Quote:
Originally Posted by mangoblaster you know why they call it an 360?
Because you turn 360 degrees and walk away |
Ummmm i do believe i found a flaw in your plan.... 360 degrees is a FULL circle so then if you were facing it you in the end would still be facing the said consul.
And as long as you have not logged on since cod mw2 you should not be banned from my understanding and you can always restore it back to original format as to make it not bannable for any reason as long as your numbers are matching
