Go Back   Honda Civic Forum > OFF TOPIC > Off Topic > Movies, TV & Music
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-08-2009   #1 (permalink)
wenling85
New Member
wenling85 is an unknown quantity at this point
how to split/join mkv file, convert mkv file, add subtitle
Part1 some knowledge about MKV video
What's MKV video format?
An MKV file is a Matroska file, the Matroska Multimedia Container is an open standard free Container format. It is similar in conception to other containers like AVI, MP4 or ASF, but is entirely open in specification, with implementations consisting mostly of open source software. Matroska file types are .MKV for video (with subtitles and audio), .MKA for audio-only files and .MKS for subtitles only.
How to play MKV files on Windows?
In principal you can play MKV files on almost every Mediaplayer on Windows if you have the latest CCCP playback pack from Matroska Download Page installed, as most of these players are based on Microsoft DirectShow (TM).
Part 2 MKV Converter - split/join MKV file, convert MKV file, add subtitle
1. Convert MKV file
Format supported
HD(High-definition) video ( AVI, MOV, WMV, MP4 TS, MTS, M2TS, MKV)
SD(Standard-definition) video ( AVI, WMV, MP4, MPEG, VOB, FLV, 3GP, ASF, MOD, MOV, etc.)
Step 1 Click "ADD" to load MKV file.
Step 2 go to "convert to" to set the output format.
Step 3 go to "target path" to set the output location.
Step 4 hit "start" to begin convert MKV to AVI, convert MKV to HD WMV MP4 3GP, etc.
2. Split/Join MKV file
MKV file is a high definition file which takes up much space on hard drive. With this MKV splitter, you can trim particular part off the MKV file to save space.
Got to "Edit - trim"
Click the Trim button to open the Trim window and trim the current video file by dragging the Start Time slider to set the start time and dragging the End Time slider to set the finish time.
Or join MKV file
On the main interface, there is an option which shows "merge into one file". Check it if you want to combine your mkv files.
3. Add subtitle to MKV file
If your MKV subtitle is seperated, you may want to add it to the MKV file.
Step 1 Put your MKV subtitle in the same folder with MKV video and name as the MKV.
ie. D:\Movie\chd-ntbos-bdrip.mkv D:\Movie\chd-ntbos-bdrip.srt
Step 2 Then select "Add" button to load the MKV video files, this tool will detect your subtitle file and add subtitle automatically.
Link
MKV Converter
wenling85 is offline   Reply With Quote
Sponsored Links
Tags
add , combine , file , files , format , free , freeware , join , joining , links , mkv , movies , remove , split , trim , video
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Initial D Fourth Stage
Quote Guessing Game..
guess the movie, get some points.
The New Real World--Austin
The Great Music Debate............
Your views on rap/hip hop
guess the movie
Injencivic's new age rock list...***UPDATED CONSTANTLY***
Guess the song by the pictures
what songs make ur subs hit hard?
Site Supporters
aluminum radiator
Honda car spoilers
