Forced Induction and SwapsPost information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Turbo kit is now available at TurboDiscounters.com
I called them up today and he said the extreme kit is gonna run anywhere from 2600.00 to 2800.00 and the kit is designed to run 16 psi, it comes with everything and its a complete bolt on. Keep AC and PS and the fuel system is taken care of by bigger injectors. I have already preordered the kit and its ETA is in 4 weeks from today. I can install this kit and still keep factory warranty with the sponsership i have with my dealership. Ill keep you updated. Im wondering if they can hook my up with a larger turbo tho.
Kit contains *
1 Garett Turbo (size is depending on kit ordered)
1 Down Pipe
1 High Nickel Composite Cast Exhaust Manifold
1 Fuel Pressure Regulator
1 Injection Control Unit
1 Injector interface block with injectors
1 Blow off valve
1 High flow intercooler with all mounting hardware, pressure tubes,
rubber hose connections and clamps
1 Map unit (Black Box)
1 Oil Return Line and Fitting
1 Air Filter with piping
i cant wait! said to produce close to 75hp at the wheels he said
There is also a smaller kit called the superior kit and its not as much money. and doesnt consist of the same components
__________________
Sponsored Links
Great info. I'd like to know if it works with the LX models since that's what I got. I wouldn't think V-tec would make a difference for the application.
Also is there a link to the company or how/where to purchase the kit?
the only thing that worries me, is are those brand name parts, or just cheap pos's. because i'd feel safer if they had brand name parts in their turbo packages. if i'm gonna turbo my car i would do it right the first time ......... you get what you pay for
i don't think bigger injectors would do it for me... what if later down the line i do some internal work and decided to boost more?? i would still need more fuel and i think new injectors would come short of what i need.... sf turbo kit comes with a secondary fuel pump and management system... it's too early to say which kit i want because there are only numbers out for the sf kit... once the numbers from the turbo discounters kit comes out, i'll decide from there....
Originally posted by derty this turbo kit works for all models of the civic -=]
are you sure?? cause there needs to be different downpipe sizes for the kits seeing how the cats on the LX/DX are different from the cat placement on the EX...
Originally posted by iamboo are you sure?? cause there needs to be different downpipe sizes for the kits seeing how the cats on the LX/DX are different from the cat placement on the EX...
he has different kits for the different trim levels as far as parts they are all brand name but im still wiggin on the fuel system. I wonder what else would be neccesasary to run a higher level of boost besides internals. Im also gonna ask about a larger turbo
Originally posted by emmc they said it was gonna be under 2800$
first everyone complains that no one will make a turbo system then someone finally has the balls to do it and the system setup seems very nice then people complain about the price in which its listed. DAMN man. IM greatful , yea its more than he quoted us but at least you have a kit now
Because the kit is using the new Dual Ball Bearing Center, as opposed to Garrett's conventional floating center it turned out to be a higher price then we were expecting. But the Ball Bearing Center Turbo is a sweet unit, it's worth the extra price!
Quote:
Originally posted by xmeeksx will this pass emission? because they are strict here in VA
The design of a turbo actually makes the car run cleaner, however you are modifying the way your exhaust system works and the smog guys don't always like this. Check with other drivers in VA and see what they went through when they had to test smog.
__________________ Bradley Dean
+> Add More Boost
IM gonna be all over this, i did have one question the pipijng for this whats it gonna be? i saw on your site and it actiually looked like it was flexible piping. Is this true?
I might be all over this dunno yet still wanna see some numbers between the 2 kits out for it right now and also the other turbo kit shop is located so close to me =] so dunno yet.
