Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-17-2003   #1 (permalink)
Grey
DIY King
Grey's Avatar
Grey has a spectacular aura about Grey has a spectacular aura about
Send a message via AIM to Grey
ATTN: Turbo Wannabe's: Missing Link Valve
First off I'de like to thank all of those who donated their money to this cause. You know who you are. Without your help I would have had to wait a little longer before I could buy this product.
For those of you who don't know what this thread is about... It's about the Missing Link Valve from Synapse Engineering. This valve protects the stock map sensor from too much pressure when the turbo kicks in and it also allows the map sensor to read slight changes in pressure so that the ECU can still adjust the fuel for various altitudes.
Now, for those of you who said to get the ML001: You were right and you were wrong. It's the only one that has a chance of fitting, but not without serious modification. Either the stock map sensor has to be modified, or the Missing Link Valve could be modified.
I will be modifying the Missing Link Valve since I don't want to destroy the stock MAP sensor and not be able to return the car back to stock if I decided to sell it. This will involve drilling out the holes within the Missing Link, cutting off one of the mounting points (mostly for appearance), and adding on a little extention for support.
I will be doing this soon and I will write up a DIY so that people know what to do.
Here's some pics...
Grey is offline   Reply With Quote
Sponsored Links
Old 03-18-2003   #2 (permalink)
JohnyBlaze
Member
JohnyBlaze is an unknown quantity at this point
What about not using check valves at all? You can use the GReddy e-Manage to electronically hide the boost from the stock ECU and let the e-Manage also control your injectors. Wouldn't that work?
--jB
JohnyBlaze is offline   Reply With Quote
Old 03-18-2003   #3 (permalink)
CIVIC808
Super Member
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
Send a message via AIM to CIVIC808
See i was stuck with that problem too. i remember asking you about this that it wont fit.i dont know how your gonna make that work.one screw is not good enough to hold it down and have a good seal.i think the other type of missing link would be easier to modify.i hope you can find a way though.
__________________
2001 civic sedan ex-t
227hp 230tq
13.3@103mph
1995 civic eg
b18c turbo
11.94@116mph -slicks
12.7@117mph-street tires
civic808's myspace
CIVIC808 is offline   Reply With Quote
Old 03-18-2003   #4 (permalink)
Grey
DIY King
Grey's Avatar
One screw would be okay as long as I can make the same kind of extention as the stock sensor has. Then it would seal properly.
The Greddy E-Manage can't "hide" the positive manifold pressure past a certain PSI. Plus, the stock MAP sensor will only read up to a certain PSI. Then it'll simply die.
I think I can make it work. This is THE one to have though. The other missing link types don't look like the proper ones to have. One has the holes spaced too far out and the other is simply not feasable.
Old 03-18-2003   #5 (permalink)
JohnyBlaze
Member
I'll let you know how the GReddy E-Manage works out -- I'm actually trying to do it without the Missing Link. I've upgraded all four injectors with 450cc DSM injectors and put in a larger Denso fuel pump as well.
The stock MAP sensor will feed the E-Manage which in turn alters signals going to the stock ECU.
I already have the car idling with the large injectors being controlled by the stock ECU + E-Manage.
My only concern is the stock MAP sensor physically popping under boost. But from what I've heard, previous gen Civic MAP sensors were good to 11psi, so I assume ours will be fine for 8psi, which seems to be the magic number for safe boost.
--jB
Old 03-18-2003   #6 (permalink)
Grey
DIY King
Grey's Avatar
Very interested. Please do.
Old 03-20-2003   #7 (permalink)
Speedracer32
Ultimate Member
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
Send a message via AIM to Speedracer32
JB:
Some told me that the DSM 450cc(blue Top) wouldn't fit on our cars?
are these the same ones you used?
and did you upgrade fuel reai and FPR?
Speedracer32 is offline   Reply With Quote
Old 03-20-2003   #8 (permalink)
JohnyBlaze
Member
Yes, the fuel rail and intake manifold had to be modified to fit the 450cc DSM injectors (correct, the ones with the blue top).
