Yeah, I'm slightly worried about long drives as well. Not because of overheating, but just because you're basically using up the engine and fuel when you don't need the power. I guess one solution would be to simply "turn off" your turbo. Simply set your wastegate to bypass as much of the exhaust gases as possible. With a large enough wastegate the turbo won't spool up and you'll have no problems. Hmm... Then again, premature wastegate failure comes to mind. LOL
I think I'll do that for my setup. Simply have a boost controller that allows me to decrease the boost for long road trips. To save fuel and to save the engine.
