FS: 1992 Honda Civic EG Hatch Turbo Showcar
Rep Power: 0 FS: 1992 Honda Civic EG Hatch Turbo Showcar
Heavily modified running a Dart Race block. Been on magazine covers and won many shows. Over 50k put into the car. Will run 11's and dynos over 500hp. Block has just been resleaved and runs perfect and needs nothing. Lots of JDM and spoon parts.
- Dart Race Block 84mm
- Pro Drive oil gears
- Bully stage 4 Clutch
- LSD
- JDM B16 Head
- Solo short shifter
- Urehane bushing kit
- Hondata stage 2 with boost control
- ARP head bolts
- Eagle Rods
- Weisco pistons
- Crower valves
- Crower titanium retainers
- Crower valves
- JDM CTR cams
- Cometic head gasket
- Mild port and polish
- Fidenza lightweight flywheel
- Complete valve job
- Custom turbo manifold
- Tial wastegate 38mm
- Garrett T3/T4 turbo
- Yonaka intercooler
- Yonaka aluminum rad
- Turbosmart supersonic blow off valve
- Custom downpipe
- Engine wrap
- 750cc RC injectors
- ITR intake manifold
- Unorthodox racing pulley
- AEM fuel rail
- B&M fuel pressure regulator
- Holly fuel pump
- Flexpipe and catalytic converter
- MSD 6AL ignition system
- MSD blaster coil
- MSD distributor cap
- MSD 8.5 mm performance wires
- 3 bar GM map sensor
- Resister pack to control injectors
- 5 Zigen 3" exhaust and muffler
- STR engine dress up
- Spoon Kevlar spark plug cover
- Spoon reservoir covers
- Spoon oil cap
- Spoon oil drain plug
- Spoon thermostat
- Spoon rad cap
- Spoon valve cover
- Buddy Club N+ coilovers (16 way adjustable)
- JDM ITR front strut bar
- J's racing rear lower tie bar
- Mr. Alex rear upper strut bar
- Mr. Alex rear upper C-pillar bar
- GSR calipers with relocation kit using VW 11.3" rotor
- Brembo cross drilled and slotted rotors
- Redline brake fluid
- Rear Brembo cross drilled and slotted stock rotors
- Spoon cam gears
- Security system
- Perimeter sensor
- 15 x 6.5 Spoon wheels SW388 (45mm offset)
- Rays engineering lightwright lug nuts
- Takata harnesses
- Apex turbo timer, speed meter etc
- Greddy turbo timer
- Tons of JDM and spoon parts from carbon fiber good to sidemarkers, to console etc.
- Broadway meter
- Custom stereo install with Kaption SPL series 12", JBL 600 amp
and much much more!!
Not interested in parting out. Would consider trade for bigger vehicle.
*ABSOLUTELY NO TEST PILOTS*
email is best if you want to get a hold of me. Thanks for looking.
Pictures are here:https://post.craigslist.org/manage/4923588853/fv2jr
- LSD
- JDM B16 Head
- ARP head bolts
- Eagle Rods
- Weisco pistons
- Crower valves
- Crower valves
- JDM CTR cams
- Custom downpipe
- Engine wrap
- AEM fuel rail
- Holly fuel pump
- MSD blaster coil
- Spoon oil cap
- Spoon thermostat
- Spoon rad cap
- Spoon valve cover
- Spoon cam gears
- Security system
- Perimeter sensor
- Takata harnesses
- Broadway meter
Rep Power: 0 Re: FS: 1992 Honda Civic EG Hatch Turbo Showcar
jessicakaybby
04-20-2015 12:11 PM