As for the GReddy e-Manage, here's essentially what is happening:
- e-Manage gets input from the stock MAP sensor, TPS, RPM indicator, and GReddy pressure sensor
- stock ECU gets input from ALL stock sensors (throttle position, RPM, O2 sensors, air temp, atmospheric pressure, etc.) EXCEPT for the MAP reading which it now gets from the e-Manage (a modified signal to hide boost -- basically a voltage clamp), plus various other signals modified by the e-Manage
- ignition and injection signals outputted by stock ECU are intercepted by the e-Manage instead of reaching the injectors and ignition coils
- e-Manage modifies injection and ignition signals based on inputs: MAP, throttle, RPM, boost pressure
- injectors and ignition coils receive (modified) firing signals from the e-Manage
The whole system should run really well. I think this is a pretty clean approach, no need for check valves, no injectors in the intake tract, properly retarded timing, etc. Note that to do it this way, you need to buy the optional GReddy pressure sensor, injection harness, ignition harness, and support software. This brings the cost of fuel/spark management to about $750.
I'll let you know how it all works/runs after it's tuned.
In case you're wondering, I'll be running a Mitsu 16G turbo @ 8psi. This is the manifold I'm using: http://www.davesport.com/cgi-bin/dav...7manifold.html -- although, I will have it ceramic coated (along with the O2 housing and turbine).
The setup will be cooled by a Griffen top-to-bottom FMIC. It's not as large or "pretty" as a huge side-to-side FMIC, but it's more than enough for 8psi, and it'll go well if you're not looking to grab too much attention.
I'll probably post pics once it's done (expecting March 28). I may not though cuz I don't want people to recognize my car. Well, I guess I can at least post pics of the engine bay.
The whole thing is costing me about $6000 installed and fully tuned. If you are in the Seattle area and are interested, let me know and I can get you in touch with my mechanic -- he's top notch, very high quality work. He prides himself in building OEM quality setups.
--jB
Old 03-20-2003   #9 (permalink)
Grey
DIY King
Grey's Avatar
Yeah, I posted a thread in Tech Stuff about the E-Manage a while back. I'll be using it as well. I just didn't know that it could be used to modify the stock MAP sensor. I thought that it needed it's own pressure sensor to read boost. Definately let us know how that works out.
That manifold you're going to use looks interesting. Not an optimal design, but it's nice and compact.
Old 03-21-2003   #10 (permalink)
Booohahaha
BAD MON
Booohahaha's Avatar
Send a message via ICQ to Booohahaha
woo looks good...
cant wait for the DIY!
Booohahaha is offline   Reply With Quote
Old 04-01-2003   #11 (permalink)
MadWheel
Premium Boosted Member
MadWheel's Avatar
MadWheel will become famous soon enough MadWheel will become famous soon enough
I emailed them looking for prices for it with a T25 flange. Hopfully they'll comply and help me out.
MadWheel is offline   Reply With Quote
Old 04-06-2003   #12 (permalink)
Speedracer32
Ultimate Member
manifold looks similar to mine but don't all log styles
i wnated equal lengths but this was priced better and that other 100 some odd dollas can go to something else.
what kind of flange is on there?
and what kind of adjustments did you have to make to get the DSM's too fit
major or minor? somethingi could do myself???
Old 04-06-2003   #13 (permalink)
XxJDMCivicxX
Ultimate Member
XxJDMCivicxX's Avatar
The E-manage seems to have more uses than I thought didn't think it would be able to manage all that. Your setup sounds like its going to be quite the sleeper type , good luck to all of you guys with each one of your turbo setups
XxJDMCivicxX is offline   Reply With Quote
Old 04-06-2003   #14 (permalink)
Boosted2k2
Boosted2k2's Avatar
Boosted2k2 should not be trusted Boosted2k2 should not be trusted
Send a message via AIM to Boosted2k2
Quote:
Me neither. Found this:
More info: manuals, instructions etc. here
Boosted2k2 is offline   Reply With Quote
Tags
2002 , check , civic , good , honda , link , make , map , missing , sensor , setup , turbo , upgrade , valve , valves
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
DIY Mechanical O2 simulator
K20z1 Swap/Turbo in process.
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
