Below is from the other post about this in other parts....the stage two isn't so agressive that it is going to mess with the idle that bad, but it should produce some pretty decent numbers for NA, with tuning of course, but other than high comp pistons this may be one of the best NA upgrades.
The cams are new, no part numbers yet.
> You'll have to order direct as no dealers have the
> cams at this time.
> Turbo spec will feature a 188 duration, .238" lobe
> lift, .405" gross lift.
> >> Stock D17A2 cam specs:
> >> Int Mid (VTEC) - Dur @ .050" is 184, lobe lift .199"
> >> Exh Lobe - Dur @ .050" is 170, lobe lift .163"
> >> Stage 2 N/A Crower spec:
> >> Int Mid - Dur @ 050 193, lobe lift .237
> >> Exh Lobe - Dur @ 050 180, lobe lift .190
> >> Looking at about $375 per cam + required
> >> spring/retainer kit (#84166) runs $302.
> >> Thanks for your interest in Crower,
> >> Crower Cams & Equipment Co, Inc
> >> 6180 Business Center Court
> >> San Diego, CA 92154-5604 USA
> >> Tel: 619-661-6477
> >> Fax: 619-661-6466
http://www.crower.com
