 60k checkup
- Red Line Oil Vs the rest.
- M/T Fluid check
- Engine Oil type
- smoother acceleration
- Time To Change My Tranny Fuild And Antifreeze...
- did some maintenance, now to the track
- Cabin Air Filter
- What mods to make fuel efficient????
- air filter replacement (aem sri)
- 3 Quartz Of Trnsmission Oil And What Else?
- where is the oil filter
- what brand should i use...
- Good Spark Plugs
- Regular Maintence
- Injen SRI Filter
- What do I need to do for proper maintenance?
- WTF Fuel
- Can we use s2000 oil filters on 7thgens?
- Service and Maintenance Schedules
- Rust Proofing
- I screwed up
- First Timer
- Fuel injector
- clicking
- Need help PLZZZZZZz
- Which maitenance is worth the effort
- How do I know when my auto tranny is going bad?
- new starter installed
- 30,000 maintenace list ok?
- BG 44K fuel additive
- Cleaning Speaker covers in door.
- 80,000 miles
- when i start my car it idols or accelerates up to 4000 rpm need help asap! thanks
- engine coolant problems/little or no heat at times
- synthetic or regular motor oil ????
- Gas Tank Door Doesn't Open
- Burnt Oil + Power Steering Fluid. Need Help!
- atf change and other tips
- Sea foam
- bazaar overheating issues, HELP!!!!!
- car won't start!
- weapon R oiling
- Lube Control FP60
- Best Gas Mileage on ur civic ?
- Annoying & Unique gas tank issue
- 11:5 LS/VTEC issues
- LC20 with automatic transmission fluid?
- sounds on 2000rpm/2500rpm
- Best oil for B16A2
- Maintaining an Auto Transmission
- help asap overheating/no heat in heater???
- Civic SI 2007 and Civic EX 2001
- Type of grease for door hinges?
- Valvoline MaxLife Question For Civic SI 2007
- Honda Brand oil question
- CAn anyone say they have gotten over 200K on dino oil?
- Uh-oh......airbag light is on.
- compression bushing?
- Need help with all types of maintenance
- alternator removal
- Electronic EGR problems - Fixed and explained
- Air Filter
- Basic maintenance issues
- Double Gas Mileage (Update Pg.5)
- Help Locating my intake manifold
- Replacing Distibutor Rotor
- Intake Question
- Question Reguarding Aem Short Ram Intake
- Using any short ram intake off of Ebay...
- Scratches
- Masks (bras) and Car Washes
- gahhhh! headliner is dirty what do you recomend?
- burning oil
- Turtle Wax ICE review!
- New Spark Plugs + No Speeding + Clean Air Filter = 41 mpg
- so how hard is it to make my 94ex auto into a manual?
- Waxing
- Cv joint boot cover
- 94 civic ex shifts hard-----------
- car trouble!! please help!!
- Civic Won't Run - Any Idea's?
- 2007 Civic Low Oil Pressure
- 02 Civic EX Transaxle Fluid Change
- What can I do to increase mpg?
- What is gapping and electrode in spark plugs?
- how and where do u put jackstands on 02 civic?
- Honda civic 93 Ex sedan Air condition issue?
- Royal Purple
- 2007 Civic Si Dipstick Question
- fuel pressure max??
- Low fuel starting problems
- Really Need 87 Octane For 06 Si?
- 5w-30
- 03 fuel type.....?
- FP PLUS is now released from LCD inc.
- What's wrong with my car?!?
- Maintenence After 90 000 and 3 Years
- Some Hopefuly easy questions
- Excitement
- DIY Manual Transmission Service Help..
- Brake Time
- car won't go into gear!
- About to change my ATF and i have 3 Qs
- Spark Plugs (NGK Iridium High Performance Spark Plugs)
- Rust proofing
- Oil pan nut but missing washer
- Power Steering issues
- synthetic or petroleum
- Zymol Royale
- PCV valve 1997 EX
- Raised fuel consumption
- Switch Oil?
- Is stalling a cause of bad alternator?
