Go Back   Honda Civic Forum > MARKETPLACE > Honda Civic Group Buys > Group Buy's Wanted
Group Buy's Wanted Post the group buy's you would be interested in or want started.
Vendors or Pre-Vendors: Post here to see if any interest in a GB.
Members caught doing group buys in this section will be banned. No questions asked.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-09-2009   #1 (permalink)
Grounding_Kits
New Member
Grounding_Kits is an unknown quantity at this point
Feeler:Grounding kit
HI All
Just wondering if you guys would be interested in purchasing a grounding kit for your engine
A little info on what are grounding kits are usefull for:
Grounding kits are known for adding horsepower (minimal) And having better audio system,These kits are a must have for the car audio enthusiasts . Gain optimum clarity from your car audio .
As for HP,now this wont give you 50 HP or make your system gain an extra 10decibles, but it does help improve throttle response, seems to make the idle a little better, and definately helps the response of the factory system.
Automotive electrical and computer systems are designed to tolerate up to 100% noise on their input lines. Meaning, if the ECU is expecting a 12-volt input signal, the signal may vary in the range of 0 to 12 volts. Fluctuations in signal are due to noise and resistance in the system. Noise is generated by spark plugs firing, discharges through the tires to the road, alternator turning on/off, etc. Resistance is the inability of the system to conduct electricity properly. One of the best-proven ways to compensate for noise and resistance is with proper grounding. Engine grounding has been used in the racing industry for years. The benefits have been proven and documented. Grounding Kits allows for cleaner data transfer to the ECU. The result is more accurate measurements by the ECU and therefore more accurate performance, smoother idle and better acceleration.
Did you ever see a car with headlights fluctuating ??
Well most of the time it's because the original Oem grounds are not good and a grounding kit will help
A grounding kit will help your car gain more torque, better gas milage, better response and better starting ability.
And this will be made 4 Gauge copper wire
and rings are included
Colors would be:
RED
Cobalt blue
and See threw Black
All of these will be pre-cut for the Civic
Price would be around the 35-40$ range ship within the US
This is only a FEELER Thread if you would be interested in this and yourself to the list.(Please right down what kind of engine you have) Ex: 1.6L,2.0L
If i have enough people interested in this i'll make some proto-types for different engines and will post them in another thread
Thanks
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Grounding_Kits is offline   Reply With Quote
Sponsored Links
Tags
4gauge , car , civic , ground , grounding , honda , kit , kits , system
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Tokico HP (Blues) GB?
Volant Air Intake Groupbuy
JDM Taillight GB
What is everyone looking for????
K&N FIPK group buy needed!
Group Buy for Power-Folding Mirrors****UPDATED 11/06/2006****
Racing Rims and drag slicks needed!
jdm tail lights
GB: What do you guys want?!?!?!
Checking Interest Top Speed Header!!!
Site Supporters
aluminum radiator
Honda car spoilers
