| You can use press bent, but mandrel bent is going to be best. I'm pretty sure if your turbo puts out x amount of air and there is a restriction in the piping, it would be more prone to surging (kinda like backpressure on an exhaust system). As for the returnless system, you can most likely use bigger injectors and a piggyback fuel computer like GReddy e-manage, or get a standalone ECU like AEM EMS. You could also keep your stock injectors and add an extra injector controlled by a fuel controller. As of right now, I think there is only one person who is working on using just larger injectors and the E-manage (JohnyBlaze?) |
